Results 1 to 3 of 3
    Senior Member Two Rings BMT62688's Avatar
    Oct 12 2010
    2013 S5/2003 Vw Passat
    Pittsburgh
    Stratmosphere Short Shifter Spacers
    I sold my b7 about 8 months ago and only have a few parts left and one of them is the Stratmosphere Short Shifter. I am having trouble selling it because when i took it out i forgot to take out the spacers. So i wanted to reach out and see if anyone has one and would be willing to give me specs on them ID, OD and thickness as i work at a machine shop and could make them or if anyone knows another way i could find the size
    2013 S5 Estoril Blue
    HR Sport Springs | USP RS5 Grille | APR Stage 2 Tune | ECS Boost Tap | 034 Motorsports Intake Tube | EUROCODE Aluminum Upper Diff Mount Insert |EUROCODE Aluminum Lower Diff Mount Insert | EUROCODE Aluminum Trans Mount Insert | BFI Alcantara shift knob | VIM Mod | APR 57.75mm Supercharger Pulley | APR 187mm Crank Pulley | Ported TB | Merc Racing Stacked Heat Exchanger + Divorced | ZKW-R Lens Swap | Eurocode Alu Kreuz
    Registered User Two Rings
    Aug 31 2012
    Rochester, NY
    They were aluminum spacers. OD was either 3/8" or 1/2". ID was around 3/16" and the height was either 1/4" or 3/8". If it were me, i'd buy 1/2" OD, 3/8" ID and 3/8" height.
    Oct 12 2010
    Pittsburgh
    Cool thank you for the response. Will i dont think these have to be exactly the same as what it came with i want it to be as close as possible so the buyer doesnt have any trouble with the operation
