Hello there
Not sure you are still around since i see that this is an old post!
I am trying to get the part code from stealership but they will not give it to me.
I have an AUDI A6 C6 (4F2) model... the 2.4 FWD car. Does the above mentioned oil (G052180A2) work for my gearbox?
The price for the Audi oil is ridiculous... if I use the Febi Bilstein (27975) oil, do you reckon it would cause a problem? Have you had any experience with using a non OEM oil?
I heard multiple sources claiming that they used an alternative oil (both cases used the Penrite CVT oil) and both said they had to replace it because transmission was slipping.
Thank you in advance
