Results 1 to 13 of 13
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    widest tire size?
    coming from a 2014 Allroad. what's the widest tire size can u run on these A3/S3?
    tks in advance.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Sep 02 2016
    Check out the aggressive wheel fitment thread. I wanna say 255
    Sent from my SAMSUNG-SGH-I337 using Audizine mobile app
    '17 Nano / RSe102 / MPS4s/ UM st.2
    Mar 19 2004
    tks. found it.
    Mar 22 2016
    Las Vegas, NV
    widest tire size?
    Widest tire depends on wheel width and offset and if you're willing to run negative camber or not
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    there is a guy on Vortex on a Golf R that is running a 265!!!!! his other specs are 19x9 and running a 30 profile. He says it rubs just a bit...but I think that's a bit extreme...lol
    http://forums.vwvortex.com/showthrea...r-MK7-R/page91
    Post #2271
    Veteran Member Four Rings MerlinS3's Avatar
    Aug 04 2010
    2023 SQ7, 2021 Exclusive SQ5, 2022 Exclusive RS6
    Frisco, Tx
    I am running 255/35 Federal R compound, actual size is about a 265 when put side by side with a bridgestone/nitto/toyo
    [CENTER]CURRENT | RS6 Avant | Audi Exclusive | Uni Stage 2
    CURRENT | 2021 SQ5 Prestige | Exclusive Paint | Sport Exhaust | Black Optic | Dynamic Steering | Sport Package | BC Forged
    CURRENT | 2023 SQ7 | Stealth PPF | Lowered |
    Mar 19 2004
    damn. i guess 275/35/19 from my Allroad wheels won't fit. Lol
    19" x 9.5. offset 40.
    Aug 04 2010
    Frisco, Tx
    Quote Originally Posted by ed@mtl View Post
    youll hit the shock probably and definitely the fenders
    im running 19x10 et35 and my 255's (265 really) almost touch the shock and are on the fenders
    Nov 13 2009
    the OC, SOCAL
    install it. I would like to see it.
    Mar 22 2016
    Las Vegas, NV
    Im going 285/35-18 on 18x9.5 et39
    Aug 04 2010
    Frisco, Tx
    Quote Originally Posted by Lusky View Post
    You don't count
    Mar 22 2016
    Las Vegas, NV
    Quote Originally Posted by VeeDubb View Post
    You don't count
    Feb 16 2004
    Bay Area
    Quote Originally Posted by jiannu View Post
    Post #2271
    Not that hard to believe when you think about it. The tire likely runs narrower than some of the stickier 265s out there. The tire size he chose is actually a tad shorter than factory, which makes the most difference when it comes to clearing large tires. Add in even a little bit of camber and suddenly clearance becomes very simple.
    Unbeknowst to Speed, Racer-X is actually his older brother who ran away from home years ago...
