Results 1 to 32 of 32
    Veteran Member Three Rings davidkae's Avatar
    Apr 20 2004
    Torrance
    Where to purchase a used b7 rs4 engine
    I purchased a rs4 car about a half year ago and the engine wasn't holding compression. Found out that the cylinder heads were damage. Now I need to find a used engine. Been looking but no luck. Any ideas will help. The car has been in the shop for almost a half a year because of this issue.
    Account Terminated Four Rings Quattrors4's Avatar
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Best bet usually is eBay
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    Check in with AutoHaas in NJ.. I got a bunch of RS4 engine components from them, and they see long block come through occasionally. Also check www.car-part.com.. and the obvious, ebay.
    Good luck!
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Senior Member Two Rings IronmanS4's Avatar
    Oct 28 2007
    Speedland, Zoo York
    There are enough wrecked R8 4.2's out there , so you can look for one of those as well. GL.
    2022 Audi RSQ8 - Daytona Grey Pearl on Cognac-factory Sport Exhaust- APR Stage 1 93 tune
    2015 Ferrari FF- Grigio Silverstone on Nero
    2015 991.1 GT3- PCCB's-Fabspeed exhaust
    2016 Porsche Cayenne Turbo S (DD )
    Gone..
    2016 Porsche Cayman GT4
    2007 RS4 Daytona-EPL tune
    2003 RS6-Daytona-Milltek DP's -10secS4 tune-
    2001 B5 S4 Stg3+-RS6 turbos
    Apr 20 2004
    Torrance
    I tried researching about that but I heard the block is not completely the same.
    If anyone needs any parts off my rs4 motor, let me know. Trying to recoup any amount
    May 20 2010
    Ditto on Auto Haas.
    Apr 20 2004
    Torrance
    Thank you! I hope I get my car running. Bought the car and didn't get to enjoy it yet. What luck
    Apr 20 2004
    Torrance
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    R8 4.2 engines are the same as the RS4. Only difference between the two engines is the dry sump.
    The user "Mc Suly" is running an R8 engine in his RS4.
    http://www.audizine.com/forum/showth...1#post11736567
    http://www.audizine.com/forum/showth...1#post11963532
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Sep 20 2015
    Check pm
    Oct 25 2016
    What are the ranges for a used engine, 10-12K USD?
    And then you have to pay for installation, while you can get a used RS4 for low 20's (and possibly sell the rolling rs4 for who knows how much)
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by dualquad View Post
    depends on milage but they range around 5500 to 9000$
    May 20 2010
    I wonder if Alex has one, since I know he has parted out some RS4s in the past. Try hitting up 65vetteC6...
    Apr 20 2004
    Torrance
    Thank you. Will try all possible solutions
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    Second for Alex, great seller.
    Other note: R8 block if you can find one, McSully went thru two of them so no question comparability, it's matter where to find one for good price. Good luck Dave
    Aug 22 2014
    07 Rs4 Avus
    Lancaster, Pa.
    what shape is your lower end in(short block)? I may need one. I will know for sure after this weekend when i drop the pan.
    Apr 20 2004
    Torrance
    I have no clue . Car is in the shop with my mechanic
    Aug 22 2014
    07 Rs4 Avus
    Lancaster, Pa.
    I think I misunderstood you. In the original post you say cly head but the pic are pistons so nevermind if that pic is of your motor. I most likely will be looking for a short block if anybody has one.
    Oct 25 2016
    Quote Originally Posted by Quattrors4 View Post
    So a rolling RS4 (w/o motor) would be worth maybe 10-14K I would imagine?
    Veteran Member Four Rings Sole_'s Avatar
    Oct 29 2009
    Put a 2.7 motor in there and call it a day!
    Imola<3
    Sep 20 2015
    Someone can buy a shell and drop a motor in all around 23k. Not bad really with a fresh motor.
    Apr 20 2004
    Torrance
    ^^^if I can find a fresh engine.
    Feb 13 2004
    There is one (vert) with a bad engine for sale 14K
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    Quote Originally Posted by davidkae View Post
    If the block is good, let me know. I'll buy it from you right now. I have a block with some minor damage to mount brackets, and I'd prefer to just replace rather than repair it.
    - - - Updated - - -
    Quote Originally Posted by d2a4 View Post
    That seems a bit overpriced for basically a rolling chassis. Do you have a link?
    -Tim
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by sandspeed View Post
    - - - Updated - - -
    he posted a picture of the bock already and its not good the cylinder wall is gouged
    Feb 13 2004
    Apr 20 2004
    Torrance
    Thank you. Looks like a lot of work. I can't wait until I get this car running
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Just swap the bed plate....
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by q_dubz View Post
    That block might be trash. If you look close the block also has a chunk out of it in the same section, there is a coolant passage right there.
    Apr 20 2004
    Torrance
    Thank you 65vetteC6 for getting me an engine
    Sep 20 2015
    Nice
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by 65vetteC6 View Post
    yep i see it now, damn!
