Results 1 to 32 of 32
    Veteran Member Four Rings SharkNardo's Avatar
    Mar 16 2007
    Richmond, VA
    How's an RS4 as a track car?
    Hey all, I've been an A6 (2 C5s and 1 C7) and Porsche (993) guy for years. I'm interested in putting a track car together to take advantage of 2 great road courses near me (VIR and Dominion).
    There's a lot of choices for a track car, but I've always been fond of the B7 RS4. I have some familiarity with the 4.2 motor having had a variant of it in my C5 4.2 A6. How are they as track cars? With the V8 weight on the front end, how do they handle? How does the motor hold up? Any weak points? I know the B7 platform has a lot of aftermarket support, is there good aftermarket support for the RS4?
    Just trying to get an idea if the RS4 is a good choice for a track car...any insight would be helpful...thanks!
    Other Cars
    2018 Golf R
    2019 Golf Alltrack SEL
    2016 Jetta GLI
    Previous Cars
    2019 RS5 Sportback
    1998 Porsche 993
    2015 A6 3.0T
    2004 A6 4.2
    1999 A6 2.8
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Although I imagine the RS4s are fun cars, I anticipate you could make better choices for a strictly track car. The V6 alone makes the front end of my car heavy and the front tires constantly SCRUBBING. I can only imagine what the extra 2 cylinders would do. Although I would not dare compare it to the 911, I anticipate it is the opposite of the rear slide happy 911.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Three Rings USAFS4's Avatar
    May 05 2008
    2008 Audi RS4; 2017 BMW M240xi Dinan stg 1
    PCC Potomac/Chesapeake
    I took mine to Summit Point last fall and was amazed at how nimble the car was through the tighter corners. Engine and stock brakes with upgraded pads did well also. At the limit it will push. Also, the tires held up really well. My B8 S4 would scrub the hell out of the fronts but the RS4 had very neutral wear. If you want a DD that is fun at DEs it's not a bad choice. But if you take your track driving seriously than it will limit you at some point, and the needed upgrades to go faster are more expensive than picking another platform.
    2008 B7 RS4, Jackal Tune, w/JHM spacers and Flap Delete
    2012 B8 S4 Stg II APR. SOLD.
    2000 B5 S4 (Audry) Stg III: 390Hp & 435Tq. SOLD. Wish I kept it!
    Jan 28 2016
    San Mateo, CA
    I track my RS4 regularly with the AudiClub. It's an absolute blast and it's an extremely capable car that will take me a very long time to fully explore before my driving skills catch up! Obviously, it's a front-heavy car (and a heavy car in general) and it will understeer badly if you overdrive it. It's a car that will rewards a smooth and precise driving. If you try to muscle it around, it'll fight back and destroy your front tires.
    As mentioned above, upgraded brake pads are a must, and if it's time to change your rotors, upgrade those too (StopTech makes good two-piece rotors, which means you can just replace the rotor rings when they're worn out at only about half the cost). I also recommend a stiffer rear sway bar (034Motorsport makes a good one) to help the rear rotate and reduce understeer, as well as adjustable control arms (again, 034) so you can dial in a bit of camber at the front.
    Mechanically, the engine is very strong, and you really don't have to worry about much there. No weak points other than the normal, often mentioned maintenance items of the RS4: carbon cleaning, intake runner flaps, and regular oil changes.
    After that, tires are what make the biggest difference, but that's a department that is up to personal preference. Michelin PSS work great and will have reasonably good lifespan, even with track use, but you have to watch out for pressures and compound temperature or they'll destroy themselves rather quickly. Some folks also run Bridgestone RE11 or Toyo R888 or T1S. I now have a different set of wheels for the track (lighter, 18"), mostly so I can run slicks.
    With all that said, I don't know that I would buy an RS4 specifically to make it a track car, unless you're loaded. It's an expensive car to maintain, and taking it to the track certainly doesn't help the wallet. It does force you to keep the car in tip-top shape though. If you're looking for a track toy, I feel like there are much better options. But the RS4 is indeed a very special car, that's a pleasure to drive both on and off the track, and I certainly would be the last person to not recommend owning one :)
    Feb 24 2010
    And have never been happier
    Rs4 is beast of a ride and heck of a lot of fun even with it's quirks.
