Page 1 of 4 123 ... LastLast
Results 1 to 40 of 121
Thread: my allroad
    Oct 01 2024
    lansdale, pa
    my allroad
    hey i am new here I recently purchased a stage 3 allroad . The car was actually built by my dad luckily, but it was sold to his apprentice which is who i bought it from. just wanted to share the car and say hello, i will definitely be active in these threads. Trying to figure out how to post pictures
    Oct 01 2024
    lansdale, pa
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Congratulations on bringing her back home and on an awesome car. I feel like Audizine’s C5 section is alive and well these days, but it sounds like you/Dad probably know a good amount.
    Tell us a little about what’s been done to it. Do you have any future plans for it?
    Oct 01 2024
    lansdale, pa
    Thanks. Weird buying the car I used to sit in as a kid. It is a 2002 Allroad 2.7t originally with the Tiptronic. My dad had a couple of b5s before so he knew his ways and after he tuned it or put the turbos, I would have to ask, he wanted to try to keep it auto so he left the trans in it. My dad, sister and I were on the way home when the trans blew up typical tiptronic, so we had to reverse all the way home. After that he swapped a 6 speed into the car. As far as whats done to it
    Frankenturbo f21
    jfonz tune 93 & e85
    devilsown meth injection
    custom side mount intercoolers
    bi pipes
    downpipes (have to get brands of many things so long ago my dad doesn't remember)
    xs power exhaust
    bailey motorsports diverter valves
    upgraded injectors for e
    upgraded fuel pump for e
    car is 402d
    I'm forgetting a lot but that's majors
    When I got the car I did some small personal touches such as
    Previous owner put in touchscreen sony carplay radio
    I wired subs
    TInted tails
    carbon style fin antenna
    034 TBB
    front/rear dashcam
    I don't plan on doing anything crazy with the car as it is my daily. It has a tune for e85 but hasn't been run yet, I want to change the plugs and coils and try that out. Fender flares are the worst part, they are starting to fade, I don't know if I should just repaint or color match to the body... I have nicer wheels that came with it that need to be straightened and welded as well as tires. Definitely going to be doing a ton of odds and ends such as lug studs, maybe some rs4 parts even though they are $$$, 2.0T coils, DTS, have to check what my dad did as far as diff, trans, engine mount. I want the carbon rs4 engine covers or just carbon ones, maybe ill try to make them. Headliner is saggin in the back
    Oct 01 2024
    lansdale, pa
    i saw on your thread you had an issue with shutting the passenger side door, my ar has the same issue wondering how you fixed it?
    Oct 01 2024
    lansdale, pa
    wheels are soon to come
    Feb 05 2007
    Portland, OR
    Quote Originally Posted by allroadc5 View Post
    I haven’t. What I understand is that the grease mostly solidifies in these C5’s over the years and bouncing off the striker is the main symptom. Some have pulled a door lock mechanism apart, cleaned them out, and replaced the grease, but I think I’ll eventually swap it out with a URO brand one and call it a day.
    Feb 05 2007
    Portland, OR
    Dang man, that thing looks like it’s been rode hard and put away wet! You gonna save those?
    Oct 01 2024
    lansdale, pa
    Ok thanks. I’m going to look into it shortly. Mine usually just shuts if you pull it lightly, but for some reason nobody does.
    Oct 01 2024
    lansdale, pa
    They are rode to shit, my dad got them for the car when he had it a while ago and they were on it with the previous owner and he must have hit a massive pothole. Just had it straightened and welded, and restored mostly 1/4 rims. Not bad since i got them for free. They look nice imo
    Feb 05 2007
    Portland, OR
    Gotcha, makes sense. I really like that style of wheel, too.
    Oct 01 2024
    lansdale, pa
    hey little update did some minor things, i have 3 of the wheels finished and boy are they a bitch to sand. I just installed new headlight switch cover and knob. really thought this was going to be a quick install but i guess i should have researched it before i bought. cover comes off easy enough but the knob has clips on the inside holding it on which i didn’t know until i looked it up. i ended up dremeling around the old knob to access the clips but they still would unhook. saw another video where a guy just used pliers and pulled the knob right out. should have just done it in the first place as the knob popped right out. hope this helps someone trying to do it as it may seem harder than it looks in the videos.
