Page 1 of 3 123 LastLast
Results 1 to 40 of 94
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Watch out for bad front axles...
    My car has 55K miles now and I've replaced both front axles with new ones from Raxles. Both inner CVs were making a little noise at low speeds over bumps, starting and stopping and in turns. Nothing crazy sounding though. When I removed the axles and cut open the inner CVs, the grease poured out like water. Audi clearly uses shit CV grease and it leads to premature failure of front axles on B8/B8.5 A4s and S4s. The worst part is the passenger side axle had enough play to damage the bearing just inside the diff housing that the axle stub rides in on the passenger side. I have a rotational whipping sound when accelerating from a stop and turning left or right. I also have bearing whine that can be clearly heard at 45mph. I'm going to have to pull the trans for the second time in 4 months to address this after my clutch install in November.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    You can't get that out without leaving the tranny in? I think you can. And you can support the cross axel through the pedastal bolt removal hole so you don't damage the seal! Worse thing you can do is damage the o ring in the case that seals around that axel and then you have to remove it anyway.Tip the car so you dont lose any fluid.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by rtl5009 View Post
    You can't get that out without leaving the tranny in? I think you can. And you can support the cross axel through the pedastal bolt removal hole! Worse thing you can do is damage the o ring in the case that seals around that axel and then you have to remove it anyway.Tip the car so you dont lose any fluid.
    Have you taken that cover off? I'll have to get it up on the lift and see how much room I have over there to work.
    Jul 28 2009
    Philadelphia PA
    I've R&R'd my clutch twice now myself. The cover is 3 torx and holds the bearing in. I believe if you remove those and support the axel through the cover hole it will be a straight shot out. The cover/flange many need some fanagling from there but I think you can do it. Take a good hard look. The toughest part will be supporting it while guiding it back into the hole with out damaging the seal. I think it's totally possible tho. May need to sag the trans a bit or jack it up to get it to slide right out. Way better than complete removal tho.
    c8 a6 allroad
    Jul 28 2009
    Philadelphia PA
    Outrageous Fun.
    c8 a6 allroad
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Total outrageous fun.
    Looks like 10 torx bolts in my pic.. unless there is a smaller cover behind the axle flange on the passenger side.
    Jul 28 2009
    Philadelphia PA
    I've never had the passenger side apart. Only the drivers side. Sorry bud. Miss read that part.
    c8 a6 allroad
    Jul 28 2009
    Philadelphia PA
    I'd imagine it's similar, the flange is much bigger tho.
    c8 a6 allroad
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I was worried about that. Need to find an exploded view of trans to see what I'll need.
    Jul 28 2009
    Philadelphia PA
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Pretty sure same has happened to mine. Next on the list, its like a kinda knocking sound over uneven pavement when turning when going slow. Almost a rattle. Every thing else on the car suspension wise is newly replaced and checked. How much were both fronts off raxles?
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by tar View Post
    A little over $300 each.
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    My car makes a minor whipping sound when going very slow on very tight turns (like when making a u-turn in a parking lot), do you think this is due to the same problem?
    Car sounds normal over bumps, under acceleration, and cruising.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by yjypm View Post
    It could be your axle stub bearing on either side. You also could have bad axles and it's hardly noticeable. I would get it checked out now before it causes other problems. Most mechanics won't even suspect the axles on low mileage cars but after speaking with an Audi tech and Marty at Raxles, they apparently have lots of low mileage failures.
    Jul 28 2009
    Philadelphia PA
    What is a whipping sound? Did your have play in the axel still installed?
    c8 a6 allroad
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Sounds like something is attached to tire or axle and whipping against the wheel well, lol
    There was a little play in axle when it was still in the car.
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by Vogz View Post
    Garage envy carry on
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by bakedziti View Post
    lol, thanks!
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    +1.
    Oct 30 2006
    B8 A4 Avant 6spd
    The wheel bearings are notorious on these cars for making all sorts of noises, I haven't replaced an axle on a B8 at the dealer yet.
    -18 718 GTS
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by Militant-Grunt View Post
    Well my inner CVs both had play and grease that had turned to water in just over 55K miles. Have you seen any axle stub support bearing issues on the transmissions?
    Mar 04 2010
    95.5 Audi S6 Track car 2010 S4 with mods 2006 Audi A4 2.0T S line w/ mods, 1974 Alfa Romeo 2000 GTV
    NY/NY
    My B8 has less than 55K miles. Since it is on very wide sticky street tires, and spends time at the track (on 275/35 x 18 R compounds), the whole drivetrain is under a lot of stress. Right after the clutch called it a day at VIR at 48K, I had growling sounds coming from the left front wheel area. That was a bad wheel bearing that had to be replaced. I would always check wheel bearings first, before checking anything else, when you hear noise coming from any corner of the car. I have also never had to replace axles on my street or track cars, just cv joints. I consider cv joints a replacement wear item. I have also found that if I don't use the KISS principle (keep it simple, stupid) it costs me more time or money.
