Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 581
  1. #81
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    Damn this is surprising to see from Audi, sure hope the rs3 has a different unit since its making more power.
  2. #82
    Oct 30 2016
    Sacramento, CA
    This isn't reassuring to know Haldex has issues. Anyway for Audi to know without having to have to test drive? Can't they check the ECU history?
  3. #83
    May 10 2017
    Lewisberry PA
    Quote Originally Posted by brad65ford View Post
    i would like to know this as well...
    2017 Ara Blue RS3
  4. #84
    Feb 16 2004
    Bay Area
    Quote Originally Posted by Seinsmeld13 View Post
    My 2016 S3 has been out the road since early spring. It's parked while I drive my Porsche during the warmer months. My problem occurred during a very light snow fall. As I was entering the highway I got stuck in a few inches of snow. My front wheels were spinning with no reaction from the rears. I eventually took the car into my dealer. When I did there was no snow on the ground. They were unable to reenact what I had reported and therefore could not find a problem. I was told to return when there was snow on the ground for a further review. The season ended with no further snow. Therefore I am going into this winter season with a faulty car. Can they check this Haldex without slippery conditions? Send me a private message if you can assist me. Thanks.
    A faulty system will generate a code. You could also just engage Launch Control and light up the tires in their parking lot.
    Unbeknowst to Speed, Racer-X is actually his older brother who ran away from home years ago...
  5. #85
    Veteran Member Four Rings Seinsmeld13's Avatar
    Mar 23 2009
    2020 Porsche Spyder
    Niagara Region, Canada
    Ladies & men, my car is 100% stock as my car is under warranty. Hopefully when I place the car back on the road my local dealer will be able to repair the car. Thanks for all your kind replies.
    2018 RS5 2020 SLC 300
    Weekend and summer drive 2020 Porsche Cayman Spyder
  6. #86
    Aug 09 2017
    Guelph, Ontario
    Hey guys,
    So 2 weeks ago i went eurodyne stage 1.5 ecu / DSG tune, took my car out for a test drive and launched it a few times only to find myself peeling the tires like crazy through 4 gears. yes 4 gears.
    went stage 2 this week with a CTS down pipe and took the car to the track, and same thing, couldn't get traction to save my life.
    at this point I'm assuming the is a Haldex issue.
    the car has 70,000 km on it.
    Stage 2 tune / deg software.
    2015 model.
    no error codes displayed on dash however i haven't looking with my software or any other method of scanning.
    have to call the dealership monday, but not sure how to go about explaining this to them.
    what have you guys said in the past to get them to warranty the problem when you have no error codes?
    Thanks.
  7. #87
    Aug 09 2017
    Guelph, Ontario
    man reading through these threads this seems like it should be a recall at this point
  8. #88
    Jan 27 2017
    Tennessee
    Has anyone noticed a humming noise from the rear before their failure during lift off deceleration (no brake) around 45-50mph? I haven't checked for stored codes yet, but something isn't right...
  9. #89
    May 10 2017
    Lewisberry PA
    Anyone with an RS3 happen to note what revision is on the RS3s?
    2017 Ara Blue RS3
  10. #90
    Oct 30 2012
    Arizona
    Quote Originally Posted by A20V200 View Post
    So the car was "acting weird" so I decided to use my OBD11 and this popped up!! What are people doing when they go back to the dealership after being TCU tuned? Flash ECU and TCU back to stock and put the stock air box back on and hope for the best or what?
    No dash lights or traction control lights...just a little squirmy going around some round a bouts and accelerating out of them.
    And if the dealer tries to "stick it to me"...you know, because your car isn't stock and is modified and has X and Y....? Anybody have a cost of repairs?
    Car has 21,000 miles on it now....this issue happened in the last week.
    Update: After going back to my tuner shop, flashed back to stock ECU and TCU, I then went to the dealer and they could not replicate the faults since it was wiped clean after the flash.
    Flashed back to stage 2 and stage 3 TCU and the faults occured almost immediately. I drove it for about 2 months and getting on it every so often to get the clutch pump or entire Haldex to fail completely and not just intermittently....Then the Haldex TSB came out and I contacted the dealer to see about getting my car in to get fixed. They still need the error codes to replace or repair. I think to myself, no worries, flash back to stock and launch control it to throw codes...
