Hi everyone,
I just have some questions for you guys who have done oil changes before or usually do it yourself. Which method do you use ? Do you use an extraction pump and suck the oil from the dipstick hole or drain the oil by removing the drain plug on the bottom of the car ?
Can you extract the same amount of oil out using the pump compared to removing the drain plug ? If removing the drain plug method is better, how would you get most of the oil out when using ramps, since the front of the car is higher than the rear ?
Thank you 😊