    2019 Ara Blue RS3, APR Stage 3, DSG tune, UM Haldex tune, TTE700, APR 4" turbo & throttle inlet, rear carbon tube, pendulum mount & dogbone insert, Tyrolsport Front Deadset Kit & Harness bar, Superpro LCA bushings, CSF radiator, JDY Performance oil pan, APR FMIC, Race Downpipe, catted Mid Pipes, Milltek exhaust, Wavetrac LSD F&R, KW Clubsport 4 coilovers, Neuspeed tubular sway bars and 350mm rear rotor kit, AP Racing CP9660 BBK, RSE11R 18X9 45mm offset wheels, 265/35 Michelin Pilot Cup 2 squared
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by rcaro900ss View Post
    My wheel bearings are fine. I have zero noise above 10mph and they don't have any play. Checked by myself and a local Audi mechanic. Since they CV joints are part of the axle, I had to replace the axle.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    I'm at 55K too but my axles are perfect. Guess either our roads here in NW are easier to cars or audi improved the quality on B8.5 cars.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Mar 04 2010
    NY/NY
    CV joints are replaceable parts on the axle. You can buy them from ECS Tuning and other parts suppliers. However, if you can buy the new axles with new CV joints for $300 each, that is a deal I would do every day :)
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by wangshuo1989 View Post
    The axles have identical part numbers on B8.5. If they changed anything, they put in better grease.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Of course they come apart but rebuilding axles is a messy pain in the ass. Plus lots of replacement CVs out there are re-ground Chinese pieces of shit. Yes, at little over $300 each with brand new CVs and AMSoil grease, Raxles are a fantastic deal.
    Jul 28 2009
    Philadelphia PA
    Repacking cv's fucking blows. I did it once to save a few dollars and swore to never do it again.
    c8 a6 allroad
    Mar 04 2010
    NY/NY
    Replacing CV joints are no big deal. I have done way too many. However, replacing the front crankshaft seal on my S6, which I am currently doing, that is a pain in the ass :(
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Would either a failing bearing, worn axles or bad CV joints cause vibrations? Car has ~80K kms (50K miles) and dont really have loud noises as described above, the PSS are starting to get loud as they wear down.
    Lately i have noticed small but noticeable vibrations usually around 50mph and up, increasingly worse going around tighter corners on the highway. The problem was really bad where my steering wheel would shake when my winter tires were on and now with the PSS the car isnt smooth as it used to be.
    Could be both sets of tires need balancing but always wondering if its something more. Or something as simple as an alignment which has been a few years....
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Jan 11 2017
    Houston, TX - USA
    I recall reading that the sound during a tight turn at low speeds was a byproduct. It's like a low grumble until I'm done with the extreme part of the turn. Was I led astray?
    Feb 23 2010
    Emmaus Pa
    I'm getting a whipping sound as well like there's a piece of wire attached to the wheel and it's hitting something when the wheel rotates. Almost sounds like letting something slapping against a spinning fan. Very light sound. I'm hoping it's just a wheel bearing and not the inner bearing in the diff housing. OP, did you have to pull the trans? Mine is dsg however, not sure how the output bearings on the diffs vary from 6 spd to dsg.
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    did you check to see if a rock is caught between the brake disk & caliper?
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    Let's hope so. I had the same issues you're facing on my 2012 S4 right around 53K miles. I wonder how much being lowered affects the life of the CV joints/axles in the long run. Hope the B8.5 grease holds up or that Audi made the switch to a better one.
    How's the 996 been?
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Veteran Member Four Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    I just had my passenger side inner axle and boot apart and the grease looked clean and thick. 2013 with 53k miles on stock suspension.
    2013 S4 S-tronic - 3.47 PR // EPL DP ECU/TCU tune // PLM hx // APR intake // Jokerz Blower // Headers // Ice box // iABED TB // Autotech HPFP // RS7 LPFP
    11.186 @ 123.35
    1993 URS4 - GT3071R - EFI Express Tuned - Gutted
    Past: 07 S4 6MT ~ 03 A4 3.0 6MT ~ 99 A4 1.8T
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by jygesq View Post
    Yes, took the caliper and rotor off. I'm also getting a groaning from that corner of the car when it loads while turning. I've had 5 bad wheel bearings on my b5 and this sounds different though.
    B9 S4- EPL/AWE
    Oct 01 2013
    I use my Audi as my daily. S4 B8.5 w tune at 50k+ miles. Had both front axles replaced already.
    2013 s4 nappa magma int. sport diff. B&O. MMI.
    2014 porsche 991 turbo. Stage 2
    Senior Member Two Rings VtotheJ's Avatar
    Jan 27 2017
    Quote Originally Posted by fally View Post
    How did you know the axles were bad? I'm getting some sort of road noise... I think it's just my tires. When I turn the wheel at high speeds the road noise doesn't change.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Sounds a lot like what I had. I ended up picking up a trans with similar mileage from a recycler and the sound is completely gone. I'll be replacing the worn bearing in the old trans and I'll either keep it as a backup or sell it.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by raudiace4 View Post
    How's the 996 been?
    Lowering effect is probably minimal, I've never had CV issues on a lowered car before. I attribute my issues more to a handful of track days causing lots of heat buildup in the CVs.
    996 has been awesome. Runs like a top, carves corners like a boss, and goes like stink. Love it.
