Results 1 to 40 of 76
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    B7 S4 to RS4 Avant Build
    Figured I would start a new build thread now that this project is nearing completion.
    What a journey..
    Post up if you want more detail on any one aspect of this build. While I had one shop do the motor and another do the body work, I was still very much involved in just about every aspect of this build from a process standpoint.. wanting to know what was being done, or making sure certain things were addressed... and most importantly.. procuring annoying to find RS4 parts from the US and Germany. I'll try to offer some insight into what this build was like.. besides being too expensive
    Overview: The car started life as 2008 S4 Avant with a tiptronic trans. I found the car in Kansas with 75k on the clock. Long story short (there is another thread for this car from its S4 days) I ran a 70 shot direct port wet shot nitrous system for about 6months.. blew the motor.. and that led to obvious conclusion that I should do an RS4 swap. Still can't justify it.. but I try.
    RS4 motor was sourced from two different cars.. short block had 50k miles on it.. Heads had around 70k if I recall. Whole engine was torn down and rebuilt. New seals, oil pans, pumps, you name it.
    RS4 motor was installed in July, 2016. Correct front mount had to be welded in, battery was relocated to the spare tire compartment. ECU's were mounted properly behind the firewall. The whole fuel system was changed from the tank forward to accommodate high pressure setup.
    Power/Drive train and suspension mods:
    6sp swap, JHM shifter trio, JHM limited slip rear diff, JHM R series pressure plate, light weight fly wheel, and 3R clutch. OEM RS4 shifter and boot.
    SRP racing pedals. 034 trans mount, Apikol rear diff mount.
    Suspension: KW V3 coilovers. HD control arms, adjustable uppers. 034 HD rear sway bar with adjustable end links. HD front sway bar mounts.
    Engine: JHM 2.75 downpipes, no cats, EBWerks 2.75 exhaust, no cats, no resonators. Grouppe M intake, JHM LW crank pulley, 034 engine mounts. Tune will be done after the body work and will be a tune by United Motorsport in CT.
    Wheels/tires: HRE P43SC 19x9.5 et 26 with Bridgestone Potenza 255/35/19 tires.
    Brakes: Brembo GT's in front, JHM BBK in rear with EBC Redstuff pads.
    Interior: Recaro Sportster CS seats, TTRS steering wheel. RS4 cluster and gauges. RS4 ebrake.
    Body: RS4 hood, fenders, side skirts, European RS4 avant rear bumper, European style headlights with clear corners. Mars LED tail lights. Also of note, I have all the proper air ducting for brakes and cooling that sits behind the RS4 front bumper and connects to the underbody shield.
    Finishing details: Argon Creative should (eventually ) be sending me a front CF splitter, CF rain tray, and a full set of CF RS4 badging.
    Engine work: Redline Speed Worx, NJ
    Body work: Frank's Auto Care, Hamden CT
    Futures plans: drive it.. finally. I'll be attending as many cruises and shows on the East Coast as I can make time for.
    We'll see how she feels all tuned, but I haven't ruled out a supercharger.. if do it, I'll probably go TTS.. TBD though!
    The before shot..
    The build:
    More to come..
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Dec 07 2009
    East Coast
    Can't wait to see this thing all intact in a proper photo sesh I do like where you're heading with this thing(TTS SC) That'll make it one bad ass Avant!
    On another note, what made you go with UM tune(genuinely interested and not to start anything like some might assumelol)?
    Forget the B8, keep the V8!
    Jun 11 2013
    Quote Originally Posted by Mr.Wrong View Post
    Jeff is local to me, and I may do a custom dyno tune as apposed to a bench tune. He is also a sponsor of Avantoberfest, and a good partner in that event.
    Plus he just knows his shit, and I trust him to tune this car.
    Oct 23 2014
    Buffalo, NY
    Love what I see, and huge undertaking! Congrats on the project being near completion.
    Please tell me that's goodwood green too
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Mar 21 2011
    '06 B7/B6 RS4 JHM Stage 1+ S/C, '04 Ford Expedition, '08 Lambroghini Gallardo SL TT
    Dubai
    Is it green or black?
    Veteran Member Four Rings Chuuey's Avatar
    Mar 06 2010
    E36
    Definitely one of the longest/craziest car journeys but, the end result is incredible.
    Congrats, Dan. Your patience and perseverance is unmatched. Can't wait for your first drive!
