I just did a halogen to bi-xenon swap in my 2013 b8.5 a5 and used the instructions that came with my kufatec adapter. The lights, led ballast and biexenon ballast are installed.
The the kufatec high beam wires are ran to brown pin 3 and red pin 9, they are pushed in all the way.
I had a 8K0 907 063 DB onboard power supply and could not code 00 to 26 so I bought a 8K0 907 063 DH highline version
The following pins were swapped:
Brown pin 12 to red pin 5
Red pin 2 to red pin 4
Red pin 12 to brown pin 4
Brown pin 4 to red pin 12
I have a Hex Can USB VCDS.
I cannot change the following because everytime I try it says error 31 request out of range
byte 2 to 50
byte 3 to 91
byte 14 to 1D
byte 15 to 0D
Now I am getting fault codes:
01312 - Powertrain Data Bus
00497 - Sensor for vehicle leveling
03124 - Terminal 31-3 011 Open
01543 - Parking Aid Warning Chime
01324 - Control Module for AWD.
My headlights are flickering when driving
Also in the Headlight OFF position the passenger led strip is on and the drivers side led strip is OFF, but the drivers side side marker is on.
1. Any help on what to change to make the flickering go away?
2. Any ideas how to make the faults go away?
3. Do I have the pins swapped correctly?
4. Any ideas how to fix the led strip in the off position(one on and one off?
Thanks,
Scott
