Results 1 to 8 of 8
    Mar 09 2007
    03 A4 1.8T
    Richmond%2C%20VA
    Roof rack question
    Hi everyone,
    Searched everywhere online to find an answer if the OEM Base bars from an 04 A6 sedan will fit 03 A4 sedan. My assumption that it will not, however I wanted to double check. Thank you for your help.
    Z
    Zlaja
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    For the 2 OE B6 options I see: 8E0071126A & 8E9071151A
    For the 2 A6 OE options I see: 4B0071126A & 4B9071151A
    If the 8E and the 4B simply imply A4 and A6, then the part numbers are otherwise the same. That being said, if you search the B6 part numbers themselves it will show the B6 number fitting all B6 and B7 variants but not the C5 A6. The bars for the C4 and C5 appear to be the same but not the same as on the B6 and B7. I have no experience with fitting either but would be inclined to go with your stated intuition.
    I did find this thread on Audizine where someone bought OEM bars off an unknown model. In the end he determined they were from a C5 A6 and did not fit his B6 A4.
    Aug 19 2013
    minnesota
    Yakima q bars ftw
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Jul 31 2016
    Montana
    B6 Passat bars fit if you cut them down. I have a lead on a Yakima rack for 50 bucks im looking at...
    Aug 10 2011
    330i ZHP
    I may be way out in left field, but I imagine he is asking that specific question because he has access/potential access to C5 A6 OEM base bars.
    Mar 05 2013
    CA
    I heard that stock bars make wind noise, and that Yakima whispbars are a better alternative, just saying.
    Mar 09 2007
    03 A4 1.8T
    Richmond%2C%20VA
    That's correct. I came across a good deal for C5 A6 base bars, however I don't want to spend money if they are not going to work. Thank you all for your help with this.
    Zlaja
    Aug 19 2013
    minnesota
    Qbars are the difinitive /thread