    The funny thing is, I drove "normally" for about 2 weeks prior to calling the dealer, now the Haldex is operating just fine...I hooked up my OBDeleven and no codes at all...! WTF....self healing Haldex? Was there some debris in the pump? Puzzled...I can launch it and get on it and it hooks up just fine. No slipping or loss of power..NOTHING!!
    WEIRD
  11. #91
    Veteran Member Three Rings shivaswrath's Avatar
    Sep 21 2017
    NJ/CT
    Quote Originally Posted by nesbit View Post
    Must be a different unit..
    2017 RS3 | Xpel in the front & Feynlabs all around | WINCOS IR 30% F and 20% R | 245/35-19 Pirelli Sottozero Serie II for winters | I'm not modding this super amazing car so I'm going to list stupid $hit like RS3 All season mats and Blendmount for Escort Max
  12. #92
    Feb 16 2004
    Bay Area
    Quote Originally Posted by shivaswrath View Post
    It has been confirmed that it has a larger rear pumpkin, but no confirmation as to whether or not the Haldex unit, or even simply the pump is the same or not.
  13. #93
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    What fluid are folks using for a Haldex fluid change?
    2016 Monsoon S3
    My slow build link - Onequick4door
  14. #94
    Junior Member One Ring
    Sep 08 2015
    What TSB # is this? I'm having the same problem and would like to go in as prepared as possible. 2016 S3, 29k miles, FWIW.
  15. #95
    Mar 23 2009
    2020 Porsche Spyder
    My S3 has been off the road since mid March while I drive my summer car. My fault has not been repaired by Audi as they were unable to reenact the poor traction I reported in the snow. Is there an automatic Haldex repair?
  16. #96
    Oct 30 2012
    Arizona
    Quote Originally Posted by SirScott View Post
    There is a TSB out for faulty clutch pumps and or the entire Haldex unit. Call your service advisor and report your issue and tell him your aware of the TSB and they will test it out.
  17. #97
    Nov 13 2009
    the OC, SOCAL
    is the tsb for all 8v s3's?
    i have a 2015 s3 and was not told about any tsb. is it where it would only come up if there was proven issues like a cel?
  18. #98
    Veteran Member Four Rings bmc333's Avatar
    Feb 12 2009
    NoVA
    1. In the rain, FWD slipping
    2. 26K
    3. 2015
    4. Any error codes - nothing specific to the haldex
    5. Awaiting appointment/diagnosis from NGP
    2015 S3 - Panther Black P+ / LED Lights / B&O / APR Stage 1 ECU & TCU / APR Turbo Muffler delete / CTS Turbo Inlet/Discharge/Intercooler Pipes / X34 Intake / Superpro end links / VWR springs / 35% Tint / ED CF rear diffuser / 034 CF engine & fuse box covers / ECS CF battery cover / BBS SR's
  19. #99
    Feb 12 2016
    La
    Quote Originally Posted by Dc779a View Post
    They replaced the pump, changed the fluid, drain plug and had a "replacement kit" which they said was to for the pump and motor replacement. I will try to get the invoice and part numbers when I get a chance
    Do you have a copy of the invoice?
  20. #100
    Feb 12 2016
    La
    Anyone have the TSB #?
  21. #101
    Oct 30 2012
    Arizona
    AFAIK..the TSB is on the "downlow" at the dealership....they are not telling/sending out any info on it, unless yours is faulty and you ask them about it and have the appropriate codes for them repair the pump or haldex. I had my car flashed back to "stock" wiping the codes out, but they did the output tests on it and it passed and threw no fault codes. I showed them my OBDII screen shot, but that wasn't enough to prompt them to fix anything because the ECU did not have a stored fault code and they "could not recreate it during their testing".
  22. #102
    Jul 11 2011
    2021 Ford F-150 Lariat PowerBoost
    I'm having this issue too it looks like. Bone stock but a spirited driver.
    This morning pulling into traffic under full throttle I smoked the front right for about 100 feet.
    [Edit] Confirmed this weekend with launch control. Car barely moved as one wheel spun furiously. It was pretty hilarious.
