Results 1 to 4 of 4
    Jun 16 2016
    Camas washington
    Aeb block with atw head?
    I have a 2000 1.8t A4 avant and the engine has seen better days. But I found a lead on a brand new zero miles aeb engine. I've done tons of research and found lots of stuff with the head and block and found that lots of people do the aeb head on atw block. But is it possible to use the aeb block and the atw head? Or use the entire aeb engine and swap parts over ? I just need information on if I can use the entire engine and how.
    Established Member Two Rings [deleted]'s Avatar
    Jun 14 2015
    Woodstock
    The codes AEB and ATW are the cylinder head codings. Both AEB and ATW were bolted to 058 blocks, they are the same.
    Jul 07 2016
    Denver
    Quote Originally Posted by scottsumner View Post
    Did you end up trying it ?
    Sent from my HTC One A9 using Audizine mobile app
    Dec 05 2007
    This is exactly what an ATW engine is. 058 bottom end (AEB short block) with ATW small port DBW cylinder head.
