I ran into another problem with the inboard eccentrics on the tie rods. They are 10mm longer than the other bolts I had, but not quite long enough for the aluminum subframe. It's a shame because that's the part number associated with the RS6. The original bolt was superseded to this one, and it's short. I'm going to blue loctite this and fill the nut with Anti-sieze to try and prevent corrosion. No going back now
Next up was the passenger front brakes. The stock line twisted off the caliper hose, and this run had considerably less straight ends to work with. I got just enough room and a good bubble flare, so it should hold up. Front brakes were also installed, but there's no pictures of that.
I tackled the fuel filter as I was simultaneously painting the caliper shields. This job was MESSY because of the Fluid Film I sprayed. It also seems to be slowly eating away at the rubber because my hands were BLACK. Here's the old filter out
Old line vs new line
New filter mounted with a Oetiker clamps on the 90° bend.
90 close up. These washers were fantastic, and I'll probably never use another type of washer if I can help it
Final act of the day before rain was putting the rear calipers together. Slide pins got silicon grease (I use this on everything brake related
Healthy dollop, and twisting as it went in. Always make sure that your slide pins fully seat, or you'll have problems
I enjoy the contrast. I was originally going to do Red calipers and silver brackets, like on my 96 A4. The problem with a grey car is there's too much grey already lol.
If it rains tomorrow I can spend that time under the car putting the driveshaft back on the transmission, and then running air lines under the protective trays for the fuel/brake lines. I still haven't figured out where the stock lines run to in the front of the car. They're probably inaccessible without removing half of the fuse blocks and panels underneath
Sent from my Power Armor 18T using Tapatalk
