Results 1 to 13 of 13
    Sep 23 2016
    Miami,Floria
    Question Fuel Issue - Check Engine light
    Anyone have an idea what the heck this is?
    6208 - Fuel Trim; Bank 1 (Mult)
    P1128 00 [101] - System too Lean
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 78348 km
    Date: 2017.03.09
    Time: 19:10:53
    Engine speed: 681.00 /min
    Normed load value: 11.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 84 °C
    Intake air temperature: 68 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 12.999 V
    Unlearning counter according OBD: 40
    Engine speed: actual: 672 /min
    MAF_ENVD: 103.49411 mg/stroke
    Coolant temperature (unfiltered): 84.8 °C
    Engine: operating status: IS
    T_AST_ENVD: 51.40 s
    STATE_LS_ENVD[1]: 2
    Nov 02 2015
    Orlando, FL
    What kind of gas are you running in the car? Could also be bad MAF or O2 sensor.
    2018 Audi RS5 Coupe, 034 Motorsport ECU and TCU tune, 034 Motorsport Front Strut Brace, 034 Motorsport Transmission Mount Insert, Kohlefaser Luft-Technik Carbon Intake System, MercRacing Multi-Pass Dual-Core Heat Exchanger, Pierburg CWA100 Water Pump, Bull-X Resonator Delete Pipes, ORT Motorsport HPFP, Maxton V2 Front Splitter, Savini SV-F5 20x10 Wheels, Michelin Pilot Sport 4s 285/30/20 Tires, H&R OE Sport Springs (yet to be installed)
    Nov 20 2014
    New York
    What kind of gas and was a/c on?
    Sep 23 2016
    Miami,Floria
    I am using E85 mix with 93 octane. On a 16 gallon tank, I used 5.89 of E85 and the rest of 93. No AC was on, just the radio
    Nov 02 2015
    Orlando, FL
    You could have put in too much E85 and leaned it out. Go drive around and top off with some more 93. It'll clear up.
    Apr 05 2016
    Portland, OR
    What does your fuel trim look like?
    Was this on startup?
    My guess is the Ethanol or not giving enough time for the LTFT to adapt.
    Did you have an Ethanol in the tank before? How long after fill up was this? Any idea the overall E% in the tank?
    Geoff
    Sep 23 2016
    Miami,Floria
    What does your fuel trim look like? I have to check
    Was this on startup? Yes. I was in the process of changing some VCDS settings and then I clicked on Scan for codes and the check engine light came on
    My guess is the Ethanol and not giving enough time for the LTFT to adapt. Too much E85?
    Did you have an Ethanol in the tank before? Yes. I had the same mix. I am on a half a tank now.How long after fill up was this? 4 days Any idea the overall E% in the tank? Nop
    Nov 20 2014
    New York
    If you're playing with mixes without a dedicated file you will get those lean codes.
    Veteran Member Four Rings MKGIY's Avatar
    2012 S4, 2012 GMC Acadia
    New Jersey
    Quote Originally Posted by whiped View Post
    How do you check the fuel trim? I had the same codes come up recently.
    OP - is you gas millage off as well?
    Thanks,
    Sep 23 2016
    Miami,Floria
    No idea how to check it. I know GIAC said its ok to mix, but I dont know if I have the correct MIX though. I might just switch to 104 octane
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    You literally made E38 exactly. So if there was a little extra e in Either the gas or the e85 it would have put you over the edge.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Apr 05 2016
    Portland, OR
    I'm in class but I will post some details after I get home tonight or tomorrow.
    I've gotten a few PMs about this so I will try to put a thread together. If anyone is free and can beat me to it I'd appreciate it.
    Geoff
    Apr 05 2016
    Portland, OR
    Long day yesterday and my laptop was just about dead when I made it home.
    Here are some fields you can log in VCDS:
    Long term adaption of mixture formation bank 1
    Long term adaption of mixture formation bank 2
    Short term adaption of mixture formation bank 1
    Short term adaption of mixture formation bank 2
    Lambda probes actual: bank1
    Lambda probes actual: bank2
    Lambda probes specified: bank1
    Lambda probes specified: bank2
    There are a few others but those will give you a good idea of what is going on.
    There is some more info in Jrans thread: http://www.audizine.com/forum/showth...rmance-Logging
    Another good way to check how the car is running is to look at your plugs.
    Geoff