    To each their own; imo it is a ridiculously expensive track car to maintain considering that if you spend the same amount on a different car, you would end up with better results (track times) and so on.. While rs4 does have support from quite a few vendors, it does not come close to the support some other cars have and the knowledge that comes with having a larger audience - something you learn the hard way with rs.
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    All that rs4max said!
    Yes we can buy newer, more adept, more agile and capable cars. But there are still some teeth in the old dog!
    https://youtu.be/M4LHOskUPes
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Mar 16 2007
    Richmond, VA
    Great info, thanks all...think I will consider another platform based on the comments...RS4's still rock though
    Other Cars
    2018 Golf R
    2016 Jetta GLI
    Previous Cars
    2019 RS5 Sportback
    1998 Porsche 993
    2015 A6 3.0T
    2004 A6 4.2
    1999 A6 2.8
    Jan 28 2016
    San Mateo, CA
    Quote Originally Posted by MattboyR32 View Post
    Nice! I wasn't at AudiFest last year (I find that event a bit expensive to attend). What other Audi events have you done? Not that many RS4s out there! I was at Thunderhill for the Winter Driving Event earlier this year, in the rain, and that same black M4 and I were having a lot of fun :)
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    They're difficult to trail brake into corners because of the propensity to understeer. They have great mid corner handling and even better corner exits because of the AWD, but turn-in is not particularly great because of all the weight over the front of the car.
    Basically, you have to get all of your braking out of the way in a straight line rather than try to use trail braking to rotate the car into the corner. Big difference from other quick-ish cars I've driven.
    Consumables will be expensive because it's a heavy car. Tires aren't terrible but brakes are quite expensive and the car uses them up quickly. The stock calipers are quite good (unlike, say BMW M cars), no fade with the correct pads and fluid. The car itself should be very reliable on track, it will just cost a lot to run HPDE with.
    It's not a bad car and the limits are quite high, it's just heavy, which makes it a less than ideal track car.
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Senior Member Three Rings pule333's Avatar
    Jan 14 2013
    Mi4cxl
    london/UK
    I track mine. It's brilliant with some mods. But. Very heavy! Consumables are expensive! Not ideal track car but very capable indeed! A lot of fun! And you can't beat a V8 :)
    https://youtu.be/xoyu64R0l94
    Vorsprung durch Technik
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by wednesday View Post
    Well said.
    FRRG AZ Ring
    Mar 26 2007
    Colorado
    Having driven an RS4 and E90 M3 back to back.... I would steer towards an M3 all day long. The motor isn't as far up as the RS4 and I believe it the center of gravity is even lower in regards to the motor. I love the RS4 as a family sedan, but personally feel it is a little too nose heavy (but everything feels nose heavy after owning a porsche )
    My vote would be an E92 M3 or oposite spectrum... C6 Z06's are insanely capable track cars as well. My good buddy has one
    CURRENT:
    2021 Atlas
    Nov 28 2006
    Quote Originally Posted by pule333 View Post
    Cool vid. How did you mount your camera?
    Apr 07 2016
    Homeless
    Mario took his 1000hp rs4 to a track day and got kicked off the track for going to slow. No longer welcome back. Probably not the best example to use but I'd say they are pretty decent and fun cars to track as long as you're not a ****.
    #Kennyleaks
    Mar 11 2008
    B7RS4 & e46Ms
    Watch the throttle level <5k rpm. This video shows the limiter quite well.
    FRRG AZ Ring
    Jan 14 2013
    Mi4cxl
    london/UK
    One more to the kitty :) https://youtu.be/QxYrcLP1kQs
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Question, what do you use for the telemetry input on the video?
    Ps: Great noises and driving!
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Jan 14 2013
    Mi4cxl
    london/UK
    Quote Originally Posted by ven0m View Post
    Harrys lap timer with KIWI3 obd dongle
    Nov 28 2006
    Need a pic of ur camera mount setup pls!
    Jan 14 2013
    Mi4cxl
    london/UK
    Just like that
    Nov 28 2006
    Awesome. Pretty huge clamps. The picture is rock steady though. Nice seat setup! Waiting for the next oreca store sale to pick up some omp seats. Nicely done.
    May 10 2015
    Slovenia
    Just like that
    Awesome camera mount! I can't find it under any searchword, how's it called even?
    I found "cargo mounts" to be similar but not with those fancy clamps at the end.
    James May: "Yes."
    Nov 28 2006
    Just like that
    What Corbeau seats are those?
