Results 1 to 34 of 34
    Aug 11 2016
    CA
    Drive select with the asterisk in steering wheel
    I have googled and googled. Can the asterisk button on the RS7 be programmed to change the drive select mode. I'd love to be able to use it to change between comfort and dynamic.
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Afaik, by default (stock programming)...it can't as it is linked to a few standard commands.
    Only way is by adding a programmed chip between it.
    Alex might maybe able to help out in the near future....but there are a few working on custom chips atm :).
    Edit: what buildyear is yours? You can always swap the steeringcontroles with the ones that have the drive select buttons (contact Alex@europrice)
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Oct 21 2014
    Amsterdam
    Quote Originally Posted by Dasquade View Post
    Please keep me informed about this
    ( Mag ook via audiforum )
    Veteran Member Four Rings Street Nasty's Avatar
    Jan 20 2009
    B5 S4 Avant
    Quote Originally Posted by supercharged- View Post
    I think my friend is selling his drive select button for 150. Pm me your email if you're interested and I'll pass you off to him.
    Sent from my LG-LS993 using Audizine mobile app
    Oct 21 2014
    Amsterdam
    @Street Nasty
    I already have the buttons and bought them new for €130. But unfortunatly it isnt working because i have a pre facelift model. I hope someone will find a workaround or something.
    I think my only option is to retrofit a MIB 2 so it will work
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Subscribed. That would be so convenient.
    Sent from my SM-G935V using Tapatalk
    Jan 31 2012
    I thought some model years had this by default?
    Jan 10 2017
    CA
    check out europrice. alex is selling the controls from the rs7 performance that replace the asterisk with the drive select button. I'm planning to switch this out soon
    2016 Daytona Gray S7. Black optics + sport pkg. Stage 3, eurocode stuff, cosmetic stuff.
    Sep 07 2010
    Belgium
    Quote Originally Posted by mookow View Post
    Like mentioned below, only the facelift performance ones have it and replaces the * function.
    Might be maybe possible to program it over custom chip in the near future....
    Aug 11 2016
    CA
    Ok just looked at that and for $325 I might do it.
    Anyone know how hard that is to swap?
    Since the RS7 has it I would think VCDS coding would work as a button is a button.
    Senior Member Two Rings moonlights4's Avatar
    Jan 11 2014
    2018 S4
    Kansas City
    Agreed. Would love this feature. I'd buy VCDS just for this. Does seem like it would be a coding issue
    2018 S4 Prestige, S Sport, DAP, Dynamic Steering, Cold Weather
    Past Cars:
    2014 S6 Prestige, APR Stage 2 ECU/TCU, APR Downpipes
    2014 S4 Prem+ DSG
    2013 S4 Prem+ DSG
    2010 Q5 Prem+ 3.2 V6
    Mar 11 2007
    Colorado Springs
    Cool
    Quote Originally Posted by gta7 View Post
    I have the drive select button on my steering wheel, the there is no way to make it work... It does not work with the pre-facelift C7. MY 2012, 2013, 2014
    IIRC, if you have to have the C7 facelift with the updated cluster, it will allow you to see which drive mode you're in. There is one caveat, if you have MY 2015 I think with some coding it'll work, you just will not see the "drive mode" on the
    DIS.
    I could be wrong ;-)
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Senior Member Three Rings RSLRS71's Avatar
    Mar 03 2017
    18' SQ5 and WK2 SRT8 Jeep
    Castle Rock, CO
    whats wrong with using the "Drive Select" button on the steering wheel??
    edit: nevermind...seeing the other replies...
    2017 RSL RS7 (1 of 3 stateside)
    Mods:
    Current: APR Stage II w/ HF DPs and KW H.A.S kit , Rotiform 3 piece SPF 21x10.5 wheels, Tag Motorsports Side marker delete and Badge blackout, ...
    Next: looking to be the quickest RS7! ;)
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    You need a C7.5 facelift model to use the RS6/7 Performance controls which have the DS button.
    2016+ models can use coding to enable the DIS to display the Drive Select mode when the button is used.
    No coding works on pre-facelift models to make these controls work unfortunately.
    Controls | RS6/7 Performance Multi-Function
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Senior Member Three Rings sean_entrust's Avatar
    Feb 11 2017
    Portland OR
    my s3 allows me to do this. I have the * button as my drive select.
    2017 S3 P+ (Mine) Daytona Gray Pearl / Black Optic / Carbon Fiber Package / 034 springs / Stoptech BBK / 12.94 @105.3mph stock
    2012 Q5 P+ (Wife) Ibis White
    Veteran Member Four Rings IowaRS7's Avatar
    Mar 22 2017
    69 Camaro SS
    Iowa
    Quote Originally Posted by sean_entrust View Post
    Did you program this through VCDS or another way?
    2016 Nardo RS7, HRE P107 21x10.5, MPSS, JL Audio sub/amp, VCDS mods, Eurocode sway bars and end links, CF/Alcantra SW, Carbon paddles, tinted windows, VIM enabled, CarPlay enabled, hardwired Escort Max 360, CETE susp module, SRM ECU/TCU tune for E85, DS1, fully built SRM monster on the way!
