Page 9 of 9 FirstFirst ... 789
Results 321 to 348 of 348
  1. #321
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by Twi7ch View Post
    What symptoms did you get when your flowmaster cats failed? I currently have Flowmaster 200 cells near the transmission and I just did a long road trip (1500 miles) and I noticed my exhaust note has changed. I'm a bit concerned as I have 1500 miles to go to get back home...
    Sent from my Pixel 9 using Tapatalk
    The failure was misfire on the driver side and a metallic rattle in the suitcase muffler. A piece of cat substrate had blown through the Vibrant on that side and into the suitcase. The cat metal was removed. But, it was too late. The engine had lost compression on two cylinders on that bank (hence the misfires). In short, I lost the engine due to excessive back pressure. The cat on that side was blocked completely.
    I was able to locate a low mileage replacement complete engine, even including the supercharger and accessories for about $5000. The seller (a salvage yard) didn't know what they had. These go for much more. We were able to sell the accessories and supercharger, even cylinder heads on my old engine and recoup some of the cost. I swapped over the pulleys so I could continue to run the tune. All is well, so far.
    There were no symptoms other than misfires and the metallic object in the suitcase muffler. Exhaust tone did not change, although I could understand why it might. We initially thought it was simply an internal baffle in the suitcase, but it was cat material, and the compression test told the sad news.
    I did not have any change in sound other than that rattle. The only sign was the misfire on one cylinder. Compression was zero on that one and 70 on the other. These were cylinders 4 and 5.
    Try to baby the car until you get home. I would not do any full throttle pulls. If it starts misfiring, I would park it and try to save the engine, but it could be too late. The best solution would be to find a muffler shop and get the Flowmasters out, even if it means temporarily installing a section of straight pipe where they are connecting to your resos, then put ceramic cats in.
    I made a huge and costly mistake with the Flowmasters. Steel just separated and clogged. If ceramic fails, it is more likely to break up and get blown out. If you relied in my advise or the parts listed in my signature regarding the Flowmasters, I deeply regret it.
    Subsequently, I did a deep research dive on the Flowmaster 200 cell steel bottle carsvand discovered an alarmingly frequent failure rate.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
  2. #322
    Sep 06 2020
    Oh man this is not the news I wanted to read. When you were getting misfires did you get get a flashing CEL or EPC light? Or was it just a loss of power when accelerating?
    Also did it log any misfire codes? I just scanned with obd11 and I'm not seeing any misfires detected. Sadly obd11 doesn't show me live data of misfires.
  3. #323
    Feb 14 2017
    Gulfport, MS
    Misfile and cylinder deactivation codes consistently on two cylinders on the driver side bank. Yes, an EPC light. I can't say you are safe if you don't get those warnings, but I did in addition to the rattle in the suitcase muffler.
  4. #324
    Sep 06 2020
    I just took it for a small drive and hit 4500k RPM. 1 misfire in Cyl 5 & 6. It's going to a shop tomorrow.
  5. #325
    Sep 06 2020
    Little update. Had the car compression tested and it came back all good with 165-175 PSI. The mechanic banged on the HFC and didn't hear any noise, he thinks new spark plugs will resolve the problem and a new O2 sensor but I'm skeptical since this O2 sensor has always thrown a slow read code. And I can't see that being why I the exhaust note changed and multiple misfires. Anyways, I'm having these flowmasters removed regardless for peace of mind. I really don't want to spend money on GESI cats next. The amount of money I've had to piss away on this exhaust system is a bit outrageous and I'm not even dual pulley.
  6. #326
    Sep 06 2020
    I saved my motor! Flowmaster 200cell cats failed in the downpipes. I'm thankful I was able to get this resolved as quick as I did while on a road trip. Now I can drive the 1500 miles back home with peace of mind.
  7. #327
    Senior Member Three Rings Slvrbul8's Avatar
    Apr 14 2021
    300zxTT and E46 BMW 330i
    Roanoke, Va
    I feel ya! I just had the GAS high flow cats installed after my oem cats started throwing low efficiency codes. One side was completely blown out, the other partially. Combined with all the issues I've had with my milltek catback and i wish I never messed with the stock exhaust.
    Advice to anyone new to this platform...leave the exhaust alone, haha
    IE Stage 2 Dual Pulley, APR HX, APR 187 and 57mm pulleys, Milltek Resonated Exhaust, Deval CF Diffuser, 034 Lowering Springs, 034 Rear Sway Bar, Eurocode AK.
  8. #328
    Junior Member Two Rings knock.out's Avatar
    May 05 2019
    Texas
    Quote Originally Posted by Slvrbul8 View Post
    Thanks for sharing, GAS claims ZERO failures of their gesi cats in stock location. Did you have the 400cel gen 2 gesi or 300cell gen 1?
    B8.5 S4 DSG
    034 stage 2+
    previous: B6 A4 Ultrasport 6MT
  9. #329
    Mar 31 2008
    eS-4
    CAL*SO
    That claim of "hundreds" of setups is so wild, especially those power numbers. Especially when it's very hard for the average user to break 500whp.
    If y'all remember redstars from years back. They were the go to catted downpipes and it didn't take very long for folks to blow out those same gesi's in the same location and those guys def weren't pushing power numbers like that.
    They do look really good though 😍
    The same throttle body and corn toon as everyone else.
    A ported blower and the mega bitch pulley.
    Lots of water and wheels lighter than my bank account.
  10. #330
    May 05 2019
    Texas
    Quote Originally Posted by Fresh.S4 View Post
    Exactly my thought, it's a fundament flaw in the design that material science can't solve for a reasonable cost.
