Originally Posted by
coop3422
Leaving the pass through open isn't an option as I have a baby seat in the back. My W3 honestly sounds like garbage, but I feel it must be a tuning issue. The installer kept the amp all at min and just turned up the LC2I, saying that's how to do it. After a couple months, I dialed the LC2I to min and tried tuning the amp to no improvement. I tuned the 4ch in my s2k with front components and bridged to my sub and it sounded incredible with my shallow JL. The thing hammered, low and deep so you felt it. This current setup (A6 w/ Bose) sounded like muddy crap that would give you a headache. Next it'll be going into my B&O S4, but I'm not confident it'll sound like what I want.
Do I get to ditch the LC2I for something better? My understanding was the only reason I got the LC2I was to convert the factory signal, so the amp could do its thing and send the power to the sub. This is the first time I've integrated into an OEM system, all my prior cars I just ripped the factory crap out and replaced it all so this was never an issue.
Sent from my SM-G973W using
Audizine mobile app
the lc2i is generally fine but i haven't' noticed bass rolloff on our cars but i have not measured and i don't know anyone that has. one thing to note is the lc2i has a non-defeatable 33hz subsonic filter with a steep 18db slope, so you are missing the lowest notes and i could definitely tell even running 1 10 in infinite baffle. this subsonic is needed for ported enclosures but not sealed.
depending on your specific amp model you can look up the input voltage range, if it can take up to 11 volts input you may be able to bypass the lc2i but in my experience this results in too high of a volume even when the gains are all the way down so first try this:
reverse the positive and negative on your sub. if the sub is out of phase it can sound muddy. if switching this makes it better then congrats, if it makes it worse change it back
check what the crossovers on the amp are set to, maybe post a picture. you can turn down the low pass crossover incrementally to get rid of some of the higher 100-120hz frequencies the oem sub seems to play, many cross their sub around 60-90hz, you can play with this knob and find what you like you won't damage anything.
make sure the accubass feature on the lc2i is completely off, i don't know which direction to turn the side knob between the two sets of rca's to turn it off is you will need to look it up. turn the accubass main knob all the way down as well.
now you need a multimeter, they are $5 at harbor freight. set your multimeter to ac voltage, and disconnect your sub from the amp.
download a 40hz test tone track or stream one from wherever, best to download.
turn lc2i bass and main knobs all the way down
if using the remote knob on the lc2i turn the remote knob all the way up (we are trying to find max safe volume here that you never want to be able to go over)
play some music and find your max listening volume that you won't be turning it up over (turn gala off or go for a drive as gala substantially increases bass/midbass while driving.
play the test tone at that volume level
turn the lc2i all the way up to where the maximized light is just turning on, then back it down to where the maximized light is not coming on at all, you have plenty of amp gain to play with and that maximized light means "distortion" you never want it to turn on in reality.
now on your amp turn your amp gain up to where the amp outputs , when read with multimeter, match the target voltage to be 500 watts which is what your sub is rated at i think (check your subs rms voltage, it isn't 700 like your amp i don't think).
at this point you've found max volume, this volume may not match and the sub may over power the mids but you can use the lc2i knob to lower the level to match your listening level and turn it up for rap, and it will affect all frequencies the same. the amp bass knobs are normally for bass boost at 40hz which may or may not be preferable for you.