    1998 E36 M345 T | 2017 B9 Allroad | 2002 996 GT2
    Previous:
    2001.5 B5 S4 Avant
    2009 B8 S4 6MT
    2008 B7 RS4
    1991 200 20v Avant
    2010 997 C2
    1988 E28 535is Dinan Turbo (RIP)
    2019 B9 A4
    Jun 11 2013
    Quote Originally Posted by iconic78 View Post
    It's Deep Green Metallic, aka Cambridge Green..
    It's my understanding that it was a special order option for the RS4 in Europe. Very few examples out there.
    It's got a ton of character and depth to it. It's dark green almost black in the shade, and the metal fleck really makes it pop in the sun.
    Mar 21 2011
    Dubai
    Quote Originally Posted by dsgray16 View Post
    It's Deep Green Metallic, aka Greenwich Green..
    Very true. I've seen probably 2 maybe 3 with that color. 1 in the uk and the other in Germany.
    Veteran Member Four Rings Pat_McGroin's Avatar
    May 09 2010
    Downey Ca
    So jealous man! Congrats bud! She looks amazing, I hope to see it in person one day.
    Rick
    B5 S4 StageIII
    Sold:Brilliant Black 2008 S4 Avant Tip.
    Gone but never gottin - Ibis 2010 A3 2.0T
    Jan 29 2010
    north ga
    I see you live up to your Instagram name....... @whiskeyandwagons
    Car looks great Dan. It'll be great that you can drive it again. I still remember the video of the motor blowing way back when.....and S4 motor #2 and its failure. And the year long RS swap. I really hope you'll get a bunch of seat time in it again before you send it back to the shop for more goodies yet again.
    Jun 11 2013
    Yeah I'll drive it a bunch between now and the winter.
    Jun 11 2013
    Picked it up at the body shop today.. dropped it off at Excelerate for some exhaust and suspension tweaking. Picking it up again on Friday and detailing the f*** out of it.. will be at EuroFest at Lime Rock on Saturday. Hope to see others from AZ there!
    Veteran Member Three Rings jhoward's Avatar
    Dec 13 2012
    central NY
    This is so cool to see finished! Sell it to me when you're done playing with it and ready to build another (seriously!)
    Established Member Two Rings Tony81's Avatar
    Apr 12 2015
    Denver
    What a fantastic job!! So amazing you were able to pull this off! Maybe once the RS4 makes a comeback here someone will make a B9 RS4 Avant
    Mar 21 2011
    Dubai
    Well done on the build. Not an easy task.
    Would look so much more cleaner/Euro if you did the roof rail delete option.
    Jun 11 2013
    They don't bother me and I think it's kind of part of the look of the car.. I did consider it, along with a sunroof delete. The finish came out nice though (cerakote, Tungsten finish) and I think it works with the green.
    Deactivated Four Rings
    Jun 23 2011
    I saw it yesterday in person and wow it is quite impressive. Well done.
    May 09 2010
    Downey Ca
    My oh my, she is beautiful!
    Rick
    B5 S4 StageIII
    Veteran Member Four Rings R&Cs4's Avatar
    Oct 19 2009
    Congrats man, glad I could take those Ti wheels off your hands
    Look forward to getting some shots of our RSs next to each other... lmk when you want to hit up Cars and Coffee.
    '11 S4 6MT
    '58 Auto Union 1000
    '60 Auto Union 1000 SP
    '54 Corvette
    '64 GAZ 69M
    '47 Lincoln Club Coupe
    Atlas R-Line
    IG @this_is_r0b
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Looks good Dan!
    Mar 21 2011
    Dubai
    You're running Brembo bbk's? Is that just the front? Also what's the interior?
    Jun 11 2013
    Brembo GT BBK in front. JHM BBK going in today in rear. Eventually I'd like to do brembos in the back if I can get brackets made and sort the ebrake cable issue.
    Interior is black. Recaro Sportster CS leather seats, TTRS wheel, and I have a CF RS4 weave trim set being made. I'll get RS door handles in a month or so. Otherwise, the only thing lacking inside will be the start button.
    Veteran Member Four Rings MarcusDubya77's Avatar
    Feb 08 2013
    '19 Volvo XC60, '05 Honda S2000 ITBs
    Schonaich, Germany
    Loooove it!
