Page 2 of 9 FirstFirst 1234 ... LastLast
Results 41 to 80 of 348
  1. #41
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Quote Originally Posted by whiped View Post
    I wouldn't do that. I'd remove the 02 sensors and spray some water that way.
    I'm in for results Alex.
    I'd be willing to try something weird. 117k on my factory cats, they've got to be close to dying with all the weird crap I've thrown at them.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
  2. #42
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    be careful...a long-block isn't inexpensive by any means guys.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
  3. #43
    Jul 05 2014
    Houston
    I still like my idea of sticking an industrial strength roto-rooter up the tail pipe.
  4. #44
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Loe View Post
    I hear you, I wouldn't dump anything directly down into the cylinders.
    I'm curious if my cats are starting to go, no white puffs or CELs yet but my exhaust note has changed and I have more drone than I used to
    Unrelated, if anyone has their OEM cats laying around or are going to toss them out you should totally ship them to me
    If you pulled off the exhaust at the downpipe that might work Alex. Issue is there is a bend in the cats so you wouldn't have direct access without removing them from the headers.
    Geoff
  5. #45
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by fitzydude View Post
    you'd be surprised how much abuse they can take though, and even partially clogged the volume is still sufficient for a nice clean 1/4 mile MPH. With that being said, there is something to be said about EGT's (read lower) when you run higher ignition advancement, or at least that's what old hot rodders used to say...something about earlier spark timing in the up-stroke lessens the heat escaping out of the exhaust valves due to the ka-boom event happening sooner and more full (but not to the point of pre-detonation, which creates heat). Not sure how true this is? but I heard it from a guy who knew a guy who purchased a thing in a dark alley...
  6. #46
    Doing some logging with my OBD Fusion app. And was looking at the EGT's, and mine range from 1100F at idle to 1500F at wot. Seem about right? Couldn't find any info on it. Note: I run full E85.
  7. #47
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Friends 2012 s4 at 75K just went out, tuned for the last 10K
    There are 10 kinds of people in this world, those who know binary and those who don't.
  8. #48
    May 20 2004
    Las Vegas
    My drivers side cat went first, then replaced with magna flow, 2 weeks later my motor seized, I think it was all due to running E85 mixture all the time, car run's to hot, I was addicted to race mode for 2yrs..lol!
    2010 S4 Ibis Prestige DSG w/ Sports Diff / Stage II V2 & DSG Tune by GIAC / Avant Garde F522 20x10 / Vogtland Coilovers / AWE Touring Exhaust / RS4 grille by ECS / Roc Euro Intake / Alu Kreuz / Carbon Style E-Codes / Brakenetics Cross Driled Rotors / Toyo Proxes T1 Sports 245/30/20 / 034Morotsports Trans Mount /
  9. #49
    Junior Member Two Rings FLN2LO's Avatar
    Jun 27 2015
    Springfield VA
    Well i think i just joined the club today. Did a full throttle run this morning that felt great but i looked back to see a massive smoke screen. First thought was a head gasket but upon further inspection my coolant was good and looking at the oil it wasn't milky (as i've seen on other cars with a head gasket issue). A couple more hard pulls and more giant clouds of white smoke later i noticed some rattling coming from the exhaust. I took a look and on one side only the exhaust tips were coated white with chunks of metal sitting in them and on the ground under the exhaust tips. Clearly the honeycomb of the cat.
    So.. here i am at 78,500K and as i understand it there should be an 80k Cat warranty.
    Anyone have luck getting warrantied for cats even though their car is chipped?
    2012 (B8) Ibis White S4 -- APR Ultracharged -- Mad by Design ported SC -- ECS Intake -- APR DSG TCU - 034 Tranny Mount - EuroCode Alu Kreuz, Sways and Endlinks -- Stoptech 380mm
    Best 1/4 Mile 11.9
  10. #50
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Quote Originally Posted by FLN2LO View Post
    Remove the tune. They scan. Will also probably check your PCV
  11. #51
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    I think I joined the club today. Did a long pull. Exhaust is noticeably louder.
  12. #52
    Established Member Two Rings <3S4PLAY's Avatar
    Mar 24 2015
    Bay Area
    An update on my car... I was able to get the dealership to replace my passenger cat under warranty, but they definitely tried to put up a fight before finally giving in and replacing it.