    Oct 01 2024
    lansdale, pa
    someone near me is selling some allroad parts. the one that caught my eye is the hotchkins sway bars. i’ve been looking for a used pair and he is close to me, one needs rebuilt and painted. He’s asking $300 for both and won’t only sell rear. I’ve heard just putting rear only is best. Let me know what you guys think they are worth.
    Jun 19 2011
    someone near me is selling some allroad parts...
    Please let me know if he has a black/dark gray cargo cover. Thank you!
    -Jeff
    current: '02 S6 Avant, light silver metallic/ebony, 6-speed w/JHM solid short throw shifter, B7 RS4 clutch & lightweight flywheel, ST coilovers
    previous: '99 A4 1.8Tqms, aluminum silver metallic/onyx
    Oct 01 2024
    lansdale, pa
    my allroad
    just engine parts pretty much…
    dk if i should just buy the rear sway bar later for 250 or take his and try to restore
    Oct 01 2024
    lansdale, pa
    FINALLY got the new shoes on. They look great and 245s ride way better so far than the 225s that were on it. When it’s aired out it’s pretty much tucking up front.
    Oct 01 2024
    lansdale, pa
    headliner/flares painted/bumpers painted/headlights at some point
    and i need to transfer the tune file to the flasher for e85 when i want
    Oct 01 2024
    lansdale, pa
    got around to doing the plugs today, wasn’t too bad besides the coil boots getting stuck in two of the cylinders and the obvious maneuvering of the front coil packs to somehow bend them out. but got it done with and car seems to rev up quicker and overall sounds healthier. these plugs were gummed up for sure who knows how long they have been in since previous owner never installed plugs.
    Oct 01 2024
    lansdale, pa
    she is ready to rip soon
    Oct 01 2024
    lansdale, pa
    got the headlights done yesterday, they look brand new. i did 600/800/1500/2500/3000grit wet sand and 3 coats clear.
    need to get better pics
    this was before
    Feb 05 2007
    Portland, OR
    Very nice! What kind of clear did you use?
    Oct 01 2024
    lansdale, pa
    I used duplicolor gloss clear coat, I found that the headlights didn’t look right unless you apply the clear coat pretty close but you have to be careful not to make runs. Turned out awesome.
    better pics
    Oct 01 2024
    lansdale, pa
    battery almost took a shit on me today, didn’t realize it was a ticking time bomb. i think i got the final juice out of it when i went to get the new battery. it ended up being from 2017. anyone have holdowns or does the battery just sit in there like mine?
    May 20 2010
    Should be a small hold down bracket that bolts in from the passenger side of the battery.
    That said, I completely understand that feeling. Back in 2019 or 2020, I had to get a new battery for my Allroad, and literally as I was driving back from the dealer (good parts deal on the battery), the car was randomly shutting off and turning itself back on. Nerve-racking but made it back and didn't do it again after the battery swapped.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Oct 01 2024
    lansdale, pa
    okay thanks, mine doesn’t have that but it doesn’t look like there is any room for it to really slide around i guess i’ll see. it was fine yesterday but slow crank this morning then barely started before work. at least its manual bc bumping is always useful in emergency.
    Oct 01 2024
    lansdale, pa
    I’m interested in upgrading my sway bars. I’ve heard great things about the hotchkis sway bars and some people also say just the rear bar is the sweet spot since the car has quite some understeer. please share your experiences and point me in the right direction.
    also when hitting some bumps or sitting in the car slight squeaks are heard. thinking control arms? all feedback is helpful. thanks.
    Feb 05 2007
    Portland, OR
    I’ve got a front and rear Hotchkiss on one of mine and I can definitely tell you it tightens things up a lot. These are big heavy cars and cornering is not their forte, but body roll is As alternatives, you can run S6 or RS6 bars, too. S6 may be the same or just slightly bigger and RS6 is definitely bigger.
    As far as squeaks go, upper control arms would be my first bet. Another thing often overlook, but usually not a squeak per se, is the top hat bushings, too.
    May 20 2010
    Honestly, on the Allroad, squeaks over bumps can be so many things
    Strut mounts are the typical culprits. Your handling and steering feel would likely feel a bit clunky with control arms. The front rear lower CAs (the curved ones) tend to exhibit their failure symptoms on braking, so that's something to check. A visual inspection will do wonders. And if you replace any, make sure to get them torqued to spec at the ride height you will use the most (probaby Level 1 for most of us).
