Results 1 to 6 of 6
    Jan 26 2017
    Philadelphia PA
    Need driver side headlight (complete assembly)
    I need an OEM left driver side headlight with bulb and ballast and all modules. Needs to be part number 8k0941029R, I think 8k0941003R also will work. Message me if you have it.
    Mar 21 2015
    What year?
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    That part number appears to be for a pre-facelift B8.
    B8.5 Audi SQ5 | APR Stage 1
    Mar 21 2015
    Quote Originally Posted by kristokes View Post
    I wasn't doing the hard work, nor do I have one. Just trying to make it easier for everyone. Thanks
    Active Member Two Rings s4ved's Avatar
    Oct 17 2016
    2013 SL63 AMG, 2016 Range Rover Autobiography, 2011 G55 AMG, 2010 X5, 2008 rs4, glk 350
    Iowa
    I need a right passenger side headlight, adaptive function no longer works and needs replaced. If someone has a complete set we could split
    Sep 15 2015
    Clarendon Hills, IL
    I switched to euro spec and have both L&R headlights but no ballasts, only turn signal bulbs, no xenon bulbs....passenger side headlight has some damage but is in excellent working condition---drivers side is in perfect condition....both of you guys can pm me if interested i can send you pics too
