Results 1 to 25 of 25
    Senior Member Two Rings Tidefan73's Avatar
    Sep 16 2016
    2014 Beetle R (Wife's), 2005 Nissan Titan LE
    F'Burg, VA
    Wheel/Tire Fitment
    Hi, all!
    I know there are MANY threads re: wheel and tire fitment, and I've read most of them.
    Looking for some confirmation about the following setup before placing an order:
    Current setup is:
    MY17 S6 w/ factory Black Optics and 15mm spacer. (I've been told those wheels are 20 x 8.5 ET45)
    VCDS lowered by 11mm.
    I'm looking to get the following:
    20 x 9 ET35 and run a 275/35/20.
    All of my research says that the outer edge should be close to the same location as my current setup.
    Can anyone confirm that a 20 x 9 ET35 with a 275/35/20 will work without any rubbing issues?
    Theron
    Took delivery 12/05/2016:
    2017 S6 Prestige | Daytona Grey Pearl | Black Optics | Sport Package | Comfort Seats | Carbon Inlay | EPL Stage 1 ECU/TCU | CETE ASC v2 | Signature SV304S 20x9.5 ET35 w/ 275/35/20 | BlackVue DR650S-2CH
    "I love this car!!" -Me
    Insta: Tidefan73_S6
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    That's a wide tire for a 9" wheel.
    Sent from my SM-G935V using Tapatalk
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Feb 25 2014
    Texas
    Does an ET35 wheel clear the massive brakes??
    The factory black optic wheel with ET45 barely clear the calipers stock. I put 15mm spacers on as well and it gives some, IMO, much needed clearance from the brakes. Can actually clean them now!
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Jan 05 2017
    Lakewood, CO
    Quote Originally Posted by brad281 View Post
    I agree with this as well. I had a 265 on a 9.5 rim and it looked great with no stretch at all. I'm not even sure a 275 will fit on a 9 inch rim at all. If you do get them on they are going to look like oversized truck tires.
    Sep 16 2016
    F'Burg, VA
    It is, but I've seen that size run before. Would you recommend going up to a 9.5"?
    Thanks! Never used that site before. Looks like it could be close, with the wheel well measurement, but I can always go up with VCDS if needed.
    Quote Originally Posted by AudiS4B8 View Post
    By adding the 15mm spacer, your Black Optics are now ET30 vs 45.
    Insta: Tidefan73_S6
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Quote Originally Posted by Tidefan73 View Post
    I would. I had 275's mounted on a 9.5" wheel on my Q5. I'm getting ready to order a set of 20x10 et40 wheels for my S6. 275's will seat perfect on those.
    Feb 25 2014
    Texas
    Right. Brain fart.
    10.65 @ 129mph
    Sep 16 2016
    F'Burg, VA
    Quote Originally Posted by Siouxbie View Post
    According to S4Per here http://www.audizine.com/forum/showth...1#post11635308, he's running the following and is the look I'm going for, but trying to avoid the 5mm spacers and the possible need to roll the fenders:
    Wheels: Audi RS6 replica, 20" x 9", 47mm Offset
    Tires: 275/35ZR-20 Michelin Pilot Super Sport XL (102Y)
    Insta: Tidefan73_S6
    Oct 28 2014
    Northern VA
    it fits fine, factory 20" RS7 Wheels are 9"wide
    2018 Ara Blue RS3
    Veteran Member Four Rings IowaRS7's Avatar
    Mar 22 2017
    69 Camaro SS
    Iowa
    Stock RS7 wheels are 21x9 ET 35 running a 275/30 tire. The RS7 (non ceramic) has slightly thinner brake calipers than an S7 though. Not sure about the caliper size on the S6.
    Oct 28 2014
    Northern VA
    buy a Cete ASC Module, you won't regret it.
    2018 Ara Blue RS3
    Sep 16 2016
    F'Burg, VA
    Quote Originally Posted by cobrario View Post
    On the list of things to be purchased over the next couple of months.
    Insta: Tidefan73_S6
    Feb 25 2014
    Texas
    I love the meatier tire stance
    10.65 @ 129mph
    Oct 28 2014
    Northern VA
    It's a hassle I know but my stock wheels are tires are sitting in a shop up here in Winchester, you're welcome to come test fit one to see if it works- 20x9 ET35.
    2018 Ara Blue RS3
    Feb 25 2014
    Texas
    Disagree. 265 is more ideal for 9" wheel but 275 will be far from a truck tire look
    10.65 @ 129mph
    Sep 16 2016
    F'Burg, VA
    Sincerely appreciate the offer, but getting out to Winchester isn't practical any time soon.
    Insta: Tidefan73_S6
    Sep 16 2016
    F'Burg, VA
    I just realized that my concern is focused on the outside of the tire rubbing, but what about the inside? In a full turn, is there any concern with rubbing?
    Insta: Tidefan73_S6
    Sep 16 2016
    F'Burg, VA
    Disregard...after looking at several size calculators, there shouldn't be any concern.
    Insta: Tidefan73_S6
    Jan 05 2017
    Lakewood, CO
    Everyone has an opinion and I fully respect that. I am just speaking from real world experience. Don't use any photos in your decision. Look at it in person and decide for yourself. A 265 on a 9.5 is very, very meaty. It just is sorry if that hurts any feelings. Also note, I usually run a Continental DW and if you're going to run a Michelin PSS the tread would actually be a half inch wider due to there design. So if a DW looks meaty its clear the PSS would just be that much more.
    Oct 28 2014
    Northern VA
    no worries, the offer is there if you need it.
    2018 Ara Blue RS3
    Sep 16 2016
    F'Burg, VA
    Thanks again!
    I've decided to go with 20 x 9.5 ET35. If the 275 happens to be too wide and poke out of the fender, I'll drop the tire size.
    Insta: Tidefan73_S6
    Feb 25 2014
    Texas
    Post pics!
    10.65 @ 129mph
    Sep 16 2016
    F'Burg, VA
    Post pics!
    Will do!
    It'll be a couple weeks.
    Insta: Tidefan73_S6
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    Here's my 275 35 conti DWS on stock 20x9. Fits fine, no rubbing and doesn't look much different from stock 265 35. We're talking about a 10mm /.39" wider tread. Not a big deal.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
