The factory plastic charge pipes and rubber couplers on your Audi B8 2.0T were never designed to handle the stress and abuse of higher boost levels much beyond stock.
At ECS Tuning, we're proud to release our in-house engineered silicone intake hoses! Each complete set includes an oversized turbo muffler delete paired with similarly sized silicone hoses. These hoses replace the OEM rubber pieces from the turbo inlet all the way to the throttle body. Our hoses are designed to install directly without the need for any modification.
Key Features:
- Maintains smooth inside surface for optimum flow to reduces turbulence and increase air flow capacity
- 5-Ply Silicone Construction
- Direct replacement of the factory rubber hoses
- Designed to maximize airflow through the intake tract by reducing expansion
- For use with the OEM intercooler only
Relieve Some Stress with ECS
Fits:
Audi B8 A4 2.0T 2009-2016
Audi B8 A5 2.0T 2008-2016
Audi B8 Allroad 2.0T 2013-2016
Be sure to check out our -----> installation PDF <-----
Jason
