Page 1 of 6 123 ... LastLast
Results 1 to 40 of 205
    Veteran Member Three Rings mkasperzak's Avatar
    Jan 16 2014
    Transition Patrol Carbon, Transition PBJ, Commencal Furious
    mkasperzak's SQ5 "The Bird" build thread
    Picked up a 2014 Brilliant Black SQ5 P+ last June with 33k miles and have been meaning to start a thread since. It is my third (and favorite) Audi to date, I was coming from a b8 A4 6MT and prior to that a b7 A4 (pics below). Thought I was going allroad, but ended up going with the SQ primarily b/c of the 3.0T. I was struggling getting back into a stock 2.0T coming from a stg 2+ and I welcomed the extra room. Found a great deal on a local SQ that had everything I was looking for P+, Tech, Carbon Inlays, 21s, Black/Brown Nappa, BangOlf, Side Assist, Xpel and I jumped on it (thought I wanted BO, but the contrast with black has grown on me). Modding started immediately, I swapped a number of parts from the b8 her first night at home and put in an order with team supreme to get her where I wanted. I took a nice break after the initial group of mods then did a "winter phase" and will do my second big phase here in the next month or so.
    My buddies and I call it the "The Bird", stems from referring to Helicopters as birds (ski culture lingo ). With the Nokian snow tire setup, it literally does fly up to the mtns in any conditions. Tough to find a more suitable/fun car for a mtn weekend trip. Now on to the mod list and photos....
    Powertrain:
    GIAC Dual Pulley Tune (3.18 PR)
    AWE SC Pulley (57.55mm)
    FluidAmpr Crank Pulley w/ iAbed 183mm oversized ring
    AWE Touring Exhaust + Valve Sims
    034 Heat Exchanger
    Roc-Euro Intake
    R8 Oil Cap
    Wheels:
    21x10.5 BC Forged EH-173, ET25 F ET20 R on Michelin PS4S 295/35 (coming spring 2020)
    20x10.5 BBS CH-R ET25 on Nokian Hakka R2s 255/45 with 3mm Supreme Power spacer in rear for effective ET22 (winter setup)
    Suspension:
    Bilstein PSS10
    034 X Brace
    034 Adj RSB
    034 Trans mount insert
    034 Rear Diff carrier inserts
    Moog End links (rear)
    Apikol Rear Diff insert (red)
    Brakes:
    Akebono Ceramic pads (rear)
    Akebono Coated rotors (rear)
    Exterior:
    Gtechniq Crystal Serum Ultra (@ Steve at Colorado Detail - highly recommended)
    Llumar Platinum PPF - Full Hood, Fender, Bumper, Side Mirror Caps & Window Pillars (@ Colorado Detail)
    Window Trim wrapped in Satin Black (@ Colorado Detail)
    Roof Rails & Rear Valence painted Satin Black (@ Emmel's Enamels - highly recommended)
    OEM E-Codes (non-AFS)
    OEM Black Optics Grille
    OEM Black Optics Lower Fog Grilles
    CarbonDesignz Mirror Caps
    Phillips Xtreme Vision D3S
    Philips 6000K Xtreme Ultinon Fogs
    DeAuto LED front signals
    DeAuto LED reverse bulbs
    Thule Aeroblade Edge Crossbars
    Thule Flow 606
    Kuat Trio bike racks - Black
    De-Badged
    Interior:
    AutoTecknic Carbon Fiber Comp shift levers
    Ziza LED interior Kit
    Passport 9500xi
    Silenced Rear Cargo Cover
    Vag Mods: Disable DRL wink, Enable remote windows/sun, Enable video in motion, Disable seatbelt chime, enable footwell lighting, disable NAV/Phone warnings, Enable Gear selection in DIS, Enable Lap timer, Disable Auto upshift, Enable Rear LED DRL
    Dragy
    Future Plans:
    CarbnLab Rear Diffuser
    BBK - when front rotors/pads are done
    Past Mods:
    21x10 BBS LM-R ET35 on Conti DWS06 295/35/21 with 15mm F / 18mm R adapters for effective ET20/18
    21x10 Vorsteiner VFF-109 ET30 on Michelin Pilot Sport 4S 295/35/21
    21x10.5 Strasse Forged SM5R Deep Concave Monoblock in Brushed Titanium, F ET30, R ET35
    KW HAS
    034 Intake Hose
    034 rear end links
    AWE S-Flo 3.0T Filter
    H&R Spacers 15mm/20mm on OEM 21s
    CQuartz Professional Ceramic Coating
    Just back from the dealership
    B8
    B7
    Phase 1 - Summer 2016 - I hit it with the Vagcom night one and drove it stock for a day and then immediately swapped some parts I kept from my A4 part out. I installed the 034 Tranny mount and apikol rear diff mount and also picked up a pair of Thule Aeroblade crossbars to fit my Rocky Mount bike racks. Also swapped my Phillips bulbs, LED interior bulbs, LED fogs and hardwired Passport my 9500xi. Shortly after my Mops/Supreme "SQ5 starter kit" arrived and i got everything except the RSB installed within a week or so. Shout out to Tam and Mops for the quick hook up. This got the ride exactly where I wanted it, tightened everything up, dropped it, and made it feel much more comparable to the full CO/Sway setup I was accustomed to. The pipes and intake hose added just the right amount of sound, I didn't go DP b/c I do a lot of highway driving and didn't want any drone (especially climbing I-70).
