Results 1 to 4 of 4
    Established Member Two Rings Silverrotor's Avatar
    Jan 06 2015
    Badass 87 Mazda RX-7 Turbo
    Vaughan Ontario Canada
    Removing secondary air injection pump hose
    I need to replace the inlet hose to the secondary pump. It's the hose that connects to the pump itself and the other end to the air box.
    I wanted to know if I have to remove my bumper skin to replace this hose. Or do I have to just pull the wheel liner back?
    I broke the connecter to the airbox and I'm now getting MILs.
    Apr 05 2016
    Portland, OR
    If you remove the intake you should be able to do it from the top.
    To make your life easier you can also remove the fog grille.
    Geoff
    Senior Member Three Rings protogeoff's Avatar
    Nov 12 2016
    Port Moody
    Although my connector to the airbox seems fine, it fits rather loosely. Is anyone elses the same?
    V1Rotate
    Jan 06 2015
    Thanks for the response whiped.
    I found by removing my passengerside headlight I was able to access the inlet hose that connects to the pump itself.
