Hmm those are good suggestions, not sure what your oilchange interval is set to but if you have vag com set it to 5k and not 10k, that will make it so your changing the oil more often especially considering it's a turbo car as the turbo cooks the oil. Make sure to cool off the turbo after any hard driving (some easy low rpm driving and idling before shutting the car off) don't excessively idle it when it's cold but also don't just turn it on and go, start the car, wait for the engine to calm down on its own then go. It doesn't do this in winter so 30seconds to a minute is a worthy amount to warm it up but don't idle it for five minutes (this is in regards to any car) as it will lead to cylinder scoring and flooding the oil with gas.
If you wanna go hardcore, cut the balance shafts in the oil pump, get a fluidampr and if you can pull the crank and have it balanced. It's the balance shafts failing which seizes most of the engines on here. Don't be redlining the thing and as a good basis don't take it over 5k (the balance shafts spin at double crank speed so redline, 7k, is 14k on the balance shafts which have non replaceable bearings/journals whatever)
Don't fall behind on maintenance, trust me, very quickly it will get out of hand and you will spend twice as much as the car is worth
Has the timing belt been done? Do it now if it hasn't.
Just take car of her, baby her and it'll take care of you.
Oh and do the carbon cleanings, you can live without it but you really shouldn't as it can excessively wear the valves because dust is always stuck to them sanding them down
There are many 200k+ vehicles on here that have been tuned since 50k and are beaten on regularly as well though and they last just fine. But it comes down to the owners and how much they obsess over maintaining the car.
Sent from my iPhone using
Audizine