    AWE
    XBrace
    034 Tranny
    034 RSB & Links
    Phase 1 Final Product
    Booty
    Phase 2 - November 2017 - I got her geared up for her first winter, I purchased the new Thule Flow box and a winter wheel setup from a local Denver AZ'r - thanks again Steve/mtbmaniac. Quattro + Nokian Rubber makes it truly a dream of a machine in the snow. Tons of traction and love the looks and functionality of the box. I also threw in the DeAuto LED Front signals and reverse lights and had a BO grille installed at BWPerformance in Denver. They will definitely be my go to spot now that I don't have a garage.
    Bye Summers
    Hello Winters
    B0 Grille in CB Front
    Phase 3 - April-Oct 2017 - Strasse Forged SM5R 21x10.5 setup. E-Codes from Arjun installed and GIAC Stg 2 April 2017 up at Apikol in Boulder.
    Phase 4 - #BBS365 - Oct 2017-present - I hit up Mops to inquire about a meatier winter setup, Martin's 20x10 Volk/Nokian setup had inspired me a bit and after getting accustomed to the summer setup I was struggling to go back to the 8.5" peelers. I've always loved the BBS CH-R and decided it was time. I transfered the same Nokian Hakka R2's over (255/45/20). At the same time Senior Mops planted a seed and gave me a heads up he was selling his LM-R's... why not make it two? I posted my Strasse wheel/tire combo and barrygold picked them up for his beautiful S8. Thanks again to Mops for making me a deal I couldn't pass up. Few other little things during this time, I painted the rear valence in Wurth Satin Black and had the window trim wrapped in Satin black. More outstanding work done by Colorado Detail. Absolutely loving it, not sure I'll part with either set until I part with the car. Playing with the idea of Bilstein's come spring and maybe Brembo's when my front rotors/pads are done.
    2014 SQ5, BBS CH-R, GIAC DP 183 Fluidampr/57 AWE SC(3.18 PR), AWE Touring, Roc-Euro, Bilstein PSS10, 034 HX/X-Brace/RSB/Inserts, Thule Edge/Flow, Kuat Trio
    Build Thread / IG @thebird_sq5
    Jan 24 2008
    Pennsylvania
    Hotness! The Thule box "flows" perfect atop your SQ!
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Veteran Member Four Rings freesole's Avatar
    Oct 30 2011
    Beauty. Love the look of the peelers on your car. What do you have coming up next for wheels??
    Current
    '22 RS6
    '22 X3M Comp
    Gone
    '19 SQ5
    '18 S5 Sportback /// Build Thread
    '16 Q5 3.0 /// Build Thread
    Insta: @frees5ole
    Jan 16 2014
    Quote Originally Posted by Turbavanttro View Post
    Appreciate it. I have been approached a few times randomly "Hey, Your box doesn't look like a Rocket ready for takeoff". Adjustable Thule bars FTW!
    Jan 16 2014
    Quote Originally Posted by freesole View Post
    I recently purchased a set of Strasse Forged SM5R Deep Concave Monoblock wheels from TSpoolin. 21x10.5 ET30 & ET35 custom built for his RS7. I will need to run spacers, likely going 285/35 PSS. I was actually just in Seattle, I should have hit you up... would have loved to come drool over the LM-Rs. Need to see in person...
    Registered User Four Rings
    Jun 25 2016
    DMV
    happy to help bud!! You da man! love the whip, can't wait to see your next phase!
