Results 1 to 8 of 8
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Alternatives to VCDS Logging - Torque maybe?
    I'm looking to just check in on knock retard and IATs. Possible to just use torque?
    I don't have any other use for a cable, just looking to see if the car works as expected.
    Wishful thinking?
    Jul 21 2004
    South Florida
    Vcds is prob the minimum in terms of useable logging. The bluetooth apps are terribly slower than even vcds. Vcds is pretty cheap considering you can sell them for good money. Prob cost u 100 bucks to use it in the end
    2018 Audi S5
    Gone-
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by bhvrdr View Post
    This is exactly my thought. I used to use dash command and OBD fusion (which is better btw). It was so laggy that good logging was really not possible. Bought a vag com and although there is a learning curve, you get so much more info and even see the soft codes that the others don't show. I figure that I can always resell it. You should also check out obdeleven though, which I started a thread about before. I probably would have got it but it was not out yet at the time.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Aug 11 2015
    Alberta
    Ignoring lag, can it record a peak number for something like IATs?
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Jul 21 2004
    South Florida
    Quote Originally Posted by cjw View Post
    Hard to say bc it will miss so many datapoints compared to even vcds. It will record a peak data point but this may not be the actual peak datapoint that occurred. That likely got skipped. Remember that its not lag but actual resolution. Its going to be collecting less datapoints not just lagging in collecting them.
    Its kind of like how vcds cant be used for reading knock voltages directly, instead we just measure knock corrections. Knock voltage spikes occur way too instantaneously / quickly that a vcds log is not going to pick it up... which is fine bc thankfully we can see the results of them which is retard.
    Mike
    2018 Audi S5
    Gone-
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Torque is great for keeping an eye on things on the fly when hooning around,but VCDS is needed for accurate usable logs
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Deactivated Four Rings
    Jun 23 2011
    VCDS is the best and now they are only $199 for 3 vins
    Senior Member Two Rings scalbert's Avatar
    Oct 21 2004
    Woodstock, GA
    Too bad we no longer have access to ECUx from APR. Although you can download it...
    http://www.goapr.com/ecux/