    I can say that they were not able to detect that I had a tune on my vehicle. I had the ECU and transmission flashed back to stock prior to going in.
    Honestly it appears that this is becoming a more common issue with this platform. It'll be interesting to see how this plays out with more people going to the dealership with cat failures.
    The dealership that I went to admitted that they had taken in 6 other cars in the past 3 weeks after approving my fix under warranty. The cars included Q5s and A6 with the 3.0t supercharged engine
  13. #53
    Nov 02 2016
    New England
    Quote Originally Posted by <3S4PLAY View Post
    So what mods and for how many miles? Dual pulley? How many miles tuned at what levels?
  14. #54
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Were the others cars tuned, did they say?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
  15. #55
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    [QUOTE= did they give u and shit cause u had the aftermarket exhaust? And what dealership in the bayarea ?
  16. #56
    Mar 24 2015
    Bay Area
    Quote Originally Posted by xxdunnxx View Post
    I was 034 stg 1 for approximately 10k miles and then 034 stg 2 for approximately 30k miles, before the cats failed at 63k miles
    - - - Updated - - -
    Quote Originally Posted by cspcrx View Post
    The Q5's and A6's that were at the dealership with failed cats were all stock
  17. #57
    Mar 24 2015
    Bay Area
    [QUOTE=Rodizzle;12502057][QUOTE= did they give u and shit cause u had the aftermarket exhaust? And what dealership in the bayarea ?
    Sent from my iPhone using Tapatalk[/QUOTE]
    I left the exhaust on the car and they tried to blame the "smell" from that. I explained to them that I personally installed the exhaust myself and it had been on the car for over 50k miles and that nothing had changed since.
    Dealer tried every excuse to not want to replace the cats. The smell was so bad that I would almost pass out during a 30 minute drive. They said that's normal with an aftermarket exhaust. They then went on to say that the smell is because I had an exhaust leak somewhere downstream way past the 02 sensors, and that the CEL was on because the o2 sensor was detecting the exhaust leak.I ended up having to draw a diagram of the exhaust system and argue with the "master tech" and service advisor on how and where the o2 sensors function before they agreed to fix the issue.
    This was at Concord Audi, the dealership I purchased the vehicle from.
    After the vehicle was fixed, they asked if I tried to hollow out the cat, because the passenger side was completely gutted. If you have seen the shape of the catalytic converter you would know that it's almost impossible to hollow out perfectly. The techs didn't bother checking for pieces of cat material in the exhaust. When I got home I took apart the whole exhaust and shook out a bunch of moon rocks from the mufflers and midpipe
  18. #58
    Dec 19 2010
    North CA
    Due to Cali laws, you are good to go on cats up to 80k. I just passed 80k and yet again I pulled a chunk out of me exhaust lol. Sigh.
  19. #59
    Jan 04 2013
    Phoenix, az
    hard for them to blame exhausts and tunes when stock cars are having issues. All about saving money! They are already in enough heat with the EPA you would think they would not want to draw extra attention with stuff like this.
  20. #60
    Active Member Two Rings Mt_S4's Avatar
    Jun 20 2016
    I'm looking to try gutting my cats without removing them of the car, the roto-rooter seems to be the perfect tool since you can put different ''drill bit'' on it.
    Anyone have tried it ?
  21. #61
    Jun 17 2015
    Bayarea
    Quote Originally Posted by Mt_S4 View Post
    Call me crazy , I thought the same thing . Sounds like it might just work . Drop the down pipe and rent a rotor rooter from homedepot for 40 buck .
  22. #62
    Jan 04 2013
    Phoenix, az
    They may not be able to apply enough torque to brake up the catalyst.
  23. #63
    Jun 17 2015
    Bayarea
    The Official Blown Catalytic Converter Thread
    Trust me that shit breaks everything !!! broke my plumbing pipes. Made my stuck turd even worse of a problem
  24. #64
    Senior Member Two Rings Gtotherock's Avatar
    Aug 17 2013
    Naples/Florida
    Looking into aftermarket test pipes. I'm in Florida, and no one cares about running cat less here. Any brands that you guys have heard good things about or recommend? I don't want high flow cats but rather test pipes. I've looked at JHM, until I heard through some friends that their test pipes aren't very good. But maybe those friends are morons!?
