Page 2 of 19 FirstFirst 123412 ... LastLast
Results 41 to 80 of 742
  1. #41
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    What yard did you go to? Just curious what would be 30 min from your location....
    Sent from my ONE A2005 using Audizine mobile app
    14 A4 allroad - stock
    05 allroad 2.7T Stock
  2. #42
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by hoganalley View Post
    U-Pull 4 less next to Doms Auto Parts. Got me the air tank for $10 and the plastic bits for a couple bucks
    Sent from my SM-G935W8 using Tapatalk
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
  3. #43
    Dec 10 2013
    I've had a number of things happen the last few days. I've managed to: map out most of the wiring for a 4.2 swap after spending 3 days looking at wiring diagrams and comparing them. Picking up a full motor and everything needed around early June.
    I've also managed to roll up the mileage on the Allroad with some very impressive numbers. I've managed to stretch the tank to 530km by 3/4. If I didn't drive like an idiot or have a 100km of stop and go city driving, I think it could be done better.
    I got these EGT boards from the guy in Poland. Perhaps I'll be putting them in sometime soon, or if the EGTs throw more codes.
    Rear suspension is also in! I gotta get the bushings for the upper and lower control arms that connect to the spindle, as well as all new bolts.
    Besides the dust, these arms are OEM fresh. I don't really want to install them now lol
    This has been the source of some clicking noises when closing the hatch. I've tried tightening this up, but to no avail. The Allroad in the junk yard showed no real way to fix this. What are my options?
    Washed the engine bay clean of most of the dirt and trash.
    IG: 24_et
    Sold:
    RIP:
  4. #44
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    http://forums.quattroworld.com/allro...s/259182.phtml
    My little writeup for fixing the hatch strut ball mount.
  5. #45
    Dec 10 2013
    Quote Originally Posted by SteelyS6 View Post
    Was hoping I wouldn't have to drill lol. Thanks!
    IG: 24_et
    Sold:
    RIP:
  6. #46
    Oct 29 2011
    Winnipeg Manitoba
    Yup the drilling part needs to be done very carefully!
    If you decide to do this, I have a whole box of the nutserts left.
  7. #47
    Dec 10 2013
    Some days since the last update; I noticed my "Allroad" badge was hysterically crooked.
    Swapped out my old radio with an inoperable tape deck with one out of another C5. Also got my steel ball seat lugs and have since replaced the summers I had with the blue tuner lugs for the stock set of wheels.
    Rolled up to the shop to find another allroad get 3/4 bags replaced and a Jerry rigged air line repaired for leak free operation.
    Then set about doing my clutch switch to kill any driveability issues I've been having. Drop the knee bolster and it's right there
    Literally(white plug)
    Pulled it out and found it rather short
    Installed the new one and called it a day. Also talked to the shop about my 4.2 S6 swap I've planned for September, and they don't want to do it. They recommend beefing up the 2.7T with some turbos and supporting mods then call it a day, or upgrade to an RS6 (which I've found stupid cheap with low mileage), and 6spd swap it when the tranny dies. Everyone and their great grandmother has built a 2.7T, but who does it to a 4.2? As much as I like it, it's getting old.
    Also went to go look at a potential summer car today. 1997 UrS6
    Asked the guy if it was stock once I opened the hood, and he said it was a stock turbo. Never have I ever seen a stock turbo look like that.
    IG: 24_et
    Sold:
    RIP:
  8. #48
    Dec 10 2013
    Got a chance to run the dyno today. Pretty disappointed with the end result.
    110whp and 155wtq. Limp mode obviously, but I have no idea why.
    Went out and logged it afterwards and hit 35psi in 1-2 but gears 3-6 are 4psi.
    I want to fix it, but I also got that S6 4.2 to put in lol. Any ideas on what's going on?
    IG: 24_et
    Sold:
    RIP:
  9. #49
    Dec 10 2013
    Anyone who wants to see the monster dyno sheet in hi-def
    IG: 24_et
    Sold:
    RIP:
  10. #50
    Senior Member Two Rings rah253's Avatar
    Oct 06 2016
    pierce county, wa
    Quote Originally Posted by Bordom View Post
    I took some things intended for the S4 and threw them onto the Allroad. It also got an interior clean, thanks to a wonderful woman of mine.
    While changing wheels, I noticed that the Allroad will need control arms and bushings in the rear. They shouldn't be too hard to do though.
    Awful picture of one of the front upper arms.
    Front lower
    Now it's perched on the new wheels, but they look quite small with the wider arch on the C5. Probably thinking of going 19s or 20s nect year.
