Results 1 to 30 of 30
    Jan 26 2014
    66 Shelby Cobra
    Kansas City, MO
    What IAT's does everyone see at idle for 4-5 minutes?
    Just trying to understand what IAT's everyone sees at idle for 4-5 mins with different setups.
    With my setup (new APR CPS), I tested this the other night to simulate what happens in staging lanes at the strip. With the car warmed up, I turned the A/C on with heat set to max (radiator fans on). Outside temp was around 60F.
    My IAT's were hovering around 50-52C with the hood closed.
    2012 S4 - EPL Stage 2 DP Meth Tune and TCU Tune, 3.25 PR, Jokerz 'Chaos', 75mm TB, APR CPS, CTS Intake, AWE Touring Exhaust & Resonated DP's, Tampa AutoSports TP's, Autotech HPFP, AEM Meth, Zeitronix E-Analyzer, CR-15, Trans Mount Insert
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    waiting for loe to chime in with sub-ambient IAT's.....
    Quote Originally Posted by AdamInKC View Post
    I'm dp EPL e85. Awe coldfront. I'm about right there too. ~50C. But that is without the ac on and turned to hot. Outside temp ~60F
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    I looked at that on my car last year.Result below after a long drive then parked in a car par waiting for the wife :)
    For another reference point,the below is cruising at 70MPH or so last week
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Those numbers seem high especially with upgraded cooling. I'm stage 2 only with stock cooling and last week at the track I was seeing temps in the low 40s/high 30s with the AC running.
    Jun 21 2016
    Tampa, Fl
    PLM with dp and see 39 to 41C holds steady there.
    2012 S4 6mt EPL DP 189/57 11.6ET @ 121
    1995 Supra Single Turbo 600hp 11.5ET (AEM)
    2004 350z Twin GT3076 E85 600hp 11.3ET ( Haltech )
    2012 Genesis Coupe PTE 5858 e85 500hp 11.9ET ( Haltech )
    2006 GSX-R 750 Track Bike
    Senior Member Two Rings audis4culver's Avatar
    Mar 07 2016
    2016 S7, 2011 S4, 1985 VW Vanagon, 2015 Q7, BMW 2004 X5 Manual, 1966 Jaguar E-Type
    Georgia
    I have logging for a few days now about to install another micro fan to get ready for 100 degree outside air temps in atlanta. I am giac stage 2, plm hx with reservoir - yesterday in atlanta 88 degree weather sitting in traffic for about 4 minutes - consistent IAT is 40-43 that's after some good stop and go's between lights. no AC or heat fans on.
    2016 Audi S7
    Jul 04 2008
    York, PA
    Im glad I sent my APR CPS back, it seems it doesn't work (like everything else APR).
    Mar 07 2016
    Georgia
    check this thread as well - there is more logging done by a variety of folks "IAT and Engine Coolant Temps "
    2016 Audi S7
    Veteran Member Four Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    Quote Originally Posted by k6750gsxr View Post
    That's what I see with PLM on the lower end. OP, have you tried bringing RPMs above 2000 and holding them there for a few seconds? Even with high heat and A/C on my temps will fluctuate up to 45-47*C. Once it reaches a certain point the pump will come on and bring the temps back down on its own but when I see the IAT's starting to go up I'll rev it a little to manually kick on the pump.
    2013 S4 S-tronic - 3.47 PR // EPL DP ECU/TCU tune // PLM hx // APR intake // Jokerz Blower // Headers // Ice box // iABED TB // Autotech HPFP // RS7 LPFP
    11.186 @ 123.35
    1993 URS4 - GT3071R - EFI Express Tuned - Gutted
    Past: 07 S4 6MT ~ 03 A4 3.0 6MT ~ 99 A4 1.8T
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    Quote Originally Posted by 4Rings3Liters View Post
    How's does a heat exchanger not work lol
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Sitting idle without the fans running isn't really going to allow any heat exchanger to do it's job.
    My IAT's when idling are very dependent on the ambient temps. I can easily see a range between 35-45 degrees.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Jul 21 2004
    South Florida
    Quote Originally Posted by jran76 View Post
    ditto. idle IATs arent really a measure of hx efficiency per se
    2018 Audi S5
    Gone-
    Feb 05 2016
    UK
    Whilst that is true, I wouldn't expect the IAT's to be in the 50*C range when it is 15*C outside.
    Add to that he had the heat on full wack with AC running & I think those reading are quite high
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Im glad I sent my APR CPS back, it seems it doesn't work.
