Results 1 to 17 of 17
    Junior Member Two Rings OE24's Avatar
    Dec 17 2015
    1987 Porsche 944 Turbo
    Hollywood, FL
    Need Some Advice Here, Please!
    I have a 2014 Audi A4 S-Line 6SM. with 46,000 miles
    Mods:
    APR Stage 2 since 28,000 miles
    APR turbo-back exhaust since 14,000 miles
    Forged Billet DV since 14,000 miles
    R8 Coil Packs since 35,000 miles
    NGK R Platinum Spark Plugs gapped to 0.028 35,000 miles
    All services have been done by Audi, all oil changes, everything.
    Driving home one night from the grocery store, after a long 300 mile trip, car just randomly begins to shake. I was less than a mile away from home, and as I pulled up, CEL started flashing, EPC light was on, thinking to myself, definitely a misfire. So, I ran the codes and got P0303 (Misfire Cylinder 3). I pulled the coils, and then pulled the plugs.
    On the plugs there was a little bit of oil on the plug itself, but no broken pieces or anything. I bought new plugs, gapped them to 0.028. Same issue, car is still misfiring. I played with the coils by switching them around and the misfiring still remained in cylinder 3. I then checked resistivity of all coils, and they were all good.
    The following day, I have it dropped off at Audi.
    I call the following morning, and they said that cylinder 3 has no compression, I need a new engine and that they will not be covering anything due to my tune(this was expected).
    Now, my question is...could this really be a mechanical issue, such as a failed piston ring, rod or piston itself? Meaning, could there be some other underlying issue to cause little to no compression in just cylinder 3?
    I am getting the car back and taking it home. What else should I check before I tear down the head?
    Could it be a clogged fuel injector just for that cylinder?
    I am speechless that I need a new motor. I always babied the thing, it is garage kept, I kept up with all services and such. On top of that, I literally drove like 300 miles earlier that day,everything was great, and then go to the grocery store, and out of no where bam.
    I must also say, that the car was not blowing any smoke out the tailpipes, just rough idle, and the dash lights (CEL/EPC).
    Jan 19 2016
    At first I would have said it was a faulty coil pack, but if a tech at a reputable audi dealership diagnosed it as something more, I'm not sure now.
    Did you try switching around or swapping a new coilpack into cylinder 3? Could you bring it to an indie or another dealershipand see what they say?
    Dec 17 2015
    Hollywood, FL
    Yeah, I did switch the coils around before taking it in, same symptoms though. I must say that when i changed the plugs to new ones. The shaking began to slightly subside, however it was still there. Oh, and the car sounds like a Subaru WRX, upon accelerating.
    Jan 19 2016
    Quote Originally Posted by OE24 View Post
    Well if you changed them around, the symptoms would have remained, however, the fault code might have given you a different cylinder. If that was the case, then you could diagnose it to be a faulty coil pack. Did you try a new one in that cylinder?
    Oct 15 2016
    Denver
    Was the oil on the plugs just one cylinder or all of them? It's suggests very significant blowby. My first guess would be broken piston ring.
    Senior Member Three Rings Pswish's Avatar
    Mar 25 2016
    2010 Suzuki VStrom 650
    Bay Area
    Compression test in for cylinder 3?
    Early 04 1.8T Dolphin Grey A4 (planning on selling), 165k miles and counting, often in bay area traffic, LED lows & HIDs fogs, ECS Snub mount, Electric systems specialist, Photographer, 2018 Q5 on order.
    Dec 17 2015
    Hollywood, FL
    ok, so I took the car back from Audi. They offered an engine replacement for $12,000. I showed them the finger and drove off in my new and improved 3 cylinder TFSI.
    I got home, I pulled the plugs and there is no oil on them whatsoever. I played around with the coils and move the plugs around, and it is still an error in cylinder 3. I did compression test, 15 times to ensure I am doing it correctly. All cylinders seem to be around 150 psi, and cylinder 3 is at 35 psi.
    I have VAG software and I ran codes again. I got P130a cylinder disabling, and P0303 cylinder 3 misfire. On the way home from Audi, I put gas at Chevron, 93 octane as usual, I am still running APR stage 2 93 octane file. The car began to run a little better but obviously still shakey and the CEL is flashing only when I am at idle.
    Dec 17 2015
    Hollywood, FL
    I am thinking a few different things now:
    1) Injector for cylinder 3 is stuck, and lots of carbon fouling on the piston and cylinder walls.
    2) Piston ring on cylinder 3 cracked or gone.
    3) Is there a bearing on the connecting rod that goes around the camshaft? If so, maybe the bearing is worn out and it is not allowing the piston to move up and down sufficiently due to lack of friction from the torsional motion of camshaft?
    My only option now, is if I purchase a new engine and do an engine swap myself.
    Do you guys know what engine ID i need? I am assuming it is CAED 2.0T TFSI because it is 2014 A4 with 6 speed manual. Anyway I can confirm this? My scanner shows the VIN and then allows me to select which engine. It is either the CPMB or CAED. tried searching online however information is a bit skewed.
    Dec 17 2015
    Hollywood, FL
    Does this sound like a PCV issue? If so, (this may sound stupid) but where is my PCV?
    Oct 15 2016
    Denver
    Stuck injector won't cause low compression. There is a bearing between the connecting rod and crankshaft, but it's not think enough to do what you're describing. I'm sticking with my broken piston ring guess. Unfortunately, it sounds like it's time for a new engine. Look for a used one in good shape. You'll save a ton, esp if you can install it yourself.
    Dec 17 2015
    Hollywood, FL
    Instead of purchasing a new engine, you wouldn't recommend just buying a new piston (~$200 from ecstuning.com), tearing the engine down, install new piston, and call it a day? Obviously I would do this myself. Not sure how simple this engine is on the inside but i assume it is definitely easier to work on than an X5 4.4 V8.
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    If you're interested in the low mileage engine swap idea, hit up Lettuce. He did a DIY a year or so ago for a few grand. Good luck with this, man. That's a terrible situation.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Oct 15 2016
    Denver
    No. It's likely that there's scoring on the cylinder walls that would require machining. Best bet would be to scope the bore or pull the cylinder head and take a look.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by mortimersnerd View Post
    You're absolutely right, but a stuck injector could have been the original issue. It could have washed the cylinder walls until they ended up scored - it wouldn't be the first time that's happened to someone here. Just an educated guess though. it still wont fix the issue at this point anymore.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Possibly a burnt exhaust valve? Did they also do a leak down test or just a compression test?
    2011 A4 Avant
    Oct 30 2006
    B8 A4 Avant 6spd
    I can bet a pretty penny that one of your ring lands broke. It happens, I've replaced a few engines for this reason. Makes sense especially that you had a spark plug covered in oil, the piston is chewing on your block at the moment. I suggest against repair, you'd probably have to overbore at this point, it really depends on what it looks like when you take it apart, though I'm fairly sure the cylinder walls are going to be scored up. If you take your oil pan down (upper and lower) you'll find pieces strewn around.
    Are you out of factory warranty?
    -18 718 GTS
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by Militant-Grunt View Post
    His tune was detected.