    2022 /SQ7 P+ | Daytona Grey Metallic | Executive Pack | Carbon Inlays | Driver Assistance | EA825 4.0T (IYKYK)
    APR Stage 1 685+ HP (Planned)
    Gone But Not Forgotten
    C7.5 S6 - Moonlight Blue
    8V S3 - Nogaro Blue
    B8 S4 - Ibis White
    2008 V10 TDI Touareg II - Floret Silver
    2006 V10 TDI Touareg - Reed Green
  23. #103
    Jul 11 2011
    UPDATE
    Car is in the shop currently getting the rear differential replaced. I was able to replicate the problem for the dealership, they scanned and found 2 faults related to the AWD system.
    1. How you discovered you had the issue - Consistent wheelspin from front wheels only. Bad torque steer
    2. Mileage - 19,XXX miles
    3. Model year - 2016
    4. Any error codes - None apparent on the dash, 2 faults found when scanned
    5. What was done to fix it, and was it under warranty? - Fixing under warranty by replacing rear differential (contains haldex clutch pack that engages rear axle). EDIT: 1/5/18 My car was in the shop for 2 months waiting for the correct diff.
    8V S3 - Nogaro Blue
    B8 S4 - Ibis White
  24. #104
    Mar 23 2009
    2020 Porsche Spyder
    My car has been to two different Audi dealers with the most recent being November 11th. I have been told by both dealers that there is no recall for my car for any issue which of course includes the Haldex. I have been told to return my car when there is snow on the ground to see if they can reenact my reported issue with the AWD. Can anybody help me with this traction issue or give me a recommendation? Thanks in advance.
  25. #105
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    Did you NOT take my advice from Vortex?!?!?!
    get yourself a gopro or some camera with a slo mo app and get out there!!!!!
  26. #106
    Sep 08 2015
    tl;dr: By replacing the haldex pump, 0CQ-598-549, my car is now fixed. TSB# is 2043144/3
    Here's what it looked like when broken: https://www.youtube.com/watch?v=D4IEBYcOecE
    The invoice for the repair.
    *Edit: 29k miles on the car when fixed. Probably 27k was when it started to break. The traction became gradually worse, it's not like it suddenly stopped working overnight.
  27. #107
    Nov 01 2017
    San Diego
    Long time lurker first time posting
    Recently had this fixed.
    1. How you discovered you had the issue - Wheelspin on hard pulls even in second and third gear.
    2. Mileage - 26,XXX miles
    3. Model year - 2015
    4. Any error codes - None on dash. Dealer paperwork showed tech found stored fault code
    5. What was done to fix it, and was it under warranty? - AWD and Final Drive W. Clutch removed and replaced under warranty.
    Notes show that when tech lifted vehicle and spun wheel the AWD system was engaging and all of the wheels would spin. Then they checked the fluid condition and found the oil had clutch material in it and proceeded to replace clutch unit. I waited a bit to launch to get the new clutch a little time to break in and everything is back to normal now.
  28. #108
    Jan 29 2016
    FJ Cruiser
    N Tex
    Just came across this thread. I have a 2016 S3 and so far no problems, i have done multiple launches(15 or so launch control) but I only have 8500 miles. I looked at my Haldex and it has a “G” stamp so not the F or K. Has anyone had any issue with this version?
  29. #109
    Veteran Member Four Rings kjeeper10's Avatar
    Dec 07 2017
    2007 Jeep Wrangler JK
    Hmm looking at a 2015, how common is this ?
    2007 Audi A6 3.2 daily, 2007 Jeep Wrangler Rubicon 3.5” lift 37’s moderately modified.
    2015 Daytona S5 - Madico Ceramic Tint 35/20 - 6 Speed - Mods - Sprintbooster V3 - APR Stage II - Dual Pulley - CPS Cooler - Eurocode ST Shifter - EuroImpulse weighted knob - USP SS Clutch Line - 034 SD Engine Mounts - 034 Trans Mount Insert - 034 rear SB - CR-15 - ORT Coilovers - SPC Front CA’s - IE Non Res Downpipes - AWE touring w/ 102 tips - CTS intake - ECS Streat Shield - Deval CF Splwitter/Rear Valance - Signature SV901 Forged 19x10.5 wheels - 275/35 Mich PS4S Tires.
  30. #110
    Established Member Two Rings maskari_gti's Avatar
    May 27 2017
    Oman/UK
    1. How you discovered you had the issue?
    I launched the car and took a slow-mo video and it’s so obvious.
    2. Mileage
    55,000 KM
    3. Model year
    2016
    4. Any error codes
    No, nothing at all.
