Every part is OBO and everything must go but please keep
you offers reasonable, thank you. Also all agreed upon prices
must add %3.5 for paypal fees. There are no exceptions.
New build parts:
3. New black leather urS e-brake boot- $45 shipped
4. New air leather urS e-brake handle- $60 shipped
7. 034 5 cyl billet cylinder head freeze plug- $26.45 shipped
8. (Used) 2bennett A-pillar gauge pod in black & Autometer boost gauge (30 psi, white face, red needle, backlight)-
$125 Shipped obo
11. USCAR to EV14 injector adapters- $25 shipped
12. Dealer/factory serpentine belt for urS cars without A/C.
Perfect for those doing an a/c delete. Price is $100 shipped
13. Custom made -6an block
turbo coolant return port- $50 shipped
All of the used parts:
1. AAN water manifold- $65 shipped
2. AAN fuel rail with braided line, FPR still on it and a newer bosch fuel filter- $100 shipped
5. AAN motor mount bracket set- $65 shipped
6. Good factory upper radiator hose- $40 shipped
7. Mint urs4 orange corner lights- $35 shipped
9. Good 5 speed CBD 01E with wide 1st gear. Serial number 94,798 from a 95.5 urs6
will include it complete. Price update--- $300 + freight or $500 picked up
Another good PJ 1st gear 5 speed 01E- $200 + freight or $300 picked up
10. Good urS locking rear end- $150 + shipping via greyhound or $100 picked up
11. Set of OEM GKN urS axle cores- $250 + shipping for all 4 or $75 + shipping per axle
12. x2 OEM driveshaft cores- $65 + shipping via greyhound (both need new cv's & center bearings)
14. Stock AAN flywheel- $100 shipped
15. Stock AAN K24 turbo NO shaft play and one broken exhaust stud- $125 shipped
Still useable!
16. Stock AAN exhaust manifold- $100 shipped
17. ECRU rear seat back in good condition- $150 shipped via greyhound
18. Stock AAN wastegate & flexpipe- $100 shipped
20. Nice ECRU rear deck with good speaker grills- $150 shipped via greyhound
includes adapters for aftermarket 6x9 speakers - Sale pending
24. Box with every relay, fuse, and module from a 95.5 urs6- $125 shipped
25. Good 95.5 ABS pump- $125 shipped within CONUS
26. Good 95.5 ABS computer- $57 shipped within CONUS
Also have a 93 s4 abs computer- $57 shipped
31. AAN intake manifold- $150 shipped within CONUS
33. AAN throttle body with TPS- $65 shipped 1 left
34. AAN oil cooler assembly- $100 + shipping
35. AAN air box assembly- $75 + shipping
37. urs4 doors, no trims, (some rust)- $100 + shipping per door or $750 shipped for all 4 via greyhound
Very minor rust but overall in very good shape. Great for replacements
38. urs4 rear bumper in good shape, trims intact, just needs to be resprayed- $350 shipped via greyhound-- includes all 3 trims and bumper shocks
40. Good set of ECRU door cards- $200 shipped via greyhound
41. Good set of 94' urS window motors- $125 shipped within CONUS
44. USED 94' urs4 factory brake booster- $115 shipped
45. USED 94' urs4 clutch master & slave cylinder set - $115 shipped
Master is factory and the slave I have a factory boge unit
47. Good brake pedal- $50 shipped
48. Good gas pedal- $50 shipped
52. ZF factory rack & pinnion/suggest a rebuild but might
be able to get away with just a new boot & fluid-- $150 shipped
54. rear knuckles/uprights- $50 + shipping for the set
55. Front subframe- $50 + shipping via greyhound
65. rear subframe- $50 + shipping via greyhound
71. urS 26mm front sway bar- $50 + shipping via greyhound
72. urS windshield wiper arms with good blades- $70 shipped
74. power steering reservoir includes cap, sensor, and wiring pigtail- $65 shipped
75. Strut tower brace- $25 + shipping
76. Strut tower covers/caps (good condition)- $57 shipped
78. urs4 cluster in good condition- $150 shipped within CONUS
79. All interior buttons, switches, ETC- $65 shipped
81. Good charge piping hoses- $100 shipped within CONUS
OEM throttle body and turbo outlet hose. 2 out of the 3
Price is OBO. The throttle body hose is in great shape and
a factory genuine piece.
88. Good o2 sensor- $40 shipped
89. Good factory coolant tank comes with cap, sensor and plug with wiring pigtail- $50 shipped
90. Mint black rear view mirror- $57 shipped
94. Black mirror caps- $57 shipped
97. Good factory front strut mounts- $50 shipped for the set
These are the oem ones that the bushings don't pop.
98. Rear control arms- $100 + shipping
98. Rear toe arms- $50 + shipping
99. Stock rear diff mount- $40 shipped
100. Rear diff crossmember- $50 + shipping
101. whole center console switch board with all switches -- $100 shipped
104. AAN valve cover- $75 shipped I have 2
106. AAN rear main flange in mint condition. Sand blasted and powdercoated silver- $50 shipped
107. AAN power steering pump bracket- $50 shipped
Lightweight 95.5 aluminum version versus the 95<
cast iron unit.
108. Idler pulley & accessory bracket- $100 shipped
111. Nice black urS4 center console both pieces- $200 + shipping or $100 per piece
112. Nice black b-pillar trims- $100 + shipping
114. Black dash pads pieces underneath & glovebox- $100 + shipping
115. Black door sills and kick panels- $100 + shipping
If there is anything you are looking for feel
free to contact me anytime. Don't be afraid
to make offers on certain things either the
worst I'll say is no or come back with another
number.
cheers
