Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 348
  1. #161
    Active Member Two Rings drew_doc1's Avatar
    Jun 08 2018
    '15 BMW X3 35i twin turbo, '17 Rubicon Hard Rock
    Colorado Springs
    Have JHM test pipes w AWE touring exhaust w resonated DP's. Was pretty loud and the odor was rough. I found the best price for GESI Vibrant high performance cats online at Home Depot of all places. Had custom install just infront of the x-pipe w quick change flanges in case they need to be replaced in the future. No smell now, slight reduction in noise, and likely a slight bit to the power, but for me was worth it.
    '16 Blk Prestige B8.5 APR Stage II+ dual pulley 91 oct, Ultracharger, intercooler, cold air intake, TCU upgrade, JHM test pipes, AWE Touring exhaust w Res DP's, Vibrant high perf. cats, Eibach Pro+sway bars/springs, 034M end links, P3 multi-gauge/track pack, tint, 3M clear bra, Audi door lights and valve stem caps, RS4 grille, StopTech slotted and dimples rotors, Redstuff pads, steel brake lines w Motul 5.1, tow hook license plate, matte rings and APR Stage II+ badge on rear
  2. #162
    Jun 12 2019
    Chicago Illinois
    So looks like I have a failed cat also @52k stage 2 single pulley and tcu tune. I went in to Audi Friday and was told scans were still reading my tune so they supposedly unplugged right away before signal sent thru. My question for all my tuned ppl is should I have tcu tune flashed back to stock also? I was told to give it a week or so to come back to Audi and try again with the scan from my SA so I will be most likely returning this week
  3. #163
    Mar 20 2017
    Algonquin IL
    Why do the test pipes get ceramic coated? For sound?
  4. #164
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by WillS4 View Post
    For heat dissipation
    Sent from my SM-G965U using Audizine mobile app
  5. #165
    Dec 02 2018
    2007 Subaru STI
    Florida
    Anyone ever test the magnaflow oem test pipes? If so, how’s the longevity
  6. #166
    Senior Member Two Rings audis4culver's Avatar
    Mar 07 2016
    2016 S7, 2011 S4, 1985 VW Vanagon, 2015 Q7, BMW 2004 X5 Manual, 1966 Jaguar E-Type
    Georgia
    Mystery smell help. 2011 Audi S4 Stage 2 with AWE touring exhaust. So this summer has been over the top hot and I have been driving my yard car instead of the s4. I keep the car in a very sealed enclosed garage. two weekends ago I drove it early in the morning when the temps were lower and with windows open, I smelled a very strange dead animal or sulfurish smell from the right side the with windows open. The smell does not happen when the car is turned off. so I am thinking its not actually a dead animal.... is this smell the beginning of a cat going bad? The car sat for 2 months with very minimal use and now this smell has appeared. I dont see any white residue on the exhaust or back of car. The smell wont go away and its pretty bad. If the cats are going, is this a 2K job or 4k ? If they are going, can I keep driving until the next inspection? This post people report a sulfur smell - is the smell straight up sulfur or are other smells mixed in - like a gas or dead animal type smell? I dont smell it when the car is idling in the garage, but when I drive and come to the first or second red light it really smells. only smell it with windows open. Thanks.
    2016 Audi S7
  7. #167
    Oct 15 2012
    Northern%20NJ
    Quote Originally Posted by drew_doc1 View Post
    Any chance you have pics of this setup? Also curious how sound compares to stock cats with AWE touring and resonated DP's as this is my setup now and in planning for the eventual failure, your setup sounds similar to something I might want to do.
  8. #168
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    Is the cats from a b8 and b8.5 the same? Sorry I'm have no luck searching
    Sent from my SM-G960U using Tapatalk
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
  9. #169
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Quote Originally Posted by mys4.org View Post
    Not the same but they are interchangeable . The 02 sensor is just slightly in a different location .
    B8.5 034 E40 DP
  10. #170
    May 29 2019
    Fort Worth, TX
    I’m getting my engine cradle / subframe replaced and also my engine mounts since they will be accessible. Are the cats going to be more accessible during this process? If so I might just ask my shop to go ahead and install test pipes or I’ll buy some used cats and gut them ahead of time. Then I’ll install high flow cats in the down pipe.
