Results 1 to 3 of 3
    Active Member Two Rings b5zay's Avatar
    Dec 21 2016
    Oshkosh WI
    Maf sensor problem
    I got a 1.8 AWD b5 and when I have my mass air flow sensor plugged in the car starts then dies or starts and runs and pushes zero psi and if I have it unplugged it pushes full boost(8-9psi) but after about 4200 rpm the car has no power and still pushes full boost but no power, what the hell is going on, I tried different maf sensors and different ecu's and it does the same thing. Please help lol
    Dec 21 2016
    Oshkosh WI
    And the wiring is good I checked that many times
    Dec 05 2007
    How you know what boost you are running? 8-9psi with no power just seems like an oxymoron.
    Boost leak test, make sure all wires for MAF are not compromised, fix all exposed and/or corroded wires, report back.
