Results 1 to 11 of 11
Hybrid View
    Nov 03 2011
    All Over!
    Coding C5 RS6 ECU For Manual
    Hey guys!
    Yes, I'm aware this is the B6 section. But, I've found there's more chance of a response, or sharing of ideas here, rather than in the C5 section.
    I'm looking into ways of getting my C5 RS6 ECU (which will be going into my B6) coded for manual, or find a way of keeping the TCU inputs in place, to keep the ECU happy. I would rather it was done properly, though, otherwise cruise may not work, same with ABS and ESP.
    Are there any maps that exist, that would keep things working as they should? Bische, and others who are into software, it'll be great to hear from you.
    Thanks in advance.
    1986 Type 85 Audi 90 quattro
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    One idea may be to try the C5 owners group on facebook. There are a few guys there who have swapped an 01E into their RS6s
    2016 S3
    Instagram- @Thisisastickup
    Nov 03 2011
    All Over!
    Quote Originally Posted by b6Hate4 View Post
    Thanks bud!
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    or another option is to add the tables for boost control to the c5 a6 4.2 ecu if its possible to add the input for the map as well.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Nov 03 2011
    All Over!
    Quote Originally Posted by blitz2190 View Post
    I thought of this with a C5 S6 ECU, which can be coded for manual. The issue would be the N/A V8 ECU's have either a dual or three-stage intake. The RS6 has a single-stage intake. You'll need to add not just the MAP sensor, but also the drivers for the dual EGT's, and hope the EEPROM will be compatible, and there's continuity between the tracks, directly or via resistors / diodes.
    The RS6 ECU also controls two independent MAF's.
    Complicated.
    Feb 26 2008
    washington
    Reach out to Jason @ AMD. He has the manual transmission RS6 stuff down.
    Nov 03 2011
    All Over!
    Quote Originally Posted by audisean1 View Post
    Please tell me more! How do I get in contact with Jason?
    Oct 29 2005
    10speed
    San Francisco, CA
    From what I heard he's actually the only one to figure out the coding
    - Clint
    Jan 09 2012
    MA
    Jan 24 2010
    Paramus,NJ USA
    Its not as simple as changing the coding.You need to contact SteveKen he has the answers you need!!
    Long story short the TCU needs to be disconnected and disabled in the canbus via the cluster
    Your best bet is to have an S6 ABS controller installed and correctly soft coded for a manual
    and have the current RS6 ECU soft coded to a manual.
    You will still get faults on the ABS and ECU:
    ECU - Missing message from TCM.You will need custom software for this.You need to take out all the automatic software portion of the ecm flash and erase or replace with manual software for whatever trans you are using.Also in addition to that you will have the following issue with the ABS it will throw a fault stating Controller incorrectly coded.This is because the ECU needs to have software changes also to accept the s6 abs unit you installed.I dont think there is another way around it.However Steve will be able to tell you all about it.I believe he was successful,but ended up selling the part before completion.Best of luck.
    Only other way I can see this working is by coding out the DTC flags in the ECU.So even if the faults set it wount affect anything.Thats one way of doing it.
    Ziddy Autowerks
    Nov 03 2011
    All Over!
    Thanks, EuroxS4. 👍