    I had Hotchkis on my previous Allroad and currently on the RS. They're great. I did both F&R, and likened it to "turning a whale into an orca" w.r.t. handling. Sadly, the stock air ride will limit how well it will handle. I felt myself missing them earlier when I was taking an interchange between two highways and had to slow down significantly because the car rolls so much.
    But you are right: the bigger bang for your buck will be the rear. Both are beefy bars compared to stock.
    Upgrade your sway bar links while you are in there. The OE ones are plastic (on mine anyway), and there are some decent metal ones available as inexpensive replacement or upgrade like 034.
    Oct 01 2024
    lansdale, pa
    my allroad
    awesome. im planning on installing lug studs the previous owner provided because im sure ill have the wheels on and off and these are a b****. when im in there im going to look around at everything, might be wheel bearing as well I heard some squeaking faintly just while rolling. i’m going to try to find a decent used hotchkis set but if I can’t I may go for a new one we will see ig. I’m going on vacation tomorrow so hoping when I get back in a week i’ll have it on E. it is intimidating but i’m optimistic that Jfonz tunes might be okay.
    Oct 01 2024
    lansdale, pa
    new weighted shift knob, 1.4 pounds. looks and feels great so far
    May 20 2010
    That looks nice! Good thing you don't live in Arizona--would have to oven mitt it in the summer!
    Oct 01 2024
    lansdale, pa
    Thanks. It actually floats into gears pretty great, we will have to see in the philly summer if it is manageable.
    Oct 01 2024
    lansdale, pa
    I regreased and cleaned the dvs which was obviously never done because they were pretty much bone dry. When taking the first one off the 1/8 vacuum fitting broke because it’s plastic and probably almost as old as me. Tried to find the right one but the threads must be from UK or something. I got brass and plastic and the brass one didn’t thread but i made the plastic one thread with force. The nipple was 1/4 which is big but i stretched the hose over as much as possible. Trying to find a new fitting now that will work , if they still make it. Hopefully this will hold in the meantime. It would have taken me under an hour 🥲🥲
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    I just took a look at my spare set of Bailey Motorsport diverter valves, and they have gray plastic fittings marked with Norma 4 R1/8" on the sides like https://shop.normagroup.com/de_en/no...108910004.html, but that site indicates 'Sales only to distributors and industrial customers. But not to commercial and private end customers'. One of my diverter valves has a straight fitting while the other is a 90 degree fitting. I'm not sure where you could buy the Norma fittings, but I tried E-bay, and they have some listings from Germany, but the shipping is really high at around $38.
    For the vacuum hose, I believe that I used braided vacuum hose with size 3.5mm ID and 7mm OD, and I got it thru RM European although it may be available elsewhere.
    *** Update - I just did a quick search for Norma at the Audiworld site, and thread https://www.audiworld.com/forums/s4-...-what-2776359/
    has some good info, and post #5 mentions that the fittings are just 1/8" NPT to a 1/8" hose barb so you can search for that.
    - Jim
    Oct 01 2024
    lansdale, pa
    Thanks for the help. I was on their website aswell, my fittings read the same. And i also saw some ebay listing but shipping is more than the product and i only need 1. It’s so weird i literally got 1/8 NPT TO 1/8 hose barb at ACE. And bought a plastic one after the brass one didn’t fit( too big), weird unless it was a machining error or something. I will order some up from amazon and try again. Thanks again Jim
    Feb 05 2007
    Portland, OR
    Feb 05 2007
    Portland, OR
    I’d be worried about this, too. My climate is much more temperate, but that week or two it’s hot AF, I know it’d get me a couple times
    Feb 05 2007
    Portland, OR
    Way to recover. Let us know what and where you end up finding the solution to be.
    Oct 01 2024
    lansdale, pa
    Quote Originally Posted by ShelbyM3 View Post
    it’s been pretty cold recently in philly and the knob gets ice cold so i’m assuming on the hot days it will definitely be absorbing the heat, it’s fine i’ll just throw a sock over it
    Oct 01 2024
    lansdale, pa
    will do, she’s holding up but definitely going to make it prettier with the brass fittings on both sides.