    Sep 28 2010
    NW NC / DE
    Looks fantastic Matt! Love black with the alu spec.
    Glad to assist anytime 👍🏼
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    The phase 1 "booty" shot is awesome. Nothing like a direct sunlight shot showing off the beautiful swirl-free finish. I need a minute over here, I just soiled myself.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Jan 16 2014
    Glad to see you back on team LM. Will be reaching out for some spacers here soon.
    Jan 16 2014
    Quote Originally Posted by VroomVroom View Post
    I've got to admit... it's a celly snap, that angle sure gets me going though. Finish is not looking like that right now, i'll be putting some serious elbow grease into her soon.
    Jan 16 2014
    Bye Amber. Finally found some time to throw the ecodes in. Was flying through the install until I got to putting the new housings back in, man it was trickier than the a4 but a little patience and voila. And she's finally the way she was always meant to be...
    Thanks again Arjun, best dude around. Now the summers and some time for some proper pics.
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    Great build! Nothing beats a clean BB. You'll absolutely love the tune...its a whole new beast.
    Sep 28 2010
    NW NC / DE
    They look fantastic. Congrats!
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    all of it looks great man
    Prior: '16 A7 3.0T Prestige, '16 S7 Prestige, ‘17 S8 Plus, '18 Porsche Panamera Turbo S - E Hybrid
    CURRENT: '23 Nardo Gray RS5, Carbon Black Optics, '18 Q7 Prestige
    My S8 modified exhaust: https://www.audizine.com/forum/showt...Muffler-Delete
    Jan 16 2014
    Quote Originally Posted by BG SQ5 View Post
    Can't wait, I have been talking to Apikol up in Boulder all day. Bringing her in to Audi on 4/7 to have some recall work done and plan on shooting up for the GIAC Tune/AWE SC pulley that afternoon. Talking to them about the Dual Pulley setup they just released as well, not something I plan on doing immediately but maybe down the road. GIAC claimed to have a dual-pulley file available for one of the Q-models with an ECU part number ending in "J". He said they will be adding more soon.
    Quote Originally Posted by DocTJ View Post
    Appreciate it, can't stop looking back at the ECodes. First trip to the bike park Saturday and up to Copper on Sunday (notice the dirt lot, not snow)
    Mar 23 2008
    2021 Audi SQ5, 2011 BMW 1M Coupe
    Fort Collins, Colorado
    Matt,
    SQ5 looks great, especially with the Thule box. I'm going to buy one this weekend with my REI 20% discount coupon. Glad the wheels and tires served you well this winter driving up I-70 for skiing. I like my Pirelli Scorpion winter replacements overall, but they're not as good as the Nokian Hakka R's in the mountains and on ice. I'd like to hook up and check out your ride once you get the tune and pully. Hit me up when it's complete.
    Quote Originally Posted by mkasperzak View Post
    Jan 16 2014
    Quote Originally Posted by mtbmaniac View Post
    Matt,
    Thanks Steve. Yea I would highly recommend the Thule Flow, fits the Q extremely well. Long enough for big pow skis and low pro to fit in any garage.
    I will shoot you a text when the pulley and tune are in. Should be around the week of 4/17 after I wrap up a few weeks of business travel.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Nice build! Didn't read every post, but have you considered blacking out the fog grilles?
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    Any idea if the box clears the hatch using the factory bars? I think this is the box I want, but for some reason ($) I'm resisting doing the Thule blades as well. Thule doesn't list this box as a match for the Q, and I'm wondering if it's because the hatch doesn't clear in the factory position. Car looks great, BTW.
    '23 S4 Prestige - Chronos Grey
    '21 Q5 P+ - Glacier White (wife's)
    SOLD: 21 S4 - Mythos Black
    SOLD: '19 SQ5 - Quantum Gray
    TOTALED: 21 SQ5 - Ultra Blue
    SOLD: '19 e-tron - Typhoon Gray
    SOLD: '16 SQ5 - Sepang Blue w/Black Optics
    IG: @gravysq5
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Quote Originally Posted by DannyDeez View Post
    Yeah, but I would black the bars and leave the rings bright.
    Just my opinion, but I think it would look good.
    Jan 16 2014
    I hadn't really, I do like the way the the chrome accents in the fog grilles tie in with the chrome in the headlights, Rings, Alu mirrors, chrome window surrounds, rails, and silver wheels. I really prefer the BO look on most colors, but I'm not a huge fan of the fully blacked out look on black paint. That being said I think blacking out just the fog grilles would look mean.
