Results 1 to 10 of 10
    Veteran Member Three Rings MantanaB6's Avatar
    Jun 24 2014
    A bunch of bikes and skis.
    Portland, OR
    Vag-com not communicating with ECU or TCU
    I'm posting this in the B6 A4 forum cuz I'm hoping for a quick reply. I have a B6 S4, and it is currently with my mechanic getting some things done, and I asked him to scan my car as a CEL just popped up the other day. I assumed it was from a failing SAI pump (heard the dreaded whirring sound the other morning). Anyways, he plugged it in and said it is not communicated the ECU or TCU. It is communicating with the central convenience however. I drove the car to the shop this morning and both the engine and transmission seemed to be behaving normally. What could cause this? I'm trying to help him diagnose this so he can focus on fixing the other shit on my car and I can still pick it up at the end of the day.
    Previous: B6 S4 Avant Tip Goodwood Green w/ JHM goodies (gone but not forgotten)
    B6 A4 Avant 3.0 Tip Light Silver
    B5 VW Passat 1.8t 5-spd Candy White
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Silly question but is the key in the ignition?
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    Quote Originally Posted by MantanaB6 View Post
    does it have an aftermarket radio, I know weird question but some have been shown to affect the can gateway.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Jun 24 2014
    Portland, OR
    It has a 2012 RNSE, however I scanned it 2 weeks ago and didn't have any issues (pre-CEL). I assume the mechanic has the key in the ignition (he's a friend and probably the best Audi tech I've ever dealt with).
    Jul 31 2014
    NH
    that radio shouldn't effect it, make sure the is in the on position. Can't tell you how many times I've forgot that one. Short of that it may be a failed module on the drivetrain canbus. One module will wreck communications on the whole bus if it has a short on the canbus wires.
    Jun 24 2014
    Portland, OR
    Quote Originally Posted by blitz2190 View Post
    Hmmm, how would you go about determining that?
    Jul 31 2014
    NH
    if the key on doesnt solve it, the simplest way would be unplug each module until you have communication. If that doesn't work it could be either the wires(you'll have to check by hand or a multi meter), or less likely the can gateway.
    Jun 24 2014
    Portland, OR
    Turns out the brand new Ross-tech cable wasn't working. Used and old cable and worked. Freak out for nothing!
    Jun 26 2015
    Tampa, FL
    Geeze man, sometimes the simplest solution. Most of use would've been chasing wires for hours.
    Jun 24 2014
    Portland, OR
    Quote Originally Posted by rocket1420 View Post
    Seriously. So note to people that get new Ross-Tech cables and run into this issue, try an old Vag-Com cable before tearing your dash apart.
