Results 1 to 4 of 4
    Jan 27 2017
    oakdale ca
    Replaced engine . Car won't start
    2001 Audi a4 Quattro 1.8turbo
    Replaced engine
    New battery
    New fob battery
    Cranks but won't turn over
    Obd2 code p0688
    sexy grease monkey
    Senior Member Three Rings Pswish's Avatar
    Mar 25 2016
    2010 Suzuki VStrom 650
    Bay Area
    17072/P0688/001672 - ECM Power Relay Load Circuit: (J271): Open Circuit
    There are sensors and other things that can cause it not to start so start with the basics: You need 3 things to start. Air, fuel, spark.
    Does your dash light up with the check engine light before you crank? Does the immobilizer light illuminate (Looks like a key)? Do you have fuel pump performance? Your ECM provides the injectors with pulse info to spray fuel so you could pull the injectors and see if they spray fuel when you crank.
    Early 04 1.8T Dolphin Grey A4 (planning on selling), 165k miles and counting, often in bay area traffic, LED lows & HIDs fogs, ECS Snub mount, Electric systems specialist, Photographer, 2018 Q5 on order.
    Mar 25 2016
    Bay Area
    Quote Originally Posted by kimmylyn View Post
    Replaced engine
    New battery
    New fob battery
    Obd2 code p0688
    sexy grease monkey
    Any luck?
    Jan 27 2017
    oakdale ca
    I will go check all that. Thank you
    sexy grease monkey
