Results 1 to 30 of 30
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Giac Stage 2 and E85
    I know I read somewhere what GIAC suggests using when running E85 with their race map but after looking through E85 thread after thread can't seem to find it. I recently put 4 gallons of E85 in my car and topped the rest off with 93. Has anyone else ran their race map with this setup and will I be ok? I don't want to throw a code because I don't have my ross tech cable yet so I won't be able to clear it. I'm going to the drag strip on friday. Also do GIACs different maps need driving time to adapt or once you change it on the fob its immediately ready?
    Deactivated Two Rings
    Jun 02 2016
    Irvine, CA
    We recommend doing an e30 blend (about 4.5 gallons) with our race mode. It should not throw codes. For future consideration, you can run up to 6.5 gallons of E85 for additional performance. You should allow for at least 20 miles for the map to adapt, but otherwise it doesn't take much time.
    Jul 04 2008
    York, PA
    Quote Originally Posted by Connie@GIAC View Post
    Excellent customer service, thank you! So has anyone ran the race map with just 4 gallons of E85? I might have to go back to the gas station.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by 4Rings3Liters View Post
    Be careful and pick up an ECA if you run it regularly.
    Over E40 and you can start getting into some trouble.
    Also, +1 Connie, excellent fast response!
    Geoff
    Jul 04 2008
    York, PA
    Quote Originally Posted by whiped View Post
    Sorry for my ignorance, what's an ECA? I don't run E85 regularly, actually this was my first time.
    Jun 02 2016
    Irvine, CA
    Not sure who here has ran 4, but you should be fine with that. Like he said, be careful of going over E40!
    Apr 05 2016
    Portland, OR
    Ethanol Content Analyzer I did a write up on mine here: http://www.audizine.com/forum/showth...ntent-Analyzer
    There are multiple other options as well.
    E40 was the tipping point for Stage II. I usually kept it around E35.
    E35 seems to bee the tipping point for my DP setup. I stay around E30.
    Be careful blending, running lean because the fuel pump cannot keep up is very dangerous for your engine.
    Geoff
    Jul 04 2008
    York, PA
    How do I calculate this and what issues could occur?
    Nov 08 2015
    Newtown sq, Pennsylvania
    I've been running giac race map daily for the last month with 4 gallons of e85 no problems, but I will be installing a ECA soon to see my exact ethanol amount.
    2016 Glacier White S4 P+
    6MT | Black/Magna Nappa Leather | Tech Package | Carbon Inlays | Sport Diff | Alu-Optics | Black Optics | B&O | LED Interior Lights |
    25% Tint | LED Fogs | 19" BBS CS5 Winter Setup | Eurocode sways F+B | Eurocode endlinks F+B | Deval Diffuser+Front Lip | | ECS 10mm Spacers | USP Stainless clutch line | E-codes | ECS Diff mounts | Eurcode Tranny mount |
    Apr 05 2016
    Portland, OR
    Ethanol content is hard to calculate unless you know the ethanol content of the gas in your car and of the E85 you're adding. You call ballpark pretty well but it is not worth it to me if you are frequently blending.
    There are lots of bad things that can happen from running lean. Pison failure is a big one.
    Geoff
    Jul 04 2008
    York, PA
    Bueller... anyone else?
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    Depending on the station the ethanol content of the fuel can vary greatly..... Using an ECA will let you know the exact amount of ethanol in the fuel you are purchasing so you can obtain the proper mix of fuel. Just because you are purchasing fuel from an E85 pump that does not mean the fuel contains a full 85% of ethanol.
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    i've been pretty lucky in FL. I just recently filled with 90% ethanol off a station in Port St. Lucie (Sunoco off Gatlin Blvd near i-95 if anyone is in the area, just tested it yesterday evening). Stations closer to my home in Sarasota, FL are normally in the 83-87% range.
    At any rate, 37.7% is my magic number for my particular car.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Is the boost profile different on the race map than the pump map?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by rtl5009 View Post
    it isn't, the B8.5 "boost dip" is still present on the stage II pump file as much as it is on the race file.
    Oct 06 2014
    Cleveland, OH
    Great thread! I was going to start one in a similar vein:
    I was wondering what is more cost effective or sensible next step in the HP increase process?
