Page 29 of 42 FirstFirst ... 19272829303139 ... LastLast
Results 1,121 to 1,160 of 1653
  1. #1121
    Junior Member Two Rings mia748sp's Avatar
    Mar 11 2016
    S5, A3, Ducatis
    GA
    Quote Originally Posted by EyeCentric View Post
    Any one else have thoughts on this?
    Sent from my PH-1 using Tapatalk
    It all depends on the amp you're using and the range of input voltage it can take. I was using a JL XD amp (200mV -8V) tapped straight from the sub to RCA with no issues until I decided what direction to go for audio upgrade.
  2. #1122
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    I had a lc2i and hated it. The low end bass cut was why too high so if you like to listen to some heavy bass songs you wouldn't hear the full range. Not to mention it had a weird setup on how it would equalize each frequency. Some tone would blast the sub and others were unheard. Everything about the lc2i just seemed cheap. Not to mention the time delay it created drove me crazy. I finally pulled the lc2i out got a rca to wire kit so that the everything went direct to my amp. Sound so much better now. I should have done this from the start I just didn't realize my amp supported it.
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
  3. #1123
    Feb 06 2018
    Central VA
    Quote Originally Posted by mys4.org View Post
    I finally got around to tossing my 10" sealed box with Polk sub and RF Punch 150w amp in. Easiest install in the automotive world, everything is right there in the trunk. Signal sense amp turn on and high level connection straight into the amp. For now I left the stock sub as is. To my ear it's just now a full sound all the way down to 30ish hz.
    2014 S4 Phantom Black Pearl P+ / B&O / Sports Diff / MMi
  4. #1124
    Dec 18 2007
    PNW | Monroe, WA
    Quote Originally Posted by gamatt View Post
    150w amp that is barely more than stock. I'm surprised you can hear it... But if it works for you that's cool.
    I'm running closer to 700w rms so you notice imperfections a lot more.
  5. #1125
    Sep 21 2017
    Merrick NY
    Could anyone tell me if Alpine makes a compatible unit for my 2014 S5?
    Presently I have a Concert series MMI 3G which came stock.
    Or, any other recommendations for a head unit, I壇 like to have car play and decent Nav.
    I tried searching but 1124 posts are in this thread and I知 not sure I知 searching correctly.
  6. #1126
    Veteran Member Four Rings PeteRock's Avatar
    Mar 08 2017
    Chicago
    Quote Originally Posted by Surfer8210 View Post
    Not 100% sure if this unit is available for purchase in the US but I thought someone may have posted about it before....
    https://www.alpine-electronics.se/p/...eView/X702D-A5
    Pete
  7. #1127
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by PeteRock View Post
    Pete
    seems like the upgraded to Version 2 now. Surely it is tempting, but somehow, I think I would have regret loosing the OEM-look of the car. Weird feeling I know! I love ''OEM'' look, and I would hesitant to replace the single DIN slot of the B&O command for the Alpine one. If it was only the screen, I would be more interesting to do it I think. Nonetheless, PROPS to Alpine for developing a solution !
    S4 B8.5 no track, just enjoying spirited driving.
  8. #1128
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Hey guys,
    I'm at a loss so I figured the stereo experts might be able to shed the light on my issue. I have a B8 with B&O with symphony interface. I upgraded to B&O MMI 3G+, all parts, except the new used B&O amp (MOST version) came from a reputable seller. Amp from eBay. My sound for radio, media, navigation, and calls almost never works. Occasionally the display doesn't come on and the MMI stays off.
    Can someone lead me in the right direction? Which unit signals the other to turn on? I believe I've read this is how it works. I have a new head unit but am starting to think thats not the issue. Is the Amp the key component for all of the sound?
    Sorry to highjack, but this is getting ridiculous.
    Thanks
  9. #1129
    Sep 21 2017
    Merrick NY
    Pete
    Thanks Pete,
    I saw that option earlier, I believe that it痴 available on EBay. It needs to be ordered from Italy.
    Reviews are great but I知 hoping that I知 able to find something similar to check out also. I was surprised to see that this was Alpines only offering for the S5痴, in fact they don稚 even mention S5痴, just the A5.
  10. #1130
    Feb 06 2018
    Central VA
    I have the amp crossover at the low setting which I think was 80 or 90hz and below, so all I'm asking the sub for is to fill in the lower stuff and it's a night and day difference.
