Results 1 to 4 of 4
Thread: Catch can help
    Senior Member Two Rings SeniorCypress80's Avatar
    Nov 09 2016
    01 A4, 01 S4
    Indianapolis
    Catch can help
    Hey guys I am looking for some information, suggestions and setups people are running for a catch can. I am currently running a DIY setup with a 034 block adapter and valve cover breather teed off going into a harbor freight separator then dump backed into my pancake. I just ordered a bunch of 10an hoses and fittings and would like to hardline it all and eliminate the pipe on left of possible. Any suggestions on this part? Also I would like to be able to use this kit and change lines when I go to big turbo. Do big turbo catch can setups vent to atmosphere then?
    Dec 05 2007
    You just have to wing it. I suggest nylon braided hose over SS for this, due to flexability. My setup uses black nylon braided hose.
    Veteran Member Three Rings APC123's Avatar
    Feb 05 2017
    Wilmington Delaware
    I can make a vid and put it on YouTube, I will tm I'll set a reminder
    Feb 05 2017
    Wilmington Delaware
