Results 1 to 12 of 12
    Veteran Member Three Rings Halfrican's Avatar
    Oct 25 2012
    United States
    'FUSE' displayed on odometer
    This has me struck. It's a 2001 A4 2.8MT for reference.
    When I turn the car on 'FUSE' is displayed on the odometer and a buzz occurs every 30 seconds or so. The car is currently in service position. The fuses appear to be fine; I even changed a couple and no luck. The instrument cluster is apparently not getting any power, no gauges are working currently. Could it be shot?
    I need some ideas.
    I hate electric ****!
    I got my first job at 16 hoping to save money...then I bought my first Audi.
    Jun 30 2008
    Erie, Pennsylvania
    I've never seen the fuse warning. Do feel free to post a picture.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear
    Oct 25 2012
    United States
    I've done a little research and haven't found too many people with the aforementioned issue. I will post a picture asap.
    Dec 05 2007
    Never heard of this issue before either. Awaiting pics myself, due to curiosity reasons.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    my 97 always had one. I just ignored it. lol.
    EH F0UR 2001 A4 1.8TqM
    = K04 | SOUTHBEND | STERN | FORGE | TREADSTONE
    = ST | MEYLEHD | FCPEURO | 034 | AWE | AKMOTORSPORT | JHM
    = HERTZ | JVC | ALPINE
    2001 A4 1.8TqM
    2002 Golf TDI
    = VNT-17 | 11mm IP | DLC1019 | COLTCAM2 | SOUTHBEND
    = RL Ultimo |
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Oct 25 2012
    United States
    Quote Originally Posted by King_ View Post
    Did any of your gauges work? That scares the hell out of me!
    Jun 30 2008
    Erie, Pennsylvania
    Volt meter appears to be pinned to maximum. Hmm.
    Oct 09 2012
    Quote Originally Posted by Halfrican View Post
    Yea everything still worked.
    2001 A4 1.8TqM
    2002 Golf TDI
    = RL Ultimo |
    @Turbo_B5
    Oct 25 2012
    United States
    Yep. I have absolutely no idea. I've done a little research and haven't had much luck. Any ideas what could cause that?
    If that was the case for me that would be fine. I'm not so much worried about my tachometer or speedometer, but I don't think I would trust driving any car with out a thermostat.
    Oct 25 2012
    United States
    This was my first Audi. I adore this thing like no other, even though it's no where near the best of shape. I just want to drive it again because it was such a fun car to drive. I'm tired of driving an automatic. I'm also having issues bleeding my power steering after replacing the pump with a junk yard pump. I think it's the cheap high pressure hose clamps I put on the supply hose to the pump. I finally have a little time and money and it will be going on this! Other than these two issues I am certain I can yank a lot more miles out of this car. It only has 135,000 miles!
    Veteran Member Four Rings crazexr7's Avatar
    Sep 10 2011
    1998.5 A4 2.8 Quattro, 1968 Cougar XR7
    Bristol, CT
    Damn that is a ton of miles
    From what I'm reading from previous posts it's a 10amp fuse (Fuse 14 (?)) for the instrument cluster. You'll have to pull it and replace it and see if that does the trick.
    https://www.audiworld.com/forums/a6-...meter-2800155/
    Oct 25 2012
    United States
    Quote Originally Posted by crazexr7 View Post
    The power of German engineering.
    Thanks a lot for the share, I will pick up another set of fuses and try my luck. I promise I searched! I didn't find anything related to the A4 model, just a bunch of posts regarding the Audi TT and Dodge Neon (lol).
