Results 1 to 9 of 9
    Established Member Two Rings Cygnets's Avatar
    Jun 28 2016
    07 Audi S4, VW Jetta 1.9 TDI
    Hershey
    B7 S4 RNS-E denying the recoding for AUX
    My S4 is currently at a pretty well known euro shop ATM to get the head unit recoded with VAG-COM.
    They are saying they can't recode it because everytime they plug the number in it's just denied. They said they called Ross tech, Audi, and others to see why it would be doing this. They didn't get a deffenate answer.
    What would be the reasoning behind this head unit not being able to be recoded?
    Is there any steps you can tell me that I can tell the shop to try?
    Edit: shop said they where trying to change 2nd to last number to a #7...thought it was supposed to be changed to a 5 if I'm not mistaken...could that be why?
    Edit 2: just talked to the shop, they tried a few different numbers, ranging from 4-7 and none of them worked or allowed AUX..
    Aug 09 2012
    Bay Area
    What version is the software on the RSN-E?
    Senior Member Two Rings Skeee's Avatar
    Nov 19 2008
    2008 Audi RS4, 1998 Gti VRT, 2003 Audi RS6, 2004 VW R32
    Washington
    do you have the current version of the software?
    Dirtbag
    Jun 28 2016
    Hershey
    Quote Originally Posted by Kambesama View Post
    Would I go about checking that using this?: http://www.audiworld.com/forums/a4-b.../#post20433236
    Jun 28 2016
    Hershey
    Quote Originally Posted by Skeee View Post
    Just checked, running SW: 0150
    http://i.imgur.com/3Lt2VK3.jpg
    Nov 19 2008
    Washington
    i believe that the mk1 current version is SW:260 and the mk2 version is SW:230
    Dirtbag
    Aug 09 2012
    Bay Area
    Quote Originally Posted by Cygnets View Post
    Alright!! That's the problem right there. Buy yourself the update CD for the 0260 Version and your set.
    Update the RSN-E then perform the coding again and it should work.
    https://www.flickr.com/photos/883054...7658197443223/
    Nov 19 2008
    Washington
    maybe try updating the software first to the latest and current version then try to recode it again to see if that helps
    Dirtbag
    Nov 12 2015
    Oregon
    Yup, you need atleast sw260 or sw280 in order for the coding to be accepted. I ran into this doing mine. I updated and it accepted right away