    Upgrade to the GIAC S2+ (DP) or Run the S2 Race file all the time with E85 (blend or full on)
    If my cost calculations are correct:
    The DP upgrade will be about $1500 (parts, labor and taxes if I install the crank pulley myself)
    The Race file feature will cost about $1000 (HP and LP fuel pump and Flex-it ECA with bluetooth, no labor, I install myself)
    Hard to tell which makes more sense. And I forgot to mention, I track the car at road courses.
    Thoughts?
    Here is the link to the ECA I would get. Whiped tells me he is researching a less expensive alternative.
    http://www.fuel-it.biz/flex-fuel-sen...ooth-analyzer/
    Apr 05 2016
    Portland, OR
    You don't need the upgraded fuel pumps to run some E85 on Stage II.
    I already posted about my ECA solution: http://www.audizine.com/forum/showth...ntent-Analyzer
    I still need to do some research on HPFP alternatives. The $400 autotech wants for the HPFP piston is a bit much. (You can buy a new pump for less than that)
    I'd start with some E85 because it is cheap and go from there.
    Add in 4 gals to a tank of 93 and see how you like it.
    Feel free to txt me if you have questions.
    Geoff
    Oct 06 2014
    Cleveland, OH
    Thanks Geoff, I already run 4-5G of E85 on occasion. That has always been enough to max out the pump gas file from GIAC. So with me considering running race all the time, abandoning pump all together (instead of buying the crank pulley and upgraded GIAC file) I wanted to remove any doubt regarding issues if I added more or full E85 and just always run the race file? Make sense?
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    I agree, but the Autotech will still outflow the new HPFP in either case. I do wish it were cheaper though. Its just a piston and spring, $400 seems a bit much.
    Oct 06 2014
    Cleveland, OH
    So to dig deeper, what needs to be done first, to run full E85? The existing threads on this, give a few different variables, so I want to approach this solution with guys that have gone full on E85.
    1. Upgrade the HPFP
    2. Log with VCDS (what field/parameter?)
    3. Depending on said logs, upgrade the LPFP?
    4. I see ECS has a replacement LPFP, but I cannot tell if it's the flex fuel model?
    Thanks for the input everyone!
    Aug 09 2015
    Sarasota, FL
    I wouldn't venture into full E85 just yet.
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    General question for everybody blending E85 - Do you guys run wideband O2 sensors?
    Oct 06 2014
    Cleveland, OH
    Quote Originally Posted by S4UCE View Post
    No, but I log with VCDS.
    Oct 06 2014
    Cleveland, OH
    Quote Originally Posted by Loe View Post
    Loe, are you running any FP upgrades, high or low? (I could not tell from your signature?)
    Also, why no full E85 yet? I thought there were several members running full on? Seems to me like a cheap way to run the RACE file all the time?
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by SR7D1 View Post
    The car has dual Widebands from the factory! You are running them!
    c8 a6 allroad
    Aug 21 2007
    I guess I should update my question then to - Do you guys run a standalone AFR gauge or at least regularly look at AFR a multi functional gauge like the P3?
    Just curious because when running meth on my B5, I would always keep an eye on AFR at wot to check for lean conditions in the event of some kind of failure of in the meth system. When running a loose mix (not doing exact measurements) of E85 (which varies in ethanol content to begin with) I would think one would want to keep an eye on AFR after filling up to make sure the ECU is properly adapting to it.
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    My experience running ethanol blended fuel on REVO and then GIAC race tunes has not revealed that an upgraded HPFP is required. Then again, I am presently using GIAC's fuel pump kit. Which unfortunately is not entirely a drama-free affair if the hose between the t-fitting and fuel regulator rips or opens up from the increased fuel delivery pressure.
    Those of you that upgraded your HPFP, what did you see or experience in running your tune on ethanol blended fuel that led you to conclude you need to install the Autotech HPFP, or did you do so simply as a prophylactic measure?
    My experience and observation is what ethanol fuel blend and what fueling upgrades you need to use to optimally run on race tunes is far from well settled, at least for me.
    Aug 09 2015
    Sarasota, FL
    PM sent, "full E85" isn't what it truly is... it makes for great marketing though!
    Apr 29 2013
    Arizona
    ^^^ Loe, I thought you concluded you did not need the HPFP and were going to jettison it?
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    I think originally "full e85" was in reference to a full tank of e85 instead of a mix. What do you mean by "it isn't what it truly is?"
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
