Results 1 to 10 of 10
    Senior Member Two Rings CoyneJ's Avatar
    Dec 29 2015
    B5 S4
    Illinois
    Auto leveling headlights pointing down
    I got a 09 avant premium plus and the headlights after turning the car on go up only a little bit unlike before where it went up a lot more, now I'm stuck driving with my highbeams on at night because the low beam points too low and the lights won't self adjust to normal position, anyone knows the problem?
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Any warning lights on the dash? Recently lowered? Maybe the leveling arm broke or got out of whack which can be found on the rear drivers side lower control arm - worth investigating. Just spit balling.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Dec 29 2015
    B5 S4
    Illinois
    Car is stock and now warning lights
    Sep 09 2010
    Destin, FL
    For vehicles with 4 headlight range control sensors:
    https://www.ecstuning.com/b-ecs-part...016880ecs01~a/
    For vehicles with 2 headlight range control sensors:
    https://www.ecstuning.com/b-ecs-part...016880ecs02~a/
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    your level sensor arm is likely broken, or orientated the wrong way confusing the car, or you need to recalibrate using vagcom
    My car had the same issue and my headlights were pointed low so I jacked up drivers rear and saw that the arm was snapped off. its a hollow metal tube with plastic piece inserted inside it to secure at both ends then crimped. I screwed a drywall screw into the plastic side and one into the metal side (with the broken plastic piece inside it) to allow epoxy something to grab onto and secured it back that way. The sensor is secured to the control arm with one screw and one electrical connector. Once dry just reinstall and make sure the arm is oriented properly, you'll see how it works where the arm opening > opens wider when the suspension drops lower
    Dec 29 2015
    B5 S4
    Illinois
    Thanks guys, over the weekend I'll look at it and let you guys know
    Nov 10 2010
    Stoney Creek
    If your gonna epoxy it, epoxy putty is probably best for the job. Just make sure you take note of the way the everything is oriented so you don't glue it on crooked/twisted to face the wrong way. I did that and it was facing the wrong way so luckily it was still soft enough to twist to face the right way.
    I also recommend rinsing the ball joint of the sensor with water and lubing it as mine was seized in place and that's why it broke the arm off. I had to work it around to free it up.
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    when i went lower, i had a similar issue. i had to take an allen wrench and re-level my headlights, there is a white plastic piece under your hood that you can turn to re-level your headlights......i can take a picture of it later today.
    Here is a pic to help you,
    Drive your car up to a flat door like a garage door, and turn on your headlights and then start turning the white plastic manually and you will see what I mean.
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Jan 03 2012
    Wilmington NC
    Slight caveat I just realized tho, maybe it's different for your model year tho
    2019 S4 Build
    IG: @steves_s4
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    How do I know which kit to order. I have a 09 Premium plus. When I turn the car on the projectors go up and down not left or right.
    Sent from my LG-V930 using Audizine mobile app
    2009 A4 2.0T Quattro Premium Plus
    Static dropped on 20s, lots of bolt ons, and some appearance stuff