  11. #1131
    Thanks Pete,
    The X701d, and since updated X702d are made for vehicles that didn't come with Nav (optical). My guess has always been because it isn't able to properly send the commands to the factory amp over optical. With that said, if you replace the factory amp also and use your new pre-outs, this may work. A quick call to Alpine Europe will confirm this.
    This unit is one of the reasons I intentionally didn't get my car with nav or backup camera. It's fantastic.
  12. #1132
    Dec 19 2004
    Quote Originally Posted by Drunktank View Post
    Do you actually have this unit installed? If so, did you have the B&O without Nav prior?
    2011 B8 S4 | EPL Stage 2 | KW H.A.S. | APR Stage 1 & 2 Carbonio Intake | Borla Exhaust | Eurocode Alu Kreuz | Eurocode ワSS Stabilizer Bars and End Links | 034 Motorsport Trans Mount Insert | Spulen Rear Differential Mount | Hartman RS 4 Wheels
  13. #1133
    Yes, i致e had it installed for a couple years now, and yes, B&O without nav.
  14. #1134
    Dec 19 2004
    That's interesting. Can you answer a few questions on the install:
    • How did you get US maps on it?
    • It looks like it has a separate trim piece. How does that fit since US cars have a combined airbag light/hazard switch?
    • Was it plug and play or is coding required?
    Thanks
  15. #1135
    Mar 14 2016
    TheFarEast
    hey guys, just a quick qns.
    I'm exploring moving the stock amp unit to the spare wheel, reason being to fit a custom sub woofer enclosure on the left side of the boot.
    Are the stock cables long enough to facilitate this?
  16. #1136
    Mar 08 2017
    Chicago
    Quote Originally Posted by ReDeViL View Post
    You don稚 want to put it there....there痴 room to relocate the amp and MMI unit to the upper driver side corner of the trunk....see below.....
    Pete
  17. #1137
    Mar 14 2016
    TheFarEast
    Pete
    Thanks for the guide!
    Is that a custom mount? I am assuming that this is achieved via drilling into the car body?
    Sent from my Pixel 3 using Audizine mobile app
  18. #1138
    Mar 08 2017
    Chicago
    No drilling....just heavy duty double stick velcro and some dynamat in between the components and the body panels to eliminate any vibration
    Pete
  19. #1139
    Mar 14 2016
    TheFarEast
    Pete
    got it!, thanks for the help!
    very much appreciated.
  20. #1140
    - You just download the maps onto a laptop and upload them to the unit, it's like $50 or so.
    - The US buttons are shrunk down to the size of the single EU hazards button. If you looked up the OEM part, I'm sure they would be the same #.
    - Plug and play. It plugs into the canbus and takes care of everything, including your nav button now working and the hands free button functionality with Siri, etc.
    This unit works with left and right hand drive, and Q5's, so the model you want is the X702D-A4L. You'll also want to get the replacement trunk handle which the camera mounts to, and get a nice 180' backup camera. If you have B&O and you want to keep that amp, you'll also need an adapter to avoid some static. This also allows you to completely remove the B&O amp without any errors.
  21. #1141
    Established Member Two Rings mrebusa's Avatar
    Oct 14 2014
    2014 A4, 2021 RS5, 2021 ZX14R
    Ohio
    After sifting for the last couple hours I am overwhelmed with options and needing this or that. I guess I am looking for a definitive option that would increase bass and quality over the factory B&O.
    Details:
    15' S4- B&O- 3G MMI
    What all is needed to buy to throw in a 10" high quality sub and amp and ensure it works with all the rest of the B&O speakers (open to recommendations for sub/amp). I was planning to put it in the factory location with the dynamat on the rear deck. Sorry for the redundant question, just looking to do this right the first time.
    17' R8 V10 Plus
    13' Q5 S-Line
    23' Blazer
  22. #1142
    Mar 21 2015
    ^ If you plan on using a high quality sub and amp then you need to mount the sub in a box in the trunk. The rear deck isn't going to cut it. You would just need an amp with line level inputs, sub, box and a amp wiring kit along with some miscellaneous connectors. You could leave the sub in the deck with it disconnected or remove it and dynamat the deck to keep it quiet.
  23. #1143
    Oct 14 2014
    Ohio
    Thank you for the answer, I think I'll end up doing the box as you suggested. What is the sub of choice folks are using these days?
    17' R8 V10 Plus
    13' Q5 S-Line
    23' Blazer
  24. #1144
    Feb 12 2017
    Redmond, WA
    Does anyone make 3d printed or otherwise custom adapters for the AP8s or something similar that would work?