    Took it to the dealer and they are blaming the tires! Waiting for a more technical explanation this week.
  31. #111
    Jan 29 2016
    FJ Cruiser
    N Tex
    Quote Originally Posted by maskari_gti View Post
    2. Mileage
    55,000 KM
    3. Model year
    2016
    4. Any error codes
    No, nothing at all.
    Were you able to look at what letter your rear diff has stamped on it?
  32. #112
    May 27 2017
    Oman/UK
    Quote Originally Posted by TWS3 View Post
    I couldn’t check that as I don’t have a lift or a jack to do so. I’m not that slim to fit under either.
    It was so obvious in the video that the rear wheels are been dragged by momentum nothing more. Yet the technician kept saying that it might be the tires. I didn’t want to argue much as there’s no point in doing so. So I booked an appointment for Tuesday to get a thorough look into the Haldex.
    https://youtu.be/vAZyeIX4dZA
  33. #113
    Jan 07 2018
    99 Isuzu Rodeo
    Detroit, MI
    Another A3 with a failed haldex system.
    1. Exceedingly poor traction in snow and other slippery conditions. Also, took some videos to see if there was any power going to the rear.
    2. 35k miles
    3. 2015
    4. No codes pertaining to powertrain or the Haldex system specifically.
    5. Awaiting appointment for local Audi Dealer. EDIT 1: Dealer is ordering in a new clutch pump. See later post for link to Repair Order.
    I am experiencing the same thing. As a new Audi owner of about 8 months, I've loved the car. I never really launched it but the acceleration was always there. In the snow, things have been very lackluster. I was expecting better performance than my Isuzu Rodeo beater but the Rodeo handles the snow better.
    Now after reading all of this and re-watching the videos I've taken, I think that the Haldex system just out right isn't working. I will post two links. The first is a snowy acceleration with TCS on and the second, TCS off.
    https://youtu.be/RtYsS3oZfEM
    https://youtu.be/reIzxQv2wTU
    Do you guys think this is proof enough for a dealership?
    Thanks in advance and I'm diggin' the four ring circus thus far. (Sans haldex....)
  34. #114
    Active Member Two Rings JahmanS3's Avatar
    Nov 17 2017
    Philadelphia, PA
    Quote Originally Posted by GreyA3 View Post
    2. 35k miles
    3. 2015
    I agree, looks like haldex is not working at all. i would definitely have the dealer look into that. have you looked to see what version of haldex your car has? what letter is stamped on the unit?
  35. #115
    Jan 07 2018
    99 Isuzu Rodeo
    Detroit, MI
    Thanks for the reply.
    We have an appointment for Friday.
    I haven't gotten under it as it's winter and no garage :(
    I'll keep this updated though
    Sent from my LG-H871 using Audizine mobile app
  36. #116
    Jan 11 2018
    Pleasanton, CA
    I have no problems with my 2016 @ 8k but...
    Could the repair be as simple as replacing this part? https://www.ecstuning.com/b-genuine-...kit/0cq598549/
    That would be far cheaper than I was fearing. I was convinced not to mod after reading about these problems.
    If the repair is under $300, that's more in line with a VTEC solenoid on my old Integra, or Timing chain tensioner on my old S2k.
  37. #117
    Jan 29 2016
    FJ Cruiser
    N Tex
    Quote Originally Posted by two_tired View Post
    That looks like a reasonable fix if you're out of warrenty...good find!
  38. #118
    Jan 07 2018
    99 Isuzu Rodeo
    Detroit, MI
    This maybe a silly question but I'll shoot.
    Does Audi charge any inspection fees for warranty covered vehicles?
    I wouldn't think so but I'd like to not get blindsided with 100+ bill atm.
  39. #119
    May 27 2017
    Oman/UK
    So after showing the dealers the video and trying to convince them that the rear tires are being dragged and no power at all, they still believe that his behavior is normal!! They asked me to drive for few days and come back to them.
    They changed the haldex oil and were happy to give me the car back!
    I'm going back again on Sunday and this time to get some something more convincing.
  40. #120
    Apr 12 2016
    North America
    This is very common.
    I started noticing slipping and wheel hopping at around 20000 km. Had the haldex pump replaced (took the dealer 1 min to scan and they found the fault) and it has been going strong ever since (now at over 55000 km). No more slipping or hopping.
