Results 1 to 19 of 19
    Veteran Member Three Rings skree25's Avatar
    Dec 20 2014
    1999 Audi B5 A4 Avant, 1996 Cherokee, 1989 Honda VTR 250
    UT
    EGT sensor location mount on engine or firewall?
    I'm putting my engine back together after a bottom end build and can't for the life of me remember where the EGT sensor boxes mount to.
    Do they attach to the heads, or the rear of the IM, or the firewall? Can someone help me out here?
    Veteran Member Three Rings -Billy's Avatar
    Feb 13 2013
    Altoona, PA
    They go on the back of the intake manifold on the 2 longer studs, if I'm remembering correctly.
    Dec 20 2014
    UT
    Do they both sit on the same two studs?
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Yes, back to back. It goes, IM>Spacer> EGT + EGT > Nut.
    I think the driver side EGT is closest to the IM, but you can try both configs to see what fits best for you.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Dec 20 2014
    UT
    Exactly what I was looking for thanks!
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    On my 00' apb there is one sensor on each side of the manifold, not sandwiched like that^
    Quote Originally Posted by a4kamila6 View Post
    Same with my 01
    Sent from my HTC331ZLVWPP using Audizine mobile app
    Dec 20 2014
    UT
    But they mount onto the manifold still?
    Dec 30 2009
    I'm picturing a 2001.5 Audi S4..
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Feb 13 2013
    Altoona, PA
    Mine is a 2000 and it's the same as the picture posted.
    Dec 30 2009
    For those with sensors not stacked.. did you buy your car recently? Are your EGT sensors different colors or the same color?
    Maybe 5 years ago, ECS tuning had a sale on 2 passenger side sensors (black ones IIRC) as a combo deal, where the passenger sensor probe wire is shorter.. so the likely owner at the time hacked it up to mount and fit. I couldn't pass up the deal so I bought them and mounted one to the false firewall so it could reach..
    2001.5 S4 Sedan
    2018 Q5 2.0t
    I've had this car since 2009 and the one before since 2004 they are both not stacked and orange on passenger side black on drivers side
    Dec 30 2009
    Thanks for the pics! You do have a < 01.5 intake manifold... but that would mean the wiring harness is also different between the vin split.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Mine's a mix between02 and 01
    she was an m box car originally
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    I have seen them both ways, if you have the studs on the back of the manifold to install them on then do it that way, it isnt going to matter how they are installed though they will work no matter how you mount them.
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Veteran Member Four Rings ReggieNoble's Avatar
    Dec 17 2016
    B5 S4 Avant
    Fl
    So it looks like early manifold they are separated and late manifold they are stacked.
    Sent from my LG-D850 using Audizine mobile app