    Then the headlights got a nice go around and refresh. Before:
    After:
    Didn't get a chance to seal them, but I'll do that next week after cleaning them up again. 402 mod is next on the list to settle on the final look, as well as an alignment to make sure everything is kosher
    AR and headlights look good! Did you just wet sand them down in 3 or 4 steps and just seal them afterwards? Just asking because i need to do that on my 03 RS6 and i'm a little worried about messing up my headlights! Looking good so
  11. #51
    Dec 10 2013
    Quote Originally Posted by rah253 View Post
    I did it in multiple steps:
    -400 cuts the fastest and where you should aim to get rid of most of the oxidization
    -600
    -1000
    -1200
    -1500
    -2000
    I didn't seal them (still haven't) but they still look good from afar. Some oxidization is starting to come back.
    I'll do it in September while the lights are off the car to do a better job, and maybe get some new rubber trim for them.
    IG: 24_et
    Sold:
    RIP:
  12. #52
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Are there any codes present after it goes into limp mode? It sounds like an under boost issue since it's happening in higher gears or your turbos can not keep up with the requested boost. Also 35psi is before atmospheric pressure is subtracted so that's around 20psi. Your long term fuel trims are showing a slight rich condition that could be pointing to a boost leak.
  13. #53
    Dec 10 2013
    Quote Originally Posted by Corradovolksb View Post
    Strange, I thought I responded to this, but apparently not. Here's the saved post:
    I've used this program before in my S4, and it read boost properly so that gauge reads "Boost Actual"
    A local tuner said that if I'm seeing that kind of boost in 1-2 and it going limp 4psi in all other gears, it may more than likely be a torn wastegate line. <-- since this, and the research I've done, it's more than likely a wastegate line, but I gotta boost leak test the lines to be sure.
    Shouldn't be too hard to do right? Drop the sway bar and remove either motor mount and TIP to get to the wastegate lines in the Allroad.
    In other news, the lady and I are going to be pitching in 50/50 for a brand new radio.
    Just put in the order here from Enfig:
    Hopefully I'll see it Friday and can put this radio in. Pioneer AVH-X2800BS
    IG: 24_et
    Sold:
    RIP:
  14. #54
    Dec 10 2013
    Should also be taking delivery of my S6 V8 this month as well, schedule dictating of course. Excited to get it and see how healthy this high km unit is; starting with a compression check and then a leakdown. If it checks out to some specs I found (B6 S4 4.2) then I'll run it as is.
    If compression is low, I'll get the heads refreshed along with 1.8T exhaust valves for my boost plans later down the road.
    If the leakdown doesn't check out, then I'll buy rings and do it like the Porsche guys do with their DIY hone jobs and such. Obviously the heads will be done at the same time, as well as all seals, rod/crank bearings, oil pump and tensioners.
    Debating forged pistons, but those are a lot of money and they'd need to be coated for the Alusil block. S6 bottom end should suffice since its already beefier than AN A6 4.2.
    Pic of the donor. I should be getting everything including trim pieces and the air box. Not ABS or any of that other stuff that doesn't pertain to the motor
    IG: 24_et
    Sold:
    RIP:
  15. #55
    Dec 10 2013
    My Lady went and picked up the radio in my absence. I'll let the pictures do the talking
    Money shot right here
    The stuff I ordered from Enfig is backordered until next week, and then maybe I'll have it the following Friday afterwards. Who knows.
    IG: 24_et
    Sold:
    RIP:
  16. #56
    Jul 23 2014
    A giant mess.
    AK
    What's this I see about an RS6 swap?
    Need the updates on this!!
  17. #57
    Dec 10 2013
    Quote Originally Posted by AudiMyMindS4 View Post
    Not an RS6 swap, but an NA BBD S6 swap in September. Depending on condition of the motor, I'll either plop it in and run it NA for a bit then shove a turbo on it, or rebuild it to handle boost and throw it in with a turbo right away
    IG: 24_et
    Sold:
    RIP:
  18. #58
    Jul 23 2014
    A giant mess.
    AK
    Ah, I must've misread it. In any case, it sounds like it'll be pretty sweet.
  19. #59
    Dec 10 2013
    Got all the stuff in from Enfig the other day. This would include:
    -Pioneer radio plug and play kit
    -Their own proprietary kit to eliminate the low sound from the back of the car
    -Radio cage and bezel
    -Steering wheel control wire
    And what the end product should be like
    Spent 2 hrs trying to finangle it into position within the dash. Install was pretty easy once I followed the Enfig install video.