    Sent from my SM-G955U using Audizine mobile app
  25. #1145
    I've used a JL 8" (great compliment for an otherwise factory stereo and can overpower it) and now a 10" Audison since I have upgrades the rest of my speakers to keep up. Volume requirements were a big factor in both decisions.
  26. #1146
    Jul 22 2014
    MS
    Can anyone comment with any degree of certainty whether or not adding a sub and amp will introduce some delay in the subwoofer response? That is, does the sub hit a few ms later than the factory set up?
    If so, is it significantly noticeable? I'm used to tinkering with time alignment/signal delay on my old setup, and if it is noticeable I feel like I'd be annoyed since I couldn't change it.
    Otherwise I'm just going to start by replacing the factory sub which is already time-aligned with the rest of the system. A DSP is the step after that but, you know, $$$.
  27. #1147
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    never noticed a delay or an odd sound
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
  28. #1148
    Feb 12 2017
    Redmond, WA
    Quote Originally Posted by techracer View Post
    Anyone?
  29. #1149
    Feb 06 2018
    Central VA
    Quote Originally Posted by Leviathan05 View Post
    Me neither and so far I have left the stock system completely as it was, for me the sub just seamlessly enhances and extends the bass response. I have a 10" Polk sub in a sealed "truck" box and a Kicker 150W amp.
  30. #1150
    Anyone?
    Sounds like you're on your own. That kind of thing really wouldn't get enough volume to make the project worth it, and people would just complain if they were $99.
    Time to grab your router and circle jig!
  31. #1151
    Veteran Member Three Rings Strong Man's Avatar
    Jan 24 2017
    Anyone?
    I don't understand why you're looking for 3-d printer etc. Two peaces of wood, wood glue, Jigsaw and 30 minutes of the job . That's all what you need.
    2013 Audi S5 3.0T: Custom Audison with B&O, Quattro Sport Differential, ADS, 7-speed dual-clutch DL501
    Mods: ||ST2: Unitronic ECU + TCU + Ported SC & Throttle||Intake: ESC Kohlefaser Luft ||Exhaust: AWE Touring with Resonated DPs 102mm tips||Susp:CR15, Alu K, H&R OE, H&R R Sway Bar, ECS Drv Mnt Insert Kit ||H&R Spacers: 15F/20R || Brakes: ECS SS Lines, StopTech BBK Creo Slott Rotors F/R, HAWK 5.0 F/R, Motul 600 || etc.
  32. #1152
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Router, circle jig and some plastic. Done in a couple hours.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
  33. #1153
    Feb 12 2017
    Redmond, WA
    I like the plastic option, where do you source it?
  34. #1154
    Sep 06 2014
    Ottawa, Canada
    The definitive stereo and subwoofer upgrade thread
    I got it from a local plastics supplier. I forget what it is called but think of cutting board plastics, that's what it is made of. (it's NOT ABS or Acrylic) I made a template out of 1/4" MDF, then used that to cut the plastics with the router. The plastic is made up of two pieces, one 1/4" and one 1" piece. Because of the type of plastic it is, it needs to be screwed together, glue won't hold it. If you do this with a router, be slow with the depth. The 1" piece I had to take multiple passes around as the bit was trying to take to take chunks out of it if I tried to take too much off on a single pass. Take your time and it's easy to do a good job.
    I used plastic, since MDF will get wet, (it's inside a door) and it will swell and ruin over time. The plastic will not deteriorate.
  35. #1155
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    Quote Originally Posted by cybernet99 View Post
    Nice work!
    BMW M850i
  36. #1156
    Sep 06 2014
    Ottawa, Canada
    Thanks @fmzip! I'm in no rush, so want to take my time doing each of the pieces so I have no regrets when it is completely finished. I also want it to be of high enough quality that I would be able to compete in Car Audio competitions and do very well.
  37. #1157
    Feb 12 2017
    Redmond, WA
    If I had dimensions I'd 3d print some from a friend's printer. I am looking to put AP8s in the front since I'm using the stock amp
  38. #1158
    Nov 18 2016
    Lehigh acres Florida
    What ohms are the factory concert speakers? Looking to replace them soon.
  39. #1159
    Established Member Two Rings BillyS4's Avatar
    May 16 2017
    Not sure if i read this Correctly. I can disconnect my B&O Sub and connect the wires directly to my Sealed Box? Sorry if this is a stupid question. A lot of information going on here. Great Thread!
  40. #1160
    Feb 12 2017
    Redmond, WA
    In theory yes, but it likely won't sound good and will be underpowered.