    Quote Originally Posted by SQive View Post
    Now this is something I would more seriously consider, would have the same look as the fog grilles on my b8 a4 where just the circle was chrome. would tie in well with the chrome rings.
    Quote Originally Posted by buggravy View Post
    Appreciate it! I don't think it would clear mounted to the Factory bars. My Thule blades are probably mounted 4 inches in front of the factory mounting locations and the spoiler is extremely close to the back of the box when the hatch is open. Almost positive you would need to get the Thule blades as well or you'd have to program the hatch to only open about 75%. I've thought about buying the Wider Thule Edge blades instead of the Flush ones so I can run my box and my RM pitchforks at the same time. If I decide to go that route and sell the Flush Edge bars, I'll let you know.
    Jan 16 2014
    3mm/10mm Spacers looking Crème fraîche
    Final night for pillow talk, mounting up tomorrow
    Sep 28 2010
    NW NC / DE
    Fantastic spacer snap!
    You know I love wheels in the bedroom
    Jan 16 2014
    Mounted up the new Summers:
    Strasse Forged SM5R Deep Concave Monoblock in Brushed Titanium. 21x10.5 Front ET 30, Rear ET35 running 3/10mm spacers for effective ET27/25. MPSS 285/35/21
    Cell snaps in the garage, need to get her cleaned up for some real pics.
    Senior Member Two Rings Cobra Commander's Avatar
    Nov 17 2010
    Porsche 970
    Philadelphia
    Great looking vehicle!
    2001.5 B5 S4-Silver |Vogtlands|PODI|Dice|
    2007 D3 S8- Daytona Gray
    Jan 16 2014
    Finally got a hand wash in
    Oct 06 2016
    CA
    This looks really good! I love this setup.
    Jan 16 2014
    Finally lugged around the camera last weekend. Got a shot in the basement of REI Denver and an alleyway shot behind my buddies garage.
    Update on spacers - my friend was driving behind me on the way to some trails and noticed a very slight wobble in my driver's side rear wheel. I took off the rears when I got home and noticed the 10mm H&R spacer wasn't fully flush even though it appeared to be. When I took it off you could see the contact/grease from the hub was only about 75%. Super Sketch, I had torqued and retorqued to 105ft/lbs twice. Super Glad he saw it, I switched the rear to 15mm H&R and all is well, crisis avoided. Slight poke now with the 10.5 with an effective ET20 in the rear, but I'm digging it.
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    looks so good! i like the poke you have going on there
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Great looking setup. Love the wheels!
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Jan 16 2014
    Quote Originally Posted by staticuxo View Post
    Thanks, definitely sticking with the 15mm spacers out back.
    Quote Originally Posted by riceboy22 View Post
    Now for some proper winters, going to be impossible to go back to the peelers
    Mar 26 2015
    New York, NY
    Haha I just sold my forged winter wheels. I'm feeling some pangs of regret.
    Current
    Past
    Jan 16 2014
    Yea I looked at them, was too soon though. Might be looking at something japanese myself
    Feb 21 2016
    '07 CBR1000RR
    PA
    I keep looking at your pics and can't decide if I'm happy I had my barrels done in black or not. I never expected it to be such a difference between the two looks.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Jan 16 2014
    Yea it definitely changes the look, big difference in depth perception.
    Nov 17 2010
    Porsche 970
    Philadelphia
    Been watching this thread for some time. Nicely done! What's your offset up front now that I see an et20 can work in the rear. I have some 20s from my D3 S8 that look like they will fit my sisters Q5.... hmmm
    Jan 16 2014
    Quote Originally Posted by Cobra Commander View Post
    Thanks man, Offset up front is 27mm on the 10.5 width. Number of others are running ET25 up front on 20"setups.
    Jan 16 2014
    Trip this weekend to Moab has me itching to add a truck to the mix, lots of 4x4 time in my buddies Sierra. Trophy Truckesque driving is rather fun. Moab has got to be the Rig Porn capital of the world, so many crazy rides.
    Established Member Two Rings SQ5IVE's Avatar
    May 11 2017
    Long Island New York
    Nice! Great looking SQ!
    Jan 16 2014
    Quote Originally Posted by SQ5IVE View Post
    Thanks. I was just checking out your thread as well, she is a beaut. Jealous of the GT's. You going to be swapping back and forth with the BLK's and 103's or are you parting ways with the Vors?