    18 Catalunya RS3 Unitronic Stg 2/TCU Stg 2, APR DP & Intake, CTS Intercooler, 034 MPs, ECE Dogbone (0-60-3.18 : 1/4-11.16 on 98 RON) & 05 S2000 w/ ITB setup
    Gone, but not forgotten- 19 C43 AMG / 12 Abarth (full bolt on) / 07 JHM SC'ed / 08 Evolution X (full bolt on) / 05 M3 Dinan SC'ed / 05 LGT w/ Hybrid Turbo ......and many others!
    "Bitches... Come over here and have sex with Charlie Murphy" ~ Rick James
    Mar 21 2011
    Dubai
    I have the parts you need! I'm breaking a whole Euro spec car.
    I also need a rear brembo bbk ebrake solution. Happy to trade you for the brackets.
    How do you find the fronts? I'm going for the 405mm with 6pot GT.
    Jun 11 2013
    Euro spec RS4? I'm not even sure what I would need.. likely a kit designed to allow brembos in the rear of an S4.. keep in mind I still have the ebrake cable setup and rear calipers of an S4..
    Redline Speed Worx did the brembos.. I only did a 380, but they offer more than enough stopping power.. this will never be a track car. Will have to see how the revamped rear setup changes things. Will be running EBC Redstuff pads with the JHM rotors.
    Nov 10 2014
    Apex, NC
    any interior shots? and since you had the motor apart.. did you ever think about going low compression built motor with turbo's?
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Jun 11 2013
    Quote Originally Posted by doug97gxe View Post
    I'll be detailing it tonight, so I'll post some more shots and include the interior.
    This build quickly snowballed from being a reasonable solution to a blown engine, into a complete money pit of a full swap.. just getting here took a lot work, luck, and stress.. while I haven't ruled out forced induction, nothing like that will happen till next year.
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Words alone cannot describe this awesomeness of this build. I wish you lived closer so I could see this thing in person. Well done!
    Cheers,
    Ry-man
    Senior Member Three Rings cmd4's Avatar
    Jan 09 2010
    asheville
    CONative summed it up perfect!! Perfect color too
    RS4 mugello blue,Ti-Curing the itch
    04-Cobalt Allroad 78k 6mt- Car seat duty
    b6 s4 avant blk/blk-57k 6mt Gone
    DD -03 7.3 pwrstrk 6spd 200k and counting
    85 fj 60 lt1 and nv4500..Gone
    96-993 C4S…Gone
    78-fj40-smb350…alum tub,aussie 4spd,orion t case ,detroit locked
    97-40th fj80 on 33's and arb front
    Jan 06 2008
    Dacia Sandero
    Arizona
    Awesome build and end result. congrats and enjoy !
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    Jun 11 2013
    Picked it up tonight from getting the alignment and suspension adjustments done, as well as the exhaust alignment, rear BBK instal and Grouppe M instal.. then put about 4-5 hours into washing it and detailing it. Beat!
    Dec 07 2009
    East Coast
    ^ this thing literally looks like brand spanking new and just rolled off the showroom Glad you went with this color choice hehe I can't stop drooling. And on top of it you're talking FI in the future, just insane!!! The coolest Avant on an entire forum, period.
    Veteran Member Three Rings G18's Avatar
    Feb 12 2004
    Congrats on an awesome build. Hope to see it in person at some point.
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Absolutely incredible, the color is gorgeous as well. Congrats!
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Jun 05 2012
    Aurora, OH
    Nooiiice!
    Sent from my VS986 using Tapatalk
    Jun 11 2013
    Thanks guys! Now to get the import things done like get the AC fixed! It's going to be 90 degrees again tomorrow and these bastards put off too much heat for that with just the windows down.
    Next phase will be a tune.. possibly a custom dyno tune.. still working on details. She pulls hard now, so I'm looking forward to seeing what I can get out of this motor.
    Established Member Two Rings Rubinator's Avatar
    Apr 30 2017
    12 Skateboards, 4 Snowboards, 4 Bicycles, 2019 Ford Raptor
    NW Portland, Oregon USA
    Honest to God, this is better than pornography.
    Sent from my ONEPLUS A3000 using Audizine mobile app
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    Jesus this thing is proper. Looks amazing!
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    Veteran Member Four Rings Optiondoc's Avatar
    Aug 18 2015
    You deserve an award for this. AZ Build of the year winner hands down. PS does or did your wife work for Saks corporate? I think our wifeys are friends.
    Jun 11 2013
    Quote Originally Posted by Optiondoc View Post
    Lol.. do you drive an S or RS5 and live down town?
    Yes my wife Heather works at Saks