  11. #171
    Sep 07 2014
    2013 s4 79.5k. Got a 420 code couple months back, dealer did the reflash. I scanned the car a couple weeks back and saw the 420 as a soft code, didn't set off the engine light. After two hard pulls merging onto highway last Friday, the check engine light came on. Bringing the car to dealer tomorrow. Hopefully they cover with no issues.
  12. #172
    May 29 2019
    Fort Worth, TX
    So i'm looking for the best high flow internal metallic cats in terms of rated for highest EGT's to install in my down pipes after I gut my cats. I can't get any help from the Magnaflow reps on giving me specs it's like they are worried that if it's in an e-mail they are liable if something happens or something. I think i've read that we can get up to 1800 F in the stock location so i'll just assume that it might be close to that even at the down pipes to be conservative. Anyone have any good suggestions?
  13. #173
    May 27 2019
    London, England
    Quote Originally Posted by jparedes View Post
    I believe the GESI is up to 2500f
    2009 S4 B8 Avant Phantom Black | EPL Stage 2 DP & TCU | Eventuri Intake | MercRacing Cooler divorced with CWA 100.3 | Forge SC pulley & JHM 187mm Crank PR 3.26 | Full Milltek exhuast with DPs & X pipe | Driving Passion rear diffuser, hydro dipped Ferrari Carbon | Yellowspeed 356mm 2 piece Front BBK | 19" Le mans wheels| Fully dechromed & tinted | CR 15 strut brace | All lights upgraded by EM Tuning
  14. #174
    Veteran Member Three Rings tgsweat's Avatar
    Nov 05 2011
    maryland
    I have the magnaflows in my downpipes. I think that 1800F is for the coating that actually does the emissions work. They won't melt until around 2500F or so. Mine are holding up fine structurally/hasn't melted, but i'm pretty sure the coating is gone because i get more gas smell than i did when i first put them on. Which makes sense because i see around 1050C-1100C EGT on a long pull...which i do often lol
    That being said, i'm going to put in the new GESI ($135) cats which are 300cel vs 200 of the magnaflow and see if i can cut the smell even more. GESI said theirs are good up to 1900F for the coating and 2500F for melting.
  15. #175
    May 29 2019
    Fort Worth, TX
    Quote Originally Posted by tgsweat View Post
    Man those are higher EGT's than the 1800 deg F that I thought were max possible. So more like 2000 deg F.... FML. How long did the magnaflows last before they started stinking? Are you running gutted cats or test pipes?
    Did those numbers apply for the $135 cats? When I look at their website, https://gsportbygesi.com/high-perfor...tems-products/, they don't list any specs for HP ratings for the 10025 P/N cats which I believe are the ones you're referring to.
  16. #176
    Nov 05 2011
    maryland
    Yeah i only get that high on a quarter mile pull. Usually i'll hit around 975 or so on some spirited driving around town. But yeah these cars run hot. Also these are calculated numbers, so who knows what we are actually seeing further away in the downpipe. I've had the magnaflows on since july and i noticed more gas smell around november or so. The smell never went completely away after installing these. As of today, the smell is still a lot better than no cats at all. Just wanting to check out how they are holding up and try the new GESI cats. Its easy to swap when they are in the downpipes.
    Yes those numbers apply for the $135 ones also. I called them up myself. The only difference between the $135 and $350 ones is the coating. There more of the precious metal coating on the more expensive ones to pass EPA emissions standards. GESI told me that if you aren't using these to pass emissions, then the $135 ones will do the job for cutting smell and helping with sound.
  17. #177
    May 29 2019
    Fort Worth, TX
    That's good to know. I'm not even looking to pass inspection I just want to A) be able to replace them easily so that's why they'll be in the down pipes. B) reduce gas smell when i go gutted OEM cat. and C) find the highest temp rated so they don't clog and cause me to blow a motor. I'll turn off the CEL via the tune and deal with passing inspection a different way.
    D) Making the sound better is going to be there regardless of brand just by the fact that it's slowing down the exhaust.
    I'm also thinking of getting them with the O2 sensor port bung that I would cap off with a threaded cap so that I can periodically open them up and inspect them with a boroscope to see how they are doing.