    How so?
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Jul 21 2004
    South Florida
    As a comparison mine get around 46-50c when idling in 21c ambients. They'll only top out at around 65c on a run but they start out pretty hot once the car has been through a run and heated up. I could go drive the car on the highway and get them down to 39c or so but we are usually packed at PBIR so no opportunity to do that.
    Mike
    2018 Audi S5
    Gone-
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Quote Originally Posted by DBL R View Post
    its quite comical sometimes when logging to see IAT's, truly a no thought process needed to get maximum power (given the D/A) for practically each run with minimal waiting. Another local guy has his hooked up with the stock pump (Hx delete as well), he actually see's better IAT's than I do, enough that I'm considering putting back in my OEM pump and selling my AWE one.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    May 09 2012
    United States
    Quote Originally Posted by Loe View Post
    I can't bring myself to remove the stock Hx...I'm waiting for my KC and PLM reservoir to come in...Hopefully I'll have it all installed in the next week or so...
    Jul 04 2008
    York, PA
    Quote Originally Posted by Trent212 View Post
    Ask APR.
    Quote Originally Posted by Silverbullet S4 View Post
    How so?
    Have you not read the OPs thread? IATs are in the 50s. Mine tonight at the track were in the low 40s with stock cooling.
    Nov 20 2014
    New York
    20C/68+F outside per car's MFI
    This was after a short drive idling
    After a drive literally around a city block and back to my driveway, slowed down to a stop sign, to a crosswalk and a redlight
    This was idling for 5 minutes about after previous drive
    This is where the fans kicked on and I switched the pump to 100% duty cycle via switch
    This was after same drive around the block but I was stuck behind a car. Lowest IAT's went were 46C
    Jul 04 2008
    York, PA
    Sonic, is that with APRs CPS?
    Nov 20 2014
    New York
    No this is with my home made set up but to put it into perspective
    This was in moderate traffic on the highway. Dropped down to 28-32 at 60-70 mph
    Jul 04 2008
    York, PA
    Quote Originally Posted by sonic32 View Post
    What's your setup?
    Nov 20 2014
    New York
    What's your setup?
    DIY stacked heat exchanger and reservoir upgrade
    Post #224
    https://r.tapatalk.com/shareLink?sha...8&share_type=t
    Mar 03 2009
    Cape Cod, MA
    That "ambient air temp" in OBD fusion is all over the place. Do you know what sensor that reading pulls from? For 68*F outside those IAT's seem a little high. You have the coolant routed a little different correct?
    11.186 @ 123.35
    Nov 20 2014
    New York
    Quote Originally Posted by kelseysautobody View Post
    Yeah I know for some reason it's all over the place. I think the sensor next to heat exchangers by the crash bar, hence it gets got in there from the engine. I think those IAT's correspond to that ambient sensor more than the MFI onemmm
    Mar 20 2015
    McKinney,TX
    Tonight I came home after a 30 min drive from the office. Short time later I ran my car at idle for a good 20 mins in my garage while I registered my new battery and looked at a few other things with the software
    I then set up a few logging parameters and was surprised that my IAT's were near 198 F (Ambient was 95F), while I was at idle. Typically when I'm out and about and do WOT runs it never gets above 130F.
    I took the car out for a two minute drive and the IATS dropped to 140 almost instantly. I have a stacked heat exchanger which does well when the car is moving, but offers no help at all when parked.
    This all makes sense to me I just didn't think a car at idle would heat up to nearly 200 degrees.
    May 09 2012
    United States
    Quote Originally Posted by EIAlfonso View Post
    This is what I've been noticing. Makes sense why the killer chiller cars are so consistent at the strip....
    Veteran Member Three Rings FromRagsToS4's Avatar
    Jan 23 2017
    Idaho
    So for people without killer chillers.... What can we do retain our maximum potential power and keep from heat soaking so bad just sitting there, like at a stop light and an M3 is talking smack, or in the staging lanes at the strip...?
    Mar 14 2016
    TheFarEast
    i'm out in a tropical climate in Asia, with ambient temperature ranging from 30-35 degrees Celcius.
    With the AMS alpha kit, EPL DP setup with 183mm pulley, idle temps peak at 55 degrees Celcius.
    main benefits of the ams kit is only seen when driving, where temps drops as low as 39/40 degrees celcius, measured via the P3 gauge with the updated track pack.
    to be specific, the faster rate at which the temps drop after a hard run.
