Howdy fellas, long time no see. I'm still around, but I've been busy with other things for the past few months.
Anyway, on my wife's Avant, the brake pad warning light is stuck on because the connector that clips onto the brake pad connector is broken. So, while I've got plenty of brake pad left, the car thinks that I don't.
Why haven't I replaced the cable that contains the brake pad clip, you ask? Well, I tried, but the little 6mm bolt that holds the ABS sensor to the spindle snapped off when I tried to remove it, and I can't get a drill in there to drill it out. I also tried an easy-out, but that didn't work, either.
So, now I'm trying to see if there's perhaps a way to disable that warning via VCDS or my Maxwell OBDII reader. Any thoughts?