    Any info, of different brands of test pipes, is much appreciated.
    2014 S4 Estoril blue | DSG | Sports differential | B & O | MMI | Nappa
    EPL Stage 1 ECU and TCU tune/Stage 2 SP in the works
    034 subframe inserts | 034 transmission mount and insert | 034 differential inserts | Solowerks coilovers | ECS Luft-technik carbon fiber intake | 034 x-pipe | Alzor 084 19x9.5 gunmetal wheels
  25. #65
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    Tampa Autosports, formerly Crown Motorsport via Evan Doel can provide you with test pipes. That's what many in the community are running without issue.
  26. #66
    Jul 19 2016
    Los Angeles California
    Quote Originally Posted by GandalfTheIbis View Post
    I was planning on obtaining these as well. Do they need to be ceramically coated?
  27. #67
    Aug 17 2013
    Naples/Florida
    Thanks GandalfThelbis
    Only a few hours away.
  28. #68
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Quote Originally Posted by SN0101101001 View Post
    They don't need to be, but Evan can have them coated upon request.
    2016 S6
  29. #69
    Aug 09 2015
    Sarasota, FL
    another vote for Evan @ Tampa Autosports, the pipes are top-notch
  30. #70
    Aug 17 2013
    Naples/Florida
    Will having an exhaust shop gut my stock cats, act as a test/race pipe in terms of power gains? I live in Florida, they don’t check cars for emissions here. Thinking of hitting stock cats and running straight pipes to my 034 x pipe and straight pipes all the way to some Milltek exhaust 2to1 100 mm tips. And yes, I know this will be very loud!
  31. #71
    Aug 17 2013
    Naples/Florida
    Gutting stock cats*
    Damn you Autocorrect!!
  32. #72
    Established Member Two Rings alarum_78's Avatar
    Dec 10 2012
    2007 VW GTI, 2018 GOLF R, 2010 Audi S4
    Ontario
    Getting my passenger side cat replaced at the dealer under warranty, didnt know the job involved dropping the transmission. I am worried the other *driver* cat will go soon. Warranty is done in 4 months on my 2010 S4.. Totally stock @ 83500km.
    2010 S4 Quartz Grey, Sport Diff, Nav, Magma Nappa, 19" Peelers, S-Tronic.
  33. #73
    Jun 17 2015
    Bayarea
    Quote Originally Posted by alarum_78 View Post
    Same boat as you , I got my driver side replaced at 48k ( stock ) . Now at 58k on a Dp set up , just waiting for the left to give out .
    What were your symptoms prior the replacement of the cat ?
  34. #74
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Quote Originally Posted by Gtotherock View Post
    I couldn't imagine it being much different whatsoever.
  35. #75
    Veteran Member Three Rings bayonet14's Avatar
    Aug 07 2013
    BMW 335i
    Pinelands NC
    Have some b8.5 cats laying around that have 20k stage 1 on them ;) i will sell em
  36. #76
    Feb 23 2016
    Chicago
    Quote Originally Posted by bayonet14 View Post
    How much?
    APR Stage 1, APR CPS, ECS Intake
  37. #77
    Dec 10 2012
    Ontario
    Quote Originally Posted by Rodizzle View Post
    Engine light, pulled a P0420 code, started noticing a rattle in the exhaust and powdery white debris sitting in the exhaust tip.
  38. #78
    Aug 07 2013
    BMW 335i
    Pinelands NC
    Quote Originally Posted by PopTart View Post
    How much?
    PM me
  39. #79
    Jul 22 2007
    Southwest
    Federal Emissions Warranty covers the Cats for 8 Years/80K Miles. Hopefully everyone that blew them took advantage of this. I just did for the 2nd time.... ugh.
    https://www.epa.gov/air-pollution-tr...nd-air-quality
    Thanks,
    Andy
  40. #80
    Jun 10 2015
    NE
    Quote Originally Posted by AndrewF1 View Post
    As long as the car is stock, this is a great PSA for everyone with this issue.
    2016 Audi S6
