Page 27 of 27 FirstFirst ... 17252627
Results 1,041 to 1,049 of 1049
  1. #1041
    Audi Customer Experience Three Rings Audi USA's Avatar
    Mar 24 2017
    Auburn Hills, MI
    Quote Originally Posted by Hayesman View Post
    Can I please get the info on
    WAUXL68EX4A106574
    My pleasure! There were actually only 297 4.2L 6-speed quattro S4 avants produced for the 2004 model year. 72 were produced with Dolphin Gray Metallic, and only 8/72 were equipped with Dolphin Gray and the Silver interior. Hope it's still running great for you :)
    Vincenzo F.
    Audi Social Community Manager
  2. #1042
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2015 Subaru WRX 2013 Yamaha R1
    New Hampshire
    I'll join
    WAUDGAFL9EA100245
    2014 Audi S4, manual, sports dif, carbon atlas inlays
    2014 Audi S4 - 6MT - Monsoon Gray Metallic | Sports Differential | Carbon Atlas Inlays | Bang and Olufsen |
    Modifications currently in route, stay tuned
  3. #1043
    Jan 05 2019
    Audi A4
    Reno NV
    WAUKGAFL7DA113467 Please and thank you !
  4. #1044
    Aug 24 2012
    83 quattro, 99 A4 Avant LY1T, 99.5 Avant LY1B, 74 Norton Commando, 81 Kawa GPz 550 (two of them)
    Portland, OR
    Vincenzo,
    As much as I appreciate your info, your numbers are incorrect..
    You state all 11 have Onyx Leatherette interior, but my build sticker says otherwise.
    I am assuming you are assuming (arent we all assuming) that you got the Onyx Leatherette from the BR interior code, but that doesnt indicate Leatherette. My 99 WITH Leatherette has N0C/BR which would be Seat trim covers in leatherette/Onyx seats with Satin Black dash/steering wheel..
    My 99.5 with Sport Cloth Onyx seats has N5F/BR which is Seat trim covers in fabric/Onyx seats with Satin Black dash/steering wheel.
    Cant imagine many of the Brilliant yellows had Sport Cloth...
    83 urq, 84 4kq, 99 a4q avant, 99.5 a4q avant
    b2 Resource page! Links, Registry, more!
  5. #1045
    Mar 24 2017
    Auburn Hills, MI
    Quote Originally Posted by Driggs View Post
    Vincenzo,
    Hello Driggs,
    Thanks for reaching back out. You are correct I was pulling the "BR" interior code in regard to your vehicle. With the older model years the spreadsheets that I have are not as robust, in particular with the interior colors as it's difficult to differentiate. I can confirm that 11 of that specific model were produced with Brilliant Yellow but apologize for any errors related to the interior color coding. Please feel free to send me a PM if you have any other questions.
    Thank you,
    Vincenzo F.
  6. #1046
    Mar 24 2017
    Auburn Hills, MI
    Quote Originally Posted by adam044 View Post
    I'll join
    WAUDGAFL9EA100245
    Hello! So there were 1,412 3.0T quattro manual S4 sedans produced for the 2014 model year. 247 were produced with Monsoon Gray metallic, and 197 of those 247 were produced with the Monsoon Gray Metallic/Black interior combination. Regrettably I cannot dig further to differentiate between options and trim line, but I hope that this is helpful for you!
    Vincenzo F.
  7. #1047
    Mar 24 2017
    Auburn Hills, MI
    Quote Originally Posted by Dreyes3893 View Post
    Hello thanks for checking in! There were 4,729 3.0T quattro s tronic S4 sedans produced in the 2013 model year. 145 of those were produced with Misano Red Pearl Effect and only 35 of the 145 were produced with Misano Red Pearl Effect and the Black/Magma Red interior.
    Vincenzo F.
  8. #1048
    Aug 24 2012
    Portland, OR
    Quote Originally Posted by Audi USA View Post
    Hello Driggs,
    Thank you,
    Not an issue! The BR indicates interior color where the other indicates the material!
    My information on the briliant yellow avant I pieced together is the following
    8D5 515 Type
    AEB Engine
    DAJ Transmission
    DWR Transmission
    LY1B Brilliant Yellow
    N5F Seat trim covers in fabric
    BR Onyx seats with Satin Black dash/steering wheel
    E0A No special edition
    1KD Disk brakes in rear
    3FE Electric tilting and sliding glass sunroof with sun screen/sunblind
    F0A No special purpose vehicle, standard equipment
    T8B 4-cylinder SI engine 1.8 l unit 058.D
    2PV Leather-wrapped sports steering wheel
    7Q0 Without navigation device
    3L3 Manual height adjustment for front seats
    1SA Without additional front underbody guard
    J0L Battery 340 A (70 Ah)
    0L0 Mechanical throttle control
    3NZ Unsplit rear seat bench unsplit, split folding backrest
    C4X Alloy wheels 7J x 16
    4UB Airbag for NAR
    1LB Disk brakes in front
    8GB Alternator 55 A
    8BH Ellipsoidal headlamps for driving on the right, US design
    8Q0 Without headlight range adjustment
    7K0 Without direct tire pressure monitoring system
    6XD Exterior mirrors, power-adjustable/ heated
    4LA Without controls (RADIO)
    5MY Decorative inserts
    0G1 Gearshift lever
    U1D Instrument cluster w/ mph speedometer, clock, tachometer, trip odometer, add. instruments (voltage, oil temperature)
    9Q2 Multi-function display/on-board computerwith check control
    4X1 Side airbag in front
    3Y0 Without roll-up sunshade
    Q1D Sports seats in front
    5SG Left exterior mirror: flat
    1AH Electronic differential lock (EDL)
    7X0 Without park distance control
    0YS Weight range 17 installation control only, no requirement forecast
    X9A Equipment options subset for USA
    8Z6 Hot country
    2K2 Reinforced bumpers
    4K2 Radio remote controlled central locking "SZV"
    5RW Right exterior mirror: convex (US) large viewing field
    1BE Sports suspension/shock absorption
    4R3 Power windows with comfort operation
    0JF Weight category front axle weight range 6
    M98 4-cylinder SI engine 1.8 l/110 kW (20V) turbo base engine is T8B/T8C
    6R2 Leather gearshift boot
    5D2 Carrier frequency 315 MHz
    4GP Windshield in heat-insulating glass withsunshield and viewing window for vehicle identification number
  9. #1049
    Oct 31 2014
    New Hampshire
    Way more manuals than I thought! I guess people just donít sell them because you canít find them anywhere. Thanks!