    Here's the finished product
    When installing it, I must have accidentally removed the Steering wheel control wire from the radio, but now that it's in there I have no idea how to remove it. I'll live with it for now.
    IG: 24_et
    Sold:
    RIP:
  20. #60
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    What did that run you? Happy with it? Bose amp/speakers still?
  21. #61
    Dec 10 2013
    Quote Originally Posted by happy2B5 View Post
    Ran me about $600 all said and done. The radio was half that and all the plug and play Enfig stuff was the other $300.
    It's all the stock Bose stuff for now. I do have a separate Infinity sound system with a self powered sub that I had saved for my S4, but never got around to installing. I might just throw all that into the Allroad at some point. The sub will definitely be put in sooner than everything else.
    I'm definitely happy with what I got. No more mucking around with the stock radio or cassette adapters for playing my own music. The audio is much more lively than the stock system, and being able to choose how you want to hear the sound (front/front left/front right/rear/all) as well as some great EQ settings makes it worthwhile.
    Definitely want to fix the Steering wheel controls because using the provided remote with the radio is getting troublesome haha
    IG: 24_et
    Sold:
    RIP:
  22. #62
    Dec 10 2013
    Forgot to mention I've already started ordering things for the S6 motor and Bits.
    IG: 24_et
    Sold:
    RIP:
  23. #63
    Jul 18 2009
    Good to hear. I am in market for new head unit as my screen has gone dead. Think the ribbon to a dump. Only thing I am hesitant about is my car came with lifetime sirius/xm. Not sure how this will impact that?
  24. #64
    Dec 10 2013
    There should be a sirius/xm module you can unplug and plug into the new radio. Shouldn't be a hassle.
    In other news, found a deal on 18z for $250. I'll be picking them up Friday
    IG: 24_et
    Sold:
    RIP:
  25. #65
    Jul 24 2013
    Bellevue, WA
    I'm a bit of an Allroad amateur. I noticed that your wheel fairings and bumpers are matching color. Was that a factory option? How can this be achieved? Can you paint them? Or maybe some cheap ebay parts? I also have a silver Allroad but the trim is that matte gray/black.
    2007 Audi RS4
    2004 Audi Allroad 2.7t
    2007 Yamaha Vino 125
  26. #66
    Veteran Member Three Rings charlatan's Avatar
    Apr 13 2007
    MOLINE, IL
    Can you give us a step by step of your headlight restoration? Products used, etc.
    theROGUEdesigner
  27. #67
    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    Northern Virginia
    Ooh, Porsche calipers. I like this progress.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
  28. #68
    Dec 10 2013
    Quote Originally Posted by lorengphd View Post
    Quote Originally Posted by charlatan View Post
    Here you go:
    -600
    -1000
    -1200
    -1500
    -2000
    Quote Originally Posted by R490 View Post
    Hopefully I don't end up selling the car like the last 2. Each one got a BBK and was sold in a year lol
    Ps, I enjoy when you stop by. Join C5 land again
    IG: 24_et
    Sold:
    RIP:
  29. #69
    Dec 10 2013
    I've been gone a while but now I'm back. Still waiting on the motor and everything to be delivered, but I've managed to negotiate many more things from the car I'll be getting the motor from.
    Things I'll be grabbing:
    -S6 Motor (complete)
    -18z BBK
    -an upgraded set of rear brakes (unknown if they're OEM S6 or another model)
    And potentially the clutch/flywheel off the car if it's confirmed it's a B7 RS4 clutch and TTV flywheel.
    I've got in the rest of the suspension and I'm trying to work out a deal to get some Arnott Gen 2 air springs to replace the old OEM stuff. I'll then be modifying the OEM stuff to try and accept larger air lines so I can switch over to manual air management.
    My other option would be to add a compressor to the current tank to aid the old and dying stock one, just to keep the air tank filled at all times.
    IG: 24_et
    Sold:
    RIP:
  30. #70
    Aug 10 2017
    Rehoboth Beach - Delaware - US
    Cool thread to read thru. Allroad noob here. Seems like this will be a nice addiction for me.
  31. #71
    Dec 10 2013
    Another long time no update:
    Been ordering a TON of stuff in preparation for the swap, but I'm still waiting on the donor car to be ripped apart.
    However, I can now do other things:
    I bought a 2003 Suzuki GS500
    Ad pics, but doesn't need too much to be road worthy:
    -Rear tire
    -Battery
    -Chain
    -Spark plugs
    -Oil change
    The bike sat for 2 years so I'll have to drain the old gas and try to clean it up. Might rebuild the carbs or even give the jets a quick clean. The chain is also kinked and has more play than a granny's breasts blowing in the breeze.
