Introducing ECS's Performance Baffled Oil Catch Can System for the B8 3.0T, engineered and tested in house. Our system was designed with the consumer in mind to provide effortless installation with no necessary modifications to be a perfect fit for your 3.0T.
Today's direct fuel injection systems have one drawback. Without fuel vapor to help clean the intake valves, oil particles are drawn into the intake from the PCV system will deposit onto the valves and ports. Over time this will result in increased levels of carbon buildup, resulting in lost power and poor drivability.
Key benefits of the ECS Baffled Oil Catch Can System:
- Highly Efficient Oil Separator (Catch Can):
- Strategically positioned 4 chamber baffle system maximizes oil / air separation
- Engineered to create multiple changes in the direction of airflow within the separator to cause oil droplets to fall out of suspension before exiting the catch can
- Knurled and black anodized integrated oil dipstick makes inspecting oil volume of reservoir clean and simple
- Fully serviceable for routine cleaning and maintenance; Includes 2.5mm allen key to remove baffle plates for cleaning
- -10AN ORB (O-Ring Boss) fittings for leak-free fitting connections
- 6061-T6 billet machined body, anodized black for lasting protection and appearance
- Easy to drain reservoir, simply un-threads from the oil separator for quick draining or cleaning
- The OEM fine oil (cyclonic) separator is retained. Due to the retention of this component, the catch can will not have to be emptied as often, as its focus will be on capturing the ultra-fine oil vapor
- Completely reversible installation, as no OEM components are permanently modified. This is ideal for those who choose to remove their catch can during the cold winter months
Stay Carbon Free
Fits:
Audi B8 S4 '10-'16
Audi B8 S5 3.0T Coupe '13-'16
Be sure to check out our -----> Installation PDF <-----
Jason