  18. #178
    Nov 05 2011
    maryland
    yep i gutted my cats and got a spacer. Still passes inspection here in MD. The magnaflow is going to be the cheapest but gets the job done for what you need. I'm pretty sure magnflow had a lower rating for the coating than the GESI, just can't remember the exact number when i called. As far as clogging, you should be good with either. I'm having the GESI installed on friday, so i can let you know what my magnaflows look like when they are out.
  19. #179
    May 29 2019
    Fort Worth, TX
    What was the part number on the magnaflow cats you used? Someone has a set of 59906's for sale on here (which is what I was trying to get specs for from magnaflow) The magnaflow rep said "These are intended to be replacement OE converters. They are not performance based or "high flow" converters, they are strictly intended to be a OE replicated replacement component that have the same tolerance as that of a factory part."
  20. #180
    Nov 05 2011
    maryland
    I have the 59955. Got them for $75 each back in july.
  21. #181
    May 29 2019
    Fort Worth, TX
    Question: I have a B8.5. Will I have any issues with clearance or fitment against the firewall or anything if I try to use B8 cats with vibrant 11619 o2 J spacers?
  22. #182
    Junior Member One Ring
    Jan 20 2020
    Montana
    15k miles on Dual pulley with crackles and so far the cats seem to be doing alright. Hoping they stay like this, otherwise it might be time for some GESI units
  23. #183
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Almost positive my cats are blown. Got catalyst codes for bank 1 and 2 and my car is dual pulley. Had a leaking valve cover gasket on both sides so I think burning oil burned the cats out faster. Only question is did the cats blow outward themselves? Both my exhaust tips are ashy white and a lot of white smoke blew out under throttle I’m just wondering did they gut themselves? The exhaust gas smells stronger and I do get that sulphuric smell too. Should I keep stepping on it until all the ashy white dust is gone or is that a bad idea?
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
  24. #184
    Jun 28 2019
    California
    Quote Originally Posted by Audibellybutton View Post
    Update I really think they might have blown themselves out and I might be lucky. The exhaust smells a lot more rich now just like when I had catless downpipes on my amg and there’s no more white smoke just some black smoke at high rpm. I’m
    Thinking of renting a plumbing camera to confirm
    IG:@stolens6
  25. #185
    Veteran Member Three Rings street2gen's Avatar
    Oct 13 2013
    Whitewater, WI
    Mine, was melting in on itself and throwing epc light it looked pretty concerning.... i would def scope it from the manifold 02 to make sure.
    '11 S4 | 034 E40 | 034 TCU | 3.315PR-Ported | iABED 75 | MercRacing HX | AutoTech HPFP | ECS Intake | JHM Test Pipes | AWE Resonated |
  26. #186
    Junior Member Two Rings
    Jan 28 2020
    Brooklyn NY
    So I’ve only had my 2016 s4 for about 5 months now. 21k miles. Looking to tune soon, most likely unitronic stage 3. Has anyone blown their cats with unitronic? I know a tune is a tune so it’ll probably happen but is there anything I can do to prolong my lifetime of my cats. In NY they don’t do visuals and I see u guys are saying go test pipes. Only worry I have is seeing a lot of posts about cats blowing very quickly and very often with dual pulley tunes
  27. #187
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Quote Originally Posted by Jimmy_s4 View Post
    +1
    haven't seen any myself on unitronic melting cats but I am curious as well
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
  28. #188
    Oct 18 2006
    Audiville
    Quote Originally Posted by street2gen View Post
    Street2gen and/or anyone that knows, how easy is it to boroscope the cats? probably best to do so before going dual pulley?
    I picked up one of those amazon specials that hook up to your phone... do you think scoping from the 1st manifold 02 sensor in the engine is easier than dropping the exhaust and going up from the downpipe?
  29. #189
    Jun 28 2019
    California
    I don’t think the tune company matters. They’re gonna go eventually. I’m at 97k miles though. Bought the car with rather high miles and tuned it. At 21k miles I’d say you should have a lot of life left on the cats but just be ready to change them down the road or install test pipes or gut them etc
    IG:@stolens6
  30. #190
    Oct 13 2013
    Whitewater, WI
    Quote Originally Posted by 01northernS4 View Post
    Even IF dropping exhaust was an easier option i would think it could be misleading...... in this picture my cat is melting in on itself and never made it all the way through, if i remember correctly it looked perfectly normal on the other side.