    Wanna get that all sorted and riding while the car is being swapped so I'm still mobile.
    And the sweet sport shifter has shipped!
    IG: 24_et
    Sold:
    RIP:
  32. #72
    Dec 10 2013
    My driver window regulator bit the dust a couple days ago, so I went around and replaced it from a buddies partout car - Allroad central
    The workspace at my pops place
    Old
    Cable ended up snapping, which I am to understand is rare
    New regulator/window frame
    Minty looking cable
    Inside of my door. Looks like it was dust checked at some point, and it's obviously helping
    Little bit of rust
    Also picked up a new switch and went to work replacing it.
    Old and new comparison
    IG: 24_et
    Sold:
    RIP:
  33. #73
    Jul 07 2015
    Oof. That old switch. Soft touch plastic is the bane of my existence.
    The new one looks minty! You spring for a brand new one? Or did you get lucky?
  34. #74
    Dec 10 2013
    Girlfriend surprised me with the switch actually. Idno where it's from, but I'd guess from China lol
    It's the same to me and actually looks of better build quality than the original. Time will tell though
    IG: 24_et
    Sold:
    RIP:
  35. #75
    Dec 10 2013
    I got this in from my contact in the US:
    -Vaiair 444cc Dual air compressor kit
    -034 Track density trans mounts
    -ECS tuning billet motor mounts
    -8x rear spindle bushings for upper/lower control arms
    -OEM rear hardware kit.
    I'll get pictures of everything eventually, bit it's starting to come together for the V8 swap.
    You may be curious about what I'm doing with the compressors, and I'll lay it out. I'm breaking this up into 2 stages.
    Stage 1:
    Hook up one or both compressors to keep the OEM tank filled to 165-200 PSI, And keep it filled so the stock compressor barely ever has to run, since the tank is always full. All suspension adjustments from then on should use whatever supply is in the tank.
    Stage 2:
    Replace the air lines with 1/4 or 3/8 air lines and then drill+tap the OEM bags to accept NPT fittings. This stage also includes converting over to manual air management with a dual needle air gauge to measure front and rear air pressures. That way I can set the car to x-psi and get it aligned at that height for driving.
    I will be running the front and rear with a T connection between each bag. I won't be running 4 individual manual valves because that's a lot of work and I'd rather do it that way if I could convert to digital for more precision, but we all know it's $$$$ lol
    If anyone can find an adapter that converts from the OEM BSPP to NPT, that would be great because the research I've done has been inconclusive for right answers on the OEM thread and fitting size. Closest I got was a thread from user CHRISTOPHÉ, but he encountered major reliability issues with his air lines.
    IG: 24_et
    Sold:
    RIP:
  36. #76
    Dec 10 2013
    Here's the pictures as promised:
    All out of the box
    ECS-Tuning motor mounts. My second set since the ones I bought for my S4. Absolutely love these as they only vibrate at idle but are rock solid off idle.
    034 Track density transmission mounts. Also very solid feel and little to no NVH from the car (in my experience)
    Upper/lower rear outer bushings for the control arms. 8 of these suckers for the rear end
    On to the big boys
    Packaged away
    These things are heavy and I've got no idea where to mount them lol
    Does anyone know the maximum pressure range of the OEM tank? These are set to 200psi, which I believe is safe for the stock tank since the system is a 235psi system.
    Gotta figure out plumbing and how to wire it through the instructions and it should be good to go.
    IG: 24_et
    Sold:
    RIP:
  37. #77
    Dec 10 2013
    I went for 2 hr drive to look at something pretty interesting today. Talked with the owner for 2 hrs and went for a ride. You all can try and figure out what I went to look at:
    Real clean 03 RS6 with a 6spd. Saw it pop up a few weeks ago and didn't contact the owner until now. I haven't had a smile on my face that big since selling the S4. What a machine
    IG: 24_et
    Sold:
    RIP:
  38. #78
    Jul 07 2015
    Annnnnnnd....?
  39. #79
    Dec 10 2013
    Quote Originally Posted by KSEADUB View Post
    Annnnnnnd....?
    Currently negotiating for an addition to the fleet.
    IG: 24_et
    Sold:
    RIP:
  40. #80
    Oct 29 2011
    Winnipeg Manitoba
    Awesome, I saw this on Kijiji too. Would be awesome to see it go to an enthusiast!
    RS6 is definitely my next C5, oh the sound and torque of the V8's is glorious!
