I added the Audison Voce 3. Being a data guy, I took a few before and after measurements to quantify the changes. All measurements are in 1/3 octave and no smoothing. I have a sub already which is clearly visible in the measurements.
First is the baseline, which has all sound settings at neutral.
[IMG]
[/IMG]
Second is the same speaker configuration adjusted by ear to match my desired performance.
[IMG]
[/IMG]
This is with the audison speakers installed.
First is the neutral setting.
[IMG]
[/IMG]
Second is the adjusted settings to my tastes.
[IMG]
[/IMG]
The overall sound has improved exponentially; unaltered, unveiled, etc. are accurate descriptions. The measurements show a 5db improvement @ 14kHz, an overall increase in output from 250 to 14k and negative impact at 160hz (a roll off difference between the stock and audison speakers).
Not visible in the static pictures is the audison’s smoothing improvement between 250-14k. The audison’s significantly reduced the peaks and valleys in the signal while the stock speakers had wide fluctuations.
I need to tune the sub and take a few near fields to determine the 160k drop and the complete lack of the top octave.
