Results 1 to 9 of 9
    Veteran Member Three Rings red4life5's Avatar
    Dec 29 2016
    2004 Audi S4 Avant
    Cleveland, OH
    Found Amp in trunk; advice needed
    I bought my A4 in October and found an aftermarket boost controller under the dash in the drivers seat then found an amp wired up but it's unplugged from the battery. The sound is fine in my B&O. Not sure if hooking it up with the Audi amp installed will hurt anything or what else has been done. Should I hook it up? Should I leave it? Or...? Help is appreciated
    2010 A4 S-Line Prestige
    2004 S4 Avant Greenwood Green
    2011 A3 K04
    2008 A3 -Sold
    2010 Audi A4 K04 -Sold
    Jun 26 2009
    Bremerton WA
    Likely they had a sub box in the trunk. So unless you plan to add one, most likely not worth the effort unless you plan to replace the factory sub.
    Edit- You may want to plug back in the battery vent tube.
    VMR 710's, APR software, Eurocode HFC
    Dec 29 2016
    2004 Audi S4 Avant
    Cleveland, OH
    Quote Originally Posted by van462 View Post
    Where is that at? I didn't notice anything unplugged
    2011 A3 K04
    2008 A3 -Sold
    Jun 26 2009
    Bremerton WA
    Last picture, just to the right of the bottom 2 wires. The battery should have a hole on that side for it. If the battery has been changed often this hole has a plug that may not have been removed for the vent.
    Dec 29 2016
    2004 Audi S4 Avant
    Cleveland, OH
    Just like this?
    2011 A3 K04
    2008 A3 -Sold
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by red4life5 View Post
    Just like this?
    Yeah that's the tube that's supposed to be there to vent the battery overboard. You're good
    Dec 29 2016
    2004 Audi S4 Avant
    Cleveland, OH
    Quote Originally Posted by The Infiltrator View Post
    Thank you. I was hoping you'd comment :D
    Any other advice about the pre-installed sub or what is said is good?
    2011 A3 K04
    2008 A3 -Sold
    Sep 09 2010
    Destin, FL
    That part I'm not sure about, sorry man.
    Senior Member Two Rings Dcferolino's Avatar
    Jan 10 2015
    2009 audi Q5
    Mountlake Terrace/ Wa
    Just leave as is not unless your planning to add a sub
