Page 15 of 15 FirstFirst ... 5131415
Results 561 to 581 of 581
  1. #561
    Established Member Two Rings wack0's Avatar
    Dec 12 2005
    Buffalo
    Quote Originally Posted by ReggieNoble View Post
    Needing a new diff all depends on how the pump goes. If it explodes, then it will send metal all throughout the diff and it will get in between the clutches and they will slip even with a new pump. If it just seized, more than likely you can put a new pump in and be fine.
    I replaced the pump. The old pump also looked fine, so it's a mystery
  2. #562
    Dec 25 2004
    Earth
    I call BS!
    The gen 5 Haldex is totally separate from the rest of the rear diff.
    #8
    The haldex can be completly removed from the rear diff. Its "sealed" off from the rear diff! Uses a totally different oil!
    The haldex motor will not explode... It will shut off via the controller.
    The haldex motor sit "outside" the haldex!
    Drama
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
  3. #563
    Dec 12 2005
    Buffalo
    I think im going to try to replace the clutch pack as seen above
  4. #564
    Veteran Member Four Rings ReggieNoble's Avatar
    Dec 17 2016
    B5 S4 Avant
    Fl
    Quote Originally Posted by wack0 View Post
    Have you tried replacing the pump yet?
  5. #565
    Dec 12 2005
    Buffalo
    Yeah replaced pump and did adaptation about a billion times
  6. #566
    Feb 19 2023
    Elliottsburg, PA
    Did you hear the pump running? Did you have your hood open? The adaptation didn't work for me until I had the hood up
    Sent from my motorola edge 5G UW (2021) using Tapatalk
  7. #567
    Dec 12 2005
    Buffalo
    Quote Originally Posted by okie21 View Post
    interesting, ill try this hood trick!
  8. #568
    Junior Member Two Rings
    Jun 13 2021
    World
    Hey guys, I am having issues now with my AWD. I have a 2016 Audi S3 and after doing a launch, the car right from the beginning of the launch, started to make a very loud banging sound/noise in the rear.
    When scanning the car with VCDS, I get the C111307 code.
    I have checked the CV joints and they are good. When I disable the haldex using the burnout box, the banging noise is almost gone!
    I recorded the below videos for reference:
    https://youtube.com/shorts/c9e31_SN5qY
    https://youtube.com/shorts/JSvbFQVhU4w
    https://youtube.com/shorts/-g4SYpjJXfU
    Are clutches able to make this sound when they are broken?
    Do I need a new diff?
  9. #569
    Jun 13 2021
    World
    Quote Originally Posted by MikTip View Post
    Well...if you simply would have googled the code C111307...called a Diagnostic Trouble Code(DTC) tells whats wrong...
    C111307 – Mechanical Malfunction – Passive / Sporadic (typically blocked pump, clean out and relearn or transfer box)
    https://www.haldexrepairs.co.uk/gene...-repair-guide/
    Whats key is stop abusing the haldex until its fixed...unless you feel like wasting money.
    I googled the code and I am currently waiting for the diff and haldex oil to be delivered so I can change that and test again.
    The main reason that I asked here was to check if anyone had this before since I didn't find anyone with the same banging noise in the rear like I am having.
    This sound is permanent unless I disable the haldex like I mentioned in my first post.
  10. #570
    Jun 13 2021
    World
    What is the mysterious vehicle with the banging rear diff?
    A3?
    S3?
    RS3?
    Year?
    Mods?
    Here's some food for thought:
    From my first post: "I have a 2016 Audi S3 and after doing a launch....."
    The car is stage3 (Vortex XL) on e85
  11. #571
    Dec 25 2004
    Earth
    Quote Originally Posted by n0ferz View Post
    So Stage 3...how many HP over stock?
    According to Iroz the "stock" haldex only holds 240nm...
  12. #572
    Jun 13 2021
    World
    Car made 480whp and 404tq
  13. #573
    Dec 12 2005
    Buffalo
    Just to update this thread - I replaced the Haldex pump and clutch pack before I realized the bevel box was toast. Replaced that with a used unit today, AWD works great now! Check the bevel box first!
  14. #574
    Jun 13 2021
    World
    Where did you get the clutch pack from?
  15. #575
    Dec 12 2005
    Buffalo
    Picked them up from this site: https://www.4x4parte.com/en/d/sada-l...raciu-1000072/
    Took about 2 weeks to arrive
  16. #576
    Jun 13 2021
    World
    Thanks for the information. I just bought a used diff and will wait until I get it to change it, I believe my issue is with the rear diff since I have a very noticeable banging noise when I drive the car.
  17. #577
    Dec 14 2021
    ANY TIME YOU SERVICE OR DISCONNECT THE TRASMISSION OR TRANSMISSION FLUID IN ANY WAY YOU MUST PRIME THE HALDEX*MP 2-3 TIMES. THIS IS 99% OF THIS THREADS FIX OTHER THAN THOSE WITH PHYSICAL MECHANICAL FAILURES.
    ALSO ENSURE YOU ARE FOLLOWING THE PROPER LAUNCH CONTROL METHOD.
    1) YOU MUST BE IN ANY MODE OTHER THAN DYNAMIC
    2) HOLD "ESC OFF" BUTTON FOR ABOUT 5 SECONDS TO TURN IT FULLY OFF
    3) SWITCH TO DYNAMIC MODE
    4) HOLD BRAKE AND THROTTLE TO LAUNCH
    If you launch switch to dynamic first, or are already in dynamic when turning off the esc/esp fully, you will spin and technically you have not engaged "launch control"
    TL;DR Make sure your HALDEX* pump is primed & launch correctly
  18. #578
    Dec 17 2016
    B5 S4 Avant
    Fl
    Quote Originally Posted by S3DAN View Post
    ANY TIME YOU SERVICE OR DISCONNECT THE TRASMISSION OR TRANSMISSION FLUID IN ANY WAY YOU MUST PRIME THE DSG PUMP 2-3 TIMES. THIS IS 99% OF THIS THREADS FIX OTHER THAN THOSE WITH PHYSICAL MECHANICAL FAILURES.
    TL;DR Make sure your DSG pump is primed & launch correctly
    The issues they are talking about in this thread is with the haldex pump, not the dsg pump
  19. #579
    Jun 13 2021
    World
    Exactly. Something is broken inside my rear diff for sure, I will tear it down when I get the used one that I bought to find out what’s happening in there
  20. #580
    Jun 13 2021
    World
    Hey I saw your post in the email but I guess it was removed? Anyways, I bought an used rear diff already so I will let you know when I install it if the issue is gone or if I still need to spend more cash lol
  21. #581
    Dec 25 2004
    Earth
    This post is confusing as fuck!
    Whats the transmission have to do with the Haldex? DSG is up front connected to the engine...Haldex in the rear connected to the rear diff...
    Haldex has its own separate electronic controller...
    YOU MUST PRIME THE HALDEX*MP 2-3 TIMES Never heard this...
    The Haldex pump only needs to be primed if it was changed...removed or have an issue with it...
    So cycling the electrics/electronic(haldex pump) fixs other than mechanical failures...Amazing!