    I have P042000 code now at 1.7k rpm and P030300/P030200 cyl 2/3 misfire at about 6k rpm. Coils and plugs are 1yr old, so planning to check IC cores and injectors first. If blown cat I'm considering doing headers to downstream exhaust cutouts then cats.
    Seems like a good way to let it rip on track with no impact to cats. Witht cutouts, then also able to close it up any baby the cats for daily/spirited driving.
    Has anyone run this setup?
    B8.5 S4 DSG
    034 stage 2+
  11. #331
    Senior Member Four Rings
    Jun 08 2021
    PA
    I wonder what it is about these motors that is so hard on cats. From what I've always known it's overly rich fuel mixture that's melts cats. Maybe take this time to replace your upstream O2 sensors. If they are not reading correctly it can cause a rich mixture all the time. Make sure you're misfire counts are low. Lots of misfiring can load them up with fuel and melt them as well.
  12. #332
    Apr 14 2021
    Roanoke, Va
    Quote Originally Posted by knock.out View Post
    B8.5 S4 DSG
    034 stage 2+
    Bill said they are only using the Gesi 400 gen 2 now. The craftmanship was really good and the installer said they fit just like factory. The sound is a little deeper and more gravelly than oem.
  13. #333
    Senior Member Two Rings ThoseRings's Avatar
    Jan 19 2023
    Other Toys
    Good catch!!!
    Quote Originally Posted by Nillious View Post
    My car with the stock tune will do a small puff of black when I rip on it. My understanding is that stage 1 tunes, especially APR run even richer.
    15' Sepang Blue S4, Prestige, DSG, Black Optics, Nappa, Sport diff, Adaptive suspension, Carbon Atlas, SC badges.
    I've added: 30% ceramic tint, Vled's 5K fogs and reverse bulbs, Osram CBN HID bulbs, APR Carbon Fiber intake and tube, CR-15 brace, EuroCode Alu Kruez and DSG insert - Otherwise stock
  14. #334
    Apr 14 2021
    Roanoke, Va
    The current gesi 400 cell gen2 has a completely different core than the old redstars used. The dual wound s-core is the game changer.
  15. #335
    Sep 06 2020
    Do you think Gesi OBD2 (300 Cell) could handle the temps in the same spot my flowmasters were (in the downpipes right at the bend before it goes into the first resonators)?
  16. #336
    Apr 14 2021
    Roanoke, Va
    Hard to say for certain, but I think the gesi would be better quality than the flowmasters.
  17. #337
    Established Member Two Rings STXA7's Avatar
    May 24 2024
    Shelves full of crap
    South Texas
    “the definition of insanity is doing the same thing over and over and expecting different results”
    as someone mentioned before , every inch you move it downstream will protect the hfc core
    JHM HFC placement go where original pair of first resonators are at maybe try copying that placement
    I am a 034 nutswinger
    Disclaimer: I am not sponsored or affiliated with 034 motorsport, just one of many happy customers.
  18. #338
    Sep 06 2020
    Quote Originally Posted by STXA7 View Post
    I already have a Gibson resonator in that location otherwise I would. Sadly the only spot I have room is where my last pair of cats were. If GESI aren't likely to survive I guess I'm SOL
  19. #339
    Apr 14 2021
    Roanoke, Va
    You are not sol, you just need to get the 400 cell version. https://garageautosports.com/product...0&_ss=e&_v=1.0
  20. #340
    Sep 06 2020
    I can't justify dropping $2g's on those as much as I'd like to have them.
  21. #341
    Mar 31 2008
    eS-4
    CAL*SO
    you can CLEARLY fit hfc's right after the tp and have room to stick resonators...
    https://www.audizine.com/forum/showt...1#post15131506
  22. #342
    Sep 06 2020
    This is where I had my flowmaster HFC so yes there is room after the TP. I'm just saying I don't have room to place them further away from the engine than that.
  23. #343
    Mar 31 2008
    eS-4
    CAL*SO
    just get some magnaflow's or if you want to spend the extra $$ get some gesi cats in the same location.
    i thought about getting that gibson resonator but its all baffles and no packing. not sure how the sound would of turned out.
  24. #344
    Sep 06 2020
    The Gibson does have a bit of a hollower sound but it's the only thing that's lasted. I blew out my MF res, I blew out my Borla res. This at least helps with rasp and is holding up.
  25. #345
    May 24 2024
    South Texas
    Check out YouTuber C Midas he has a video specifically about the Gibson muffler with before and after sound on his A6 3.0t not sure if he has any hfc though probably not.
  26. #346
    Mar 31 2008
    eS-4
    CAL*SO
    yea i know him. hes local.
    i originally started with polo performance (helmz holtz) but after adding tps, it was a downhill losing battle with having to add hfc's and multiple sets of resonators. if my current 5" cans ever blow out, ill probably try the gibson just for shits and giggles.
  27. #347
    Jun 08 2021
    PA
    I wonder what a set of super 50s would sound like on these cars. Zero packing and can never blow out. They are pretty damn quiet on the cars I’ve heard with them but they were all v8 or na v6s
  28. #348
    Jan 11 2020
    Europe
    I have had no issues with the GESI GEN 2 cats placed in the resonator section in the past three years at stage 2 power level. This includes one German autobahn trip (>155 mph+) and frequent 60 - 120 mph pulls. Quite interesting to see that other vendors claim they also hold up at stage 2+ level when placed in the stock cat location.
    2015 Audi A5 3.0 TFSI quattro (CREC)
    2020 Audi E-Tron 55 quattro