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Quote Originally Posted by IowaRS7 View Post
    No, it is the "wildcard" button. You program it in the MMI just like setting the settings for "Individual". When I had my S3, I programmed the "wildcard" * button to toggle between night and day mode lighting on the NAV. The option to set it for Drive Select was available as well even though there was already a Drive Select button on the dash.
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Feb 11 2017
    Portland OR
    i was able to do it through the MMI
    Aug 11 2016
    CA
    Not that I am a VCDS expert but it seems to me you could code the asterisk to function like the drive select button.
    Aug 11 2016
    CA
    I would gladly pay for the new switch but the install sounds a bit more than I want to do at this time.
    Mar 22 2017
    69 Camaro SS
    Iowa
    Quote Originally Posted by nefkntym View Post
    Ok, not an option by default on my 16 RS7
    Feb 26 2010
    Los Angeles, CA, USA
    Agreed...in my 2016 RS7, you can program the wildcard button to do a few select functions thru the MMI, but the function for drive select toggle is not available.
    I ordered the drive select button from Alex of Europrice and installed it...worth every penny.
    2016 Sepang Blue RS7 with Audi Exclusive Interior In Lunar Silver/Alcantara/Sepang Blue Stitchings, Layered Aluminum/Black Wood Inlays
    Carbon-Optic, DRC, Sport Exhaust, Driver's Assist Package, Night Vision, B&O, 21" OEM Wheels, CF B-Pillar/Exterior Mirror/Rear Trunk Spoiler,
    TAG Painted Side Markers, CF Interior Roof Handles/Rear Seat Center Console, RS7 Floor Mats, W&F LED Door Projectors
    Xpel Ultimate + Opticoat Pro Plus
    Aug 11 2016
    CA
    Quote Originally Posted by chucky0731 View Post
    How hard was the switch to install? Did you do it yourself?
    Established Member Four Rings limeypride's Avatar
    Mar 18 2017
    Snohomish
    I have it by default on my car--I can't imagine living without it. Even with it, there are 2 too many modes--I want Individual and Dynamic and that's it. Cycling through them makes me yearn *every time* for my M1 and M2 buttons. Then I accelerate from nothing and forget all about it...
    2018 ////AMG E63S in Diamond White/Nut Brown, lowered 20mm front/back, spacers, tints, EuroCharged tune
    Gone but never forgotten
    2017//RS7 Performance in Mythos Black, Audi exclusive Titanium edition w/ Akrapovic exhaust
    Jan 10 2017
    CA
    Quote Originally Posted by limeypride View Post
    Thank you for this. I was going to PM you with this question given you have a rs-P. I've been wondering whether you have to cycle through all 4 options or if you press the button and then use the scroll wheel to pick. Bummer that you have to cycle -- but better than what the rest of us have!
    Jan 20 2009
    B5 S4 Avant
    Pop off the airbag and then pry off the surrounding plastic trim. The buttons have a spike beneath them that allows you to pry the buttons up.
    Sep 01 2014
    2017 BMW X5 50i (family-friendly monster)
    NoVA
    Quote Originally Posted by Street Nasty View Post
    How do you "pop off the airbag?" And is there any VCDS coding required once you have the new set of controls installed, or is it literally "plug and play" once the new button is in?
    Established Member Two Rings Julius_855's Avatar
    Nov 04 2016
    Germany
    I have those commands since Jan and a facelift model. What am I waiting for.....
    I guess some coding is needed though, or?
    2016 S7 Sepang Blau
    2006 Z4M
    2012 A7 bi-TDI (sold)
    Jan 20 2009
    B5 S4 Avant
    The are two holes behind the steering wheel that you stick a flathead through to pry off the tabs that mount the airbag. You hang to turn the wheel once for each side to access them. If you take a picture with your phone it will give you a better idea. Also, there are videos on YouTube with instructions from people who have removed it. It might take a bit the first time, but you'll get the hang of it.
    If you have a facelift and buy drive select buttons and want to see it change in the dis (dash) then yes, you have to change the coding. I do not know what it is, someone posted on the forum a while back about it.
    Sep 01 2014
    NoVA
    Thanks, I found the video of the guy popping it off in an A7 on YouTube. How hard is it to pop off the black trim?
    I do have a facelift (2017 RS7 standard), so it looks like some coding is required. I'll have a look around the forum and see if I can find it.
    Jan 20 2009
    B5 S4 Avant
    Quote Originally Posted by Safelder View Post
    The black trim you just pry off with a nylon trim tool. Just go slow.
    Jan 10 2017
    CA
    I just did the coding a week or so ago. Here was the thread I used to do it. If you find a better one and / or determine that one should do more than just change the 5th digit from a 0 to an 8, please let me know.
    http://www.audizine.com/forum/showth...ng-wheel/page2
    Sep 01 2014
    NoVA
    Quote Originally Posted by kpriv View Post
    That's the same one I found. Tough to tell what's going on there with all the pictures missing, but it looks like you had success.
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    Why would even take it out of dynamic mode?
    Comfort mode is for my wife or grand pa only!
