    Jan 20 2016
    Denmark
    Angry Audi A7 - Shark fin
    Hi Guys
    I just backed my A7 out of garage and knocked the fin off, its not broke but the 6 screw holes are but every thing works fine.
    Is it possible to glue the fin back on and get a tight enough fit so that no moisture will get in?
    If not, I'll have to buy a whole new fin and remove headliner to replace....any ideas?
    Thanks for your input...
    Mar 29 2014
    Hampshire, UK
    You can get a replacement fin from eBay quite easily. The fin is used across a lot of models, although you may have to paint to match the original.
    I don't believe you need to remove the whole headliner, only enough at the back you can reach the underside of the fin. You may even be able to get to it once you remove the rear interior light.
    I wouldn't recommend glue, as it's not likely to last very long. Also the fin does occasionally go wrong and needs to be replaced!
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Jan 20 2016
    Denmark
    Thanks for info RAF.
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    Quote Originally Posted by Sir-Delta View Post
    I would stick it down with clear RTV until you decide how you're going to repair it.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
    Jan 20 2016
    Denmark
    Thanks, I will try that.
    PS: Does somebody here maybe know the difference between the "4G0035503" and "A" - "K" - "P" - "D" - "N" or "E" version? - Little bit unsure which version to buy from Ebay.