    Feb 24 2010
    Damn. Love it
    Switched to Tesla and have never been happier. No more shady mechanic bills and excuses - oil top off before an oil change is normal or dealing with outdated forums that have image size limitations. And no more dealing with vendors that do not provide horsepower numbers but sell you random things by labeling them as performance parts. No more dealing with the Audi dealership and having to buy custom Audi specific tools. Wow. I can't believe I lived through all of this. Money pit.
    Jan 14 2013
    Mi4cxl
    london/UK
    Lol :)
    I am a photographer so have them laying around
    This is what the clamps are https://www.bhphotovideo.com/c/produ...h_ratchet.html
    And this is the extension pole to go in between https://www.bhphotovideo.com/c/produ...ble_light.html
    I have a slightly difrent version of the pole but they do same thing.
    Also need something like this https://shop.gopro.com/mounts/handle...AGTSM-001.html
    Or
    http://www.ebay.com/bhp/gopro-pole-mount
    Jan 14 2013
    Mi4cxl
    london/UK
    http://www.sportseats4u.co.uk/corbea.../prod_474.html
    Mar 11 2008
    B7RS4 & e46Ms
    Search: racing harness spinal compression
    FRRG AZ Ring
    Nov 28 2006
    So long as my sholders are lower than the holes the belts pass through are, correct?
    Mar 11 2008
    B7RS4 & e46Ms
    Negative; the key function is where your shoulders sit in relation to where the harnesses mount. A harness bar above the shoulders behind the seat is proper. Some folks get away with mounting to the seatbelt anchors on the rear deck, but that's just a loophole, and it's not exactly the safest choice. OE seats are designed to crumple and provide some level of vertical impact support. Racing seats are designed to work in tandem with the roll cage. When the occupant is strapped in, they become a part of the structure along with the seat. If the seats are left to be structural members all alone, they will fail at the wrong time.
    FRRG AZ Ring
    May 10 2015
    Slovenia
    MattboyR32, if you're interested in a read. Me and koolade9 had a long discussion a while back in this forum thread: http://www.audizine.com/forum/showth...ounting-points
    We also continued the discussion privately and I'm thankful for the arguments he brought to the table. We both agree that these "plug-in" harnesses are no substitution for a roll-cage/harness-assembly/hans. And by using it, you put your own neck at stake as it never can be a 100% safety solution.
    I think the loophole that koolade mentions is that what I pointed out in our discussion (pictures in that thread), that if you as the driver are short-enough (I'm 5'8"), your shoulders are under the hole in the seat where the harness passes through, but also the angle at which the harnesses continue behind the seat is important. A propper harness bar will cause the harness to travel upwards leaving your shoulders, reducing the risk of spinal compression. Connecting them to the rear seat-belt connection points still puts them at an "acceptable" angle.
    This word "acceptable" you have to judge yourself.
    PS: We were discussing the Scroth harnesses, who are running a patented ASM technology to prevent the driver from submerging.
    James May: "Yes."
    Nov 28 2006
    Look, I totally get the safety aspects of it.
    There was an article on the winding road website about the race to the bottom and the budget conscious decisions we make and therefore the risks that we take. Believe you me, I would love to go get a proper race car as a "fun" car like a few people in the Audi Club here in California have. Alas I don't play in that sort of money. So trying to balance safety with cost is tough because ultimately what is your life worth!
    There was an instructor a number of years back, second lap at big willow and he rolled it. he had a few bruises and contusions but otherwise fine. Car was a write-off. Very lucky fellow. Do I take some comfort that he was in an RS4 and he survived. Sure. Does it mean I am invincible no.
    I think as we work our way up from beginner groups and with no mods on the car to more and more advanced such that you want to make certain adjustments to go faster, means also you have to start weighing the safety aspect much more.
    Would also be nice if someone made a removable roll cage for our cars. Before people jump on and flame me about removable or fixed, my argument is that I would still like to take more than 2 people in the car on the road if I wanted to... maybe one day I'll take a trip to autopower industries and see if they can measure something up...
    cheers all.
    Mar 11 2008
    B7RS4 & e46Ms
    I'm not saying you guys need to run a cage. But you'll be hard pressed to find a racing organization that will let you on track with belts mounted like that. Find yourself a good fabricator and have a harness bar made. Here's one in a B6 I pulled off the interwebs:
    Otherwise, I'd run OE belts...
    FRRG AZ Ring
