Results 1 to 34 of 34
    Mar 11 2007
    Colorado Springs
    Cool
    Quote Originally Posted by gta7 View Post
    I have googled and googled. Can the asterisk button on the RS7 be programmed to change the drive select mode. I'd love to be able to use it to change between comfort and dynamic.
    I have the drive select button on my steering wheel, the there is no way to make it work... It does not work with the pre-facelift C7. MY 2012, 2013, 2014
    IIRC, if you have to have the C7 facelift with the updated cluster, it will allow you to see which drive mode you're in. There is one caveat, if you have MY 2015 I think with some coding it'll work, you just will not see the "drive mode" on the
    DIS.
    I could be wrong ;-)
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Senior Member Three Rings RSLRS71's Avatar
    Mar 03 2017
    18' SQ5 and WK2 SRT8 Jeep
    Castle Rock, CO
    whats wrong with using the "Drive Select" button on the steering wheel??
    edit: nevermind...seeing the other replies...
    2017 RSL RS7 (1 of 3 stateside)
    Mods:
    Current: APR Stage II w/ HF DPs and KW H.A.S kit , Rotiform 3 piece SPF 21x10.5 wheels, Tag Motorsports Side marker delete and Badge blackout, ...
    Next: looking to be the quickest RS7! ;)