    I would pull manifold 02s to be sure.
  31. #191
    May 29 2019
    Fort Worth, TX
    Is it pretty easy to get the manifold 02's off to do it?
  32. #192
    Oct 18 2006
    Audiville
    +1
    for those who have done it or know, how hard is it to get the manifold 02's off to scope the cats?
  33. #193
    Senior Member Three Rings Robdukes's Avatar
    Dec 11 2014
    01 Audi A4 2.8 Quattro
    Mount Cobb, PA
    For those curious. Had Audi quote me new cats. 7k. Crazy.
    Sent from my SM-N960U using Tapatalk
  34. #194
    Veteran Member Three Rings SSSSS5's Avatar
    Apr 16 2018
    '85 300TD, '85 500SEL, NA MIATA, Merkur XR4Ti, '99 Cactus Avant, '10 S6, GX470, '16 Outback
    Bangor. ME
    Quote Originally Posted by Robdukes View Post
    Although they are indeed a bitch to replace, they are't a $7,000 bitch. Thats ludacris
    -Casey @CaseyCactusV10 | 1999 Cactus Green B5.5 A4 Slicktop + V10 + 0A3
  35. #195
    Established Member Two Rings s3lman's Avatar
    Jan 23 2017
    kenosha/wisconsin
    Just took my cats out earlier this week and replaced them with test pipes as I plan on going dual pulley soon. I currently have a custom exhaust (Magnaflow 11385 in place of baby res -> Res delete -> Muffler delete). before I had my cats removed this sounded pretty damn good for a custom route. After I had the test pipes put in this thing sounds horrendous. basically anything above 2700 rpm with the windows up it feels like I'm listening to my car from the outside and with the crackle pop from IE it sounds like actual gunshots I knew it was going to sound horrible but I was just really curious to find out lol. Luckily I have a set of Magnaflow mufflers and tips going on this coming Monday.
    IE Stage 1 | CTS Intake | Catless DP's | TGK Motorsport Dumpbox
  36. #196
    Senior Member Three Rings cssullivan's Avatar
    Jan 02 2019
    MA
    +1
    +1 bump
  37. #197
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Thread Revival.
    I got the Cat eff code for Bank 2 last week and the change in exhaust tone. Car feels down on power intermittently which I think means its clogged and not blowing itself out. Full throttle give an misfire code on cyl 6 and EPC so I've been driving it easy. I Plan on trying to gut it this Sunday. Do I need to gut both at the same time? Is one gutted going to be a problem performance wise? Stage 2+.
    *2013 B8.5 S4
    APR Stage 2+ ECU/TCU 100oct Tune, JHM 187mm CP, Injen Intake. Stasis Touring Exhaust/ Springs & Rear Sway Bar, PLM HX.
    11.468 @ 122.06mph. 90ft DA. *Totaled* RIP
    2016 B8.5 S5 Prestige - APR Stage 2+ ECU/TCU 100oct Tune, JHM 187mm, modded stock air box (Loe mod!), PLM HX, OE Springs, Stock Exhaust.
    11.264@ 124.46. Best MPH 11.269 @ 125.13
  38. #198
    May 01 2017
    Seattle/WA
    if you are making the effort to gut one, then do the other and thank yourself later :)
  39. #199
    Dec 18 2007
    PNW | Monroe, WA
    Quote Originally Posted by SCHOUGY View Post
    Yes very true but one side comes out easy the other (passenger if my memory is correct) is a pain in the a$$ to drop as it doesn't clear the tranny unless you to JHM method and pull the tranny out of the way with a heavy duty strap. Need to a lift to do that.
  40. #200
    Senior Member Two Rings BigKeshy's Avatar
    Jun 01 2017
    West Orange, NJ
    If you're on jack stands/ramps/quick-jack/etc. you can run the heavy duty strap around the bottom of your B-pillar. Just put a towel between the strap and the paint and make sure the ratcheting mechanism is somewhere on the underside of the car so you don't scratch anything up.
    It's not ideal the way a lift would be, but it does work and shouldn't cause any instability in the car when it's lifted off the ground.
    2013 B8.5 S4 MT
